Old Jan 13, 2012, 09:12 AM
J3Flyer is offline
Find More Posts by J3Flyer
Brian
United States, MO, St Peters
Joined Oct 2003
Originally Posted by akschu View Post
Ok, here we go.
http://northern-rc.com has been updated.
There are now two offerings:
1. A fully assembled kit. This is a bolt in and go kit, just like the old full kit.
2. A full kit, which has all of the parts you need including the aluminum bracket with the holes already drilled. This kit requires crimping and soldering. I highly recommend using a good crimper (like this one: http://www.proskit.com/crimpers/fram...-crimper-frame). If you don't want to solder there is a $5 option for me to do the soldering for you.
Right now there are 5 full kits and 8 assembled kits. First come first serve.
schu
Hi Schu, I searched thru the available dies but I didn't see any that said they were for APP connectors? Which dies are used the most for general crimping of ring terminals etc..
Thanks for your time....Brian
J3Flyer is offline Find More Posts by J3Flyer
Old Jan 15, 2012, 12:02 PM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
Ok, here we go.
schu
Bummer, out of stock already...will you post here when more are available?
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Jan 16, 2012, 10:12 AM
pakk is offline
Find More Posts by pakk
Joined Nov 2011
Has anyone experienced varying voltage on the ps with the dc- removed when unloaded? When loaded, it is solid.
pakk is offline Find More Posts by pakk
Old Jan 16, 2012, 10:34 AM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Many power supplies do fluctuate their output voltage when there is no load on them. Normally the voltage tends to rise a lot, and the circuitry has trouble maintaining the output voltage with no load on it.
earlwb is online now Find More Posts by earlwb
Old Jan 16, 2012, 11:18 AM
pakk is offline
Joined Nov 2011
That's what I'm figuring but only noticed it when the DC- was removed. I've read several post and have never seen anyone mention it. It is a little alarming when first hooking up your meter.
Old Jan 16, 2012, 10:07 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
The ones I use and sell are rock steady according to my voltmeter. I don't have a scope.
feathermerchant is offline Find More Posts by feathermerchant
Old Jan 16, 2012, 10:33 PM
pakk is offline
Joined Nov 2011
Does it make sense to why I would have varying voltage after removing the DC- when un loaded?
Old Jan 17, 2012, 09:07 PM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Newbie Needs help :)
I have a server power supply that I bought from classifieds. I do not know what brand. I do know that it is producing 12 volts.
How can I discern the amps that it is capable of producing?
According to my Icharger 206B, the charger should be producing 200 watts at 12 volts. Is there a way to test that?
I have tried to charge my 3300, 6s lipos at 5C, but even though I set my charger at 15 amps, it only runs up to a little over 10 amps if I remember correctly.
Obviously the power supply is holding the Icharger back because it COULD produce 300 watts at 18 volts.
But how does one know how many WATTS it will take to charge a 3300 Mah, 6s lipo at 15 amps? What is the formula for ciphering?
If this is not the correct thread for this question I apologize and ask if someone would direct me?
Thanks so much!!!
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Jan 17, 2012, 09:23 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
http://www.customthermoelectric.com/elecequations.html
stgdz is offline Find More Posts by stgdz
Old Jan 17, 2012, 09:27 PM
marksextra is offline
Find More Posts by marksextra
Once u go yak u never go back
marksextra's Avatar
Erie, PA
Joined Mar 2005
Originally Posted by stgdz View Post
That's a pretty sweet little chart. Thanks
marksextra is offline Find More Posts by marksextra
Old Jan 17, 2012, 09:30 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Volts X amps = watts
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Jan 17, 2012, 09:49 PM
They Call him Dead!
Joined Jul 2003
Great Chart Thanks! It certainly gets me started.
I have done some closer looking at my power supply. It is a Dell Switching supply.
It claims that it can produce 502 watts Max
If I understand the symbols correctly, it state that at 5 volts it produces 2 amps and at 12 volts it produces 41 amps.
Of course 12 volts times 41 amps equals 492 watts so that is the Max they state....
Now my Icharger says it produces 300 watts at 18 volts so I assume that means it produces 200 watts at 12 volts.
What I still don't understand is
1. what is the limiting factor of my system that prevents me from charging my 3300 6s lipo at 5c?
2. how to I discern what the limiting factor is?
Is it because I am trying to charge a pack to 22 volts and I only have 200 watts at my disposal therefore I can only get up to around 10 amps?
Old Jan 17, 2012, 09:52 PM
They Call him Dead!
Joined Jul 2003
If that is the case then the Dell power supply is the limiting factor.
SO the next question is how do I go to an 18 volt Power supply. I assume that the Icharger can not take 24 volts so I can not just put two of these Dells together....
Old Jan 17, 2012, 10:04 PM
They Call him Dead!
Joined Jul 2003
Oops... More info:
Here are the specs for the Icharger:
Input voltage range: 10– 28.0VDC
Charge current range: 0.05 – 20.0A
Discharge current range: 0.05 – 20.0A
Maximum charge power capacity: 300W @ input voltage > 18V
Maximum discharge power capacity: 20W
Maximum regenerative discharge power capacity: 300W
Maximum extern discharge power capacity: 500W @ 25V/20A
Seems to me that the specs say that it can run on as many as 28 volts DC. Which means I need to get a 24 volt power supply yes?
It also says its maximum charge capacity is 300 watts at 18 volts. Which I believe means that I can charge at 16.6 amps?
Old Jan 17, 2012, 10:09 PM
RC Helicopter Pilot
Joined Mar 2010
Usually the limiting factor is the charger limits out on either watts or amps.
But you do need to feed the charger with enough power.
These little chargers are pretty sophisticated. They take 12v input and boost it the 25.2V to charge a 6S pack.
The specs for the charger should tell you what input is required to get full output.
Your batteries require - 16.5AMP to charge at 5C and that is 415watts.
Your charger wouldn't provide that.
Question Hp DPS 800gb a power supply Nocept1 Batteries and Chargers 231 Sep 19, 2016 11:07 PM
Discussion COnverting Server Power Supply - EMERSON pluto_26 Power Systems 14 Apr 24, 2016 02:37 PM
Discussion Getting a Compaq HP DL580 Proliant Server Power Supply to Work earlwb Batteries and Chargers 544 Feb 22, 2016 04:10 PM
Help! HP Server Power Supply conversion memory Batteries and Chargers 4 Feb 14, 2016 01:47 AM
Question Can I Use This Compaq Server Power Supply? LowFlier07 Batteries and Chargers 2 Oct 28, 2010 04:23 PM
