Old May 24, 2012, 09:15 AM
Born-Again HeliNut
Leeds, UK
Joined Nov 2004
Is there a thread (or maybe somewhere on this site but I have looked and it seems this thread is just for the ready made kits for sale) on how to take out the hot swap from the PSU and make your own poles?
muscleflex is offline Find More Posts by muscleflex
Old May 24, 2012, 09:20 AM
Harry H's Avatar
Los Angeles
Joined Oct 2010
The hot swap is held on by a couple of screws. Very straight forward. It is also connect with 2 wires that you simply cut and isolate then remove the ribbon connection from the hot swap. I used the screws to attach the L channel with the binding posts.
Harry
Harry H is offline Find More Posts by Harry H
Old May 24, 2012, 04:03 PM
Born-Again HeliNut
Leeds, UK
Joined Nov 2004
thanks. is that all then? sounds easy enough.. i'm kinda thinking of pairing up the other psu as well for a 24v power supply.
if i do that though, and i just need 12v - can i power just one of them? or both will need be powered on when they've been hooked up together?
Old May 24, 2012, 04:13 PM
Expo/DualRates = Lack of Skill
typeRA's Avatar
San Diego, CA
Joined Mar 2009
The answers to all your questions can be found in this thread and this thread:
http://www.rcgroups.com/forums/showthread.php?t=1581061
typeRA is offline Find More Posts by typeRA
Old May 31, 2012, 04:22 PM
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
I'm getting a small shock when I touch the case of my supply, any ideas? should I just insulate the PS in a housing (im gonna use a plastic tool box). I was barefoot and in my basement so Im sure that was helping a little with me conducting. Do these hacked PS's need grounded?
nebwake is offline Find More Posts by nebwake
Old May 31, 2012, 04:27 PM
typeRA's Avatar
San Diego, CA
Joined Mar 2009
What has been changed from its original configuration?
Old May 31, 2012, 04:29 PM
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Some power supplies are modified to disconnect the Output - (return) from Chassis/Safety ground, in order to be able to put them in series connection (for 24V).
From a safety perspective, the case/chassis should always be grounded, independent of whether the power supply output return is chassis referenced or floating.
If the chassis is allowed to 'float', it can end up any any potential, sometimes hundreds of volts relative to the outputs or earth/safety ground.
ltc is offline Find More Posts by ltc
nebwake's Avatar
Joined Mar 2011
I followed the instructions here
http://www.rcgroups.com/forums/showt...=358340&page=2
Old May 31, 2012, 04:31 PM
nebwake's Avatar
Joined Mar 2011
That is kinda what I thought. How are you guys grounding them out a the field? saltwater and a grounding stake like a HAM radio?
Old May 31, 2012, 05:47 PM
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
There is a distinction between a (safety) ground and a return.
The fundamental idea is to ensure that you are not the inadvertent return path for potentially lethal current. This is usually accomplished by ensuring that accessible metal (chassis) is always at a known potential and capable of handling fault return current.
Most of the time it is seldom an issue.
Old May 31, 2012, 07:49 PM
nebwake's Avatar
Joined Mar 2011
Got it.... so the short answer I simply not to stick your toungue on it
Old Jun 01, 2012, 02:05 PM
VOLTS > AMPS
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Where are you guys getting your jacks from?
I think I may step up to 40amps.
stgdz is offline Find More Posts by stgdz
Old Jun 01, 2012, 06:36 PM
Pitch - Roll - Y'all
St. Louis
Joined Oct 2001
Not the cheapest or closest (Australia) but I bought 50amp jacks here: http://madelectronics.com.au/shop/in...ort=20a&page=2
I couldn't find similar ones anywhere in the states. These work very well.
Brian Molloy is online now Find More Posts by Brian Molloy
Old Aug 24, 2012, 01:14 AM
Puerto Rico, San Juan
Joined Feb 2012
Help with 12/24V PS setup
I'm going insane with this
I went ahead and purchased two more PS thinking one of the previous ones was bad. The problem still there. I've read all 37 pages on this post ( DPS-600PB Builds - hints, tips and build plans) looking for clues. I've tried Lardog's wiring scheme, 123 to GND and 458 shorted. No dice.
Would someone please post an wiring guide for this PS for dummies. I really need it. I must be doing something wrong, but I'm obviously overlooking it. I Think I've tried every combination possible with the darn ribbon. The power outlet or the multimeter are both ok, I can probe a friends Dell dual PS and the voltages on it are steady. Why is it only when the units are touching.
Here's a short video of the voltage variation. Wired 1,2,3,4,5 to GND. All other ribbon wiring combinations get same result. DPS-600PB Voltage Fluctuation.mp4 (1 min 13 sec)
prjoe is offline Find More Posts by prjoe
Old Aug 24, 2012, 10:39 AM
Harry H's Avatar
Los Angeles
Joined Oct 2010
There must be something simple you are overlooking. I know you have posted in the other thread but if you start by doing what rchelijc did in post #8 (photo) http://www.rcgroups.com/forums/showthread.php?t=1581061
and have removed the hot swap, cut and insulated the 2 wires that were connected to the hot swap, all is left is the ribbon cable. Are you sure you are viewing the cable numbering correctly starting with the red wire in the upper left corner and reading from right to left going down the cable? I grounded 1&2 directly to the ground post and jumped 4,5 &8 together (as you know, there are other ways). Check for continuity. Since you have 4 of these and you can't get it to work, there must be something you are overlooking. Good luck.
Harry
Question Hp DPS 800gb a power supply Nocept1 Batteries and Chargers 31 May 09, 2013 10:45 AM
Discussion Getting a Compaq HP DL580 Proliant Server Power Supply to Work earlwb Batteries and Chargers 509 May 05, 2013 02:34 PM
Discussion COnverting Server Power Supply - EMERSON pluto_26 Power Systems 5 Dec 09, 2010 04:19 AM
Question Can I Use This Compaq Server Power Supply? LowFlier07 Batteries and Chargers 2 Oct 28, 2010 04:23 PM
Help! HP Server Power Supply conversion memory Batteries and Chargers 3 Aug 29, 2010 12:15 AM
