Old Apr 07, 2013, 09:28 PM
SuperFatCat is offline
Find More Posts by SuperFatCat
Joined Sep 2005
Originally Posted by feathermerchant View Post
Jim - If both chassis are still grounded via the power cord, there is no need to separate them.
SuperFat - Since the negative side of the floated power supply is at 12V above ground, making any connection from it to ground will result in the power supply with the grounded negative output seeing a short circuit and shutting down. It may damage whatever caused the short before it shuts down.
Yes I know. The positive from the PS1 which is the 12V will be connected to the floating 12V Neg of the PS2 which will be the 24V source. The floating neg will be internal like some of the others I have see.
The finished panel will have only 12V +/- and 24V +/- binding posts so if others use it, the float neg will never accidentally ground. Also the binding posts for the 12V side will be 4mm, and the 24V side are 5mm to separate them.
SuperFatCat is offline Find More Posts by SuperFatCat
Old Oct 27, 2013, 11:54 AM
rinatka7 is offline
Find More Posts by rinatka7
rinatka7's Avatar
Russia, МО, Podolsk
Joined Dec 2010
Hello to all.
Could someone help me with my part list for converting DPS-600pb power supply.
Some info: Powerlab 8 + 2 in parallel DPS-600pb.
Binding post -
1)http://www.ebay.com/itm/4-pair-Ampli...item563e4c3b6e
or
2)http://www.ebay.com/itm/Red-and-Blac...item35b99eb3f8
Connectors -
http://www.ebay.com/itm/190836891487...84.m1423.l2649
Wires - 12 AWG.
And scheme how to power on PSU.
rinatka7 is offline Find More Posts by rinatka7
Old Feb 28, 2014, 10:47 AM
TM Ru22311 is offline
Find More Posts by TM Ru22311
Collect Vintage Kyosho 1:10
TM Ru22311's Avatar
United States, MI, Monroe
Joined Feb 2014
I was wondering if it possible to get a 5v connection from this PSU without adding resistors? I know there has been a lot of revisions and more info has been posted about the pinouts, so I just wondered if it was easier than adding different resistors to different pins, Thanks.
Also (and please forgive me) but does anyone have quick links to info/pics on removing the board and internalizing the binding posts (these threads are really long). :/
TM Ru22311 is offline Find More Posts by TM Ru22311
Old Mar 12, 2014, 04:09 PM
Riff_1 is offline
Find More Posts by Riff_1
Estonia, Lääne-Viru County, Tapa
Joined Mar 2014
Hi,
Could someone please explain where do I need to connect the zener diode for safety when using them in series? One PS is grounded and second one is not (anymore). I understand I need to connect zener to the floating PS. Does it have to be in between "+" and ground? How do I select correct size zener, I understand it needs to be more than 12,6V? I can get from a local electronics store 13V, 14V and 15V 5W zener diodes?
I measured on the psu that AC ground is also connected to the frame of my psu, should I remove that one also on one ps?
I'm using the HP PS-3701-1
725W 60A
Raimo
Riff_1 is offline Find More Posts by Riff_1
Old Mar 12, 2014, 04:41 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
From where do you glean that a zener is required?
mrforsyth is offline Find More Posts by mrforsyth
Old Mar 12, 2014, 04:57 PM
Brian Molloy is offline
Find More Posts by Brian Molloy
Pitch - Roll - Y'all
St. Louis
Joined Oct 2001
I believe that the zener is part of the original design by AKSCHU. It was a safety feature in case there was a fault as one of the units is ungrounded. Check some of the earlier posts.
The zener value should be found in the same general area. A search on "zener" should work I would think.
Brian Molloy is offline Find More Posts by Brian Molloy
Old May 29, 2014, 06:48 PM
pukas84 is offline
Find More Posts by pukas84
Joined Jul 2011
So I have read a lost of post about floating the ground on the 2nd PSU. So I just want to double check, if I check continuity between the DC ground and the chassis of the PSU, if it reads open then I am ok to have the two PSU touching each other?
pukas84 is offline Find More Posts by pukas84
Old Jan 19, 2015, 09:26 AM
J Fonseca is offline
Find More Posts by J Fonseca
Barcelos - Portugal
Joined Apr 2003
Hi,
I have just finished my HP DPS-600PB conversion project and got very disappointed.
I shorted 6-9-10 and also tried 6-8-10 with a 370Ωpotentiometer between 3 and 9.
Both configurations work with fan in top speed and then shut down after a few minutes charging in parallel 2 6s 5000mAh 40C at 7Ah.
Does anyone know what can I do to fix this?
JFonseca
J Fonseca is offline Find More Posts by J Fonseca
Old Jul 11, 2015, 07:06 PM
CyberCrash is online now
Find More Posts by CyberCrash
Germany
Joined Sep 2009
Do I need a "floated ground" if I don't let the PSU cases touch?
CyberCrash is online now Find More Posts by CyberCrash
Old Jul 11, 2015, 08:07 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
J Fonseca - sorry you are having problems. Have a look at my blog for how I connect mine. The DPS600 is very reliable when built correctly.
feathermerchant is offline Find More Posts by feathermerchant
Old Dec 11, 2015, 01:22 AM
kodachrome is offline
Find More Posts by kodachrome
Joined Oct 2014
Voltage unstable if casing touches
Just finished isolating the DC ground on one of my two DPS 1300 BB psu's.
However when the psu chassis casing touches each other the voltage goes all over the place.. I thought if one side DC is isolated the cases can/should touch? With the cases separated the voltage reads 12 or 24v at the correct points. If the touch it soars upwards!?
Ground is isolated (tested DC ground out to its case) until I connect the a/c Y power cable, then the isolated unit gets a high resistance connection between its ground output and its case..
kodachrome is offline Find More Posts by kodachrome
Question Hp DPS 800gb a power supply Nocept1 Batteries and Chargers 162 Jan 24, 2016 07:30 PM
Discussion COnverting Server Power Supply - EMERSON pluto_26 Power Systems 12 Nov 30, 2015 09:31 PM
Discussion Getting a Compaq HP DL580 Proliant Server Power Supply to Work earlwb Batteries and Chargers 535 May 12, 2015 07:17 PM
Question Can I Use This Compaq Server Power Supply? LowFlier07 Batteries and Chargers 2 Oct 28, 2010 05:23 PM
Help! HP Server Power Supply conversion memory Batteries and Chargers 3 Aug 29, 2010 01:15 AM
