Old Apr 21, 2011, 09:15 PM
lpott6 is offline
Find More Posts by lpott6
Joined Dec 2009
Add me to the list for 1 full kit. Thanks
Larry in Denver
lpott6 is offline Find More Posts by lpott6
Old Apr 22, 2011, 02:15 AM
z3scot is offline
Find More Posts by z3scot
Joined Mar 2011
Scott
z3scot is offline Find More Posts by z3scot
Old Apr 22, 2011, 02:27 AM
akschu is offline
Find More Posts by akschu
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
I got some parts ordered, but this time I'm not going to start selling them until they are actually built since last time I got ahead of myself. I suspect they will be available next weekend since it takes about 5 hours to build 10 kits.
akschu is offline Find More Posts by akschu
Old Apr 22, 2011, 10:44 AM
stickybeatz is offline
Find More Posts by stickybeatz
stickybeatz's Avatar
USA, AZ, Phoenix
Joined Apr 2010
put me down for a full kit too
stickybeatz is offline Find More Posts by stickybeatz
Old Apr 24, 2011, 07:50 AM
Remco45 is offline
Find More Posts by Remco45
Joined Aug 2008
Keystone binding post heads unscrewable?
Great thread Akschu,
As I live in Europe and the Tax plus custom charges totals 25,7% not to mention the shipping costs, I've made my one kit per Akschu's specifications.
I hope you don't mind Akschu, and I want to thank you for all the info, the power supplies work great!
Regarding the advice to use ring terminals w.r.t. the high current, my Keystone double head Binding post (See Akschu reccomendation on page 4, type number is 7019) does not allow to unscrew the heads. They jam after 5 millimeters. Can I just force them? Has anyone tried that?
Haven't tried it myself yet as I'm afraid to damage them. Ofcourse, I can use U-shaped terminals, but I like the ring terminals better.
Regards,
Remco45
Remco45 is offline Find More Posts by Remco45
Old Apr 24, 2011, 09:07 AM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
I notch the ring terminal by cutting out a section. It's not perfectly ideal, but does work fine and results in a solid connection that doesn't raise in temp even while pulling 45 amps through it. There is still a little more surface area over using a u shaped connector.
It would be nice if the lugs came off, but I still think this is the best solution as the connector is very high quality.
Hope that helps,
Schu
Old Apr 25, 2011, 01:53 AM
kcobra is offline
Find More Posts by kcobra
Joined Dec 2004
Anyone connect of the stock fan on the DPS-600PB to the +5v purple wire that runs to the breakout board? When removing the breakout board tonight I did this. Seemed to work well. The fan is now very quite. I guess time will tell if the PS get's enough cooling when doing this.
kcobra is offline Find More Posts by kcobra
Old Apr 25, 2011, 02:27 AM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
It's not enough cooling. If you run the power supply hard it will get very hot.
I've been installing two 47ohm resistors in parallel which quiets the fan a bit, but it's still not very quiet, but I'm confident that I'm not going to have heating problems.
schu
Old Apr 25, 2011, 05:12 AM
whitedg is offline
Find More Posts by whitedg
Australia, NSW, Rydalmere
Joined Feb 2010
You can run the fan - wire to the + 5VSB and the + wire to the normal header (+12V) on the fan. This gives a differential of 7V which is not too bad.
Alternatively, you can run a resistor/pot between pin 4 and Gnd to control the fan speed.
Cheers
whitedg
whitedg is offline Find More Posts by whitedg
Old Apr 25, 2011, 09:44 AM
kcobra is offline
Joined Dec 2004
Thanks for the info guys. I'll try out the 7v trick tonight.
Old Apr 25, 2011, 11:00 AM
kcobra is offline
Joined Dec 2004
Couple more questions.
1. Is there an easy way to remove the white epoxy looking stuff from around the fan connector?
2. Is the ribbon cable that goes to the breakout board removable from the power supply board. I pulled on the black connector but it didn't seem to budge.
Thanks.
Old Apr 25, 2011, 01:47 PM
fscii is offline
Find More Posts by fscii
United States, PA
Joined Apr 2011
Let me know about getting one.
fscii is offline Find More Posts by fscii
Old Apr 25, 2011, 01:51 PM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
I should have the parts today, but I just don't have any time to build these things until later in the week. I'll put them on the site when I get them done, but it will be soon.
schu
Old Apr 25, 2011, 11:48 PM
longjohnsally is offline
Find More Posts by longjohnsally
longjohnsally's Avatar
United States, IL, Evanston
Joined Apr 2011
Another full kit please!
schu
If it's not too late, I'd love to get in on this round. Will you have enough for one more full kit?
~LongJohnSally
longjohnsally is offline Find More Posts by longjohnsally
Old Apr 26, 2011, 02:51 PM
kcobra is offline
Joined Dec 2004
Cheers
whitedg
I tried the 7v trick last night, but no go. I connected the black wire from the fan to the 5v wire that went to the breakout board. The PS would come on for a second (fan never ran) and then would shut down. Any ideas?
Question Hp DPS 800gb a power supply Nocept1 Batteries and Chargers 213 Today 05:00 PM
Discussion COnverting Server Power Supply - EMERSON pluto_26 Power Systems 14 Apr 24, 2016 02:37 PM
Discussion Getting a Compaq HP DL580 Proliant Server Power Supply to Work earlwb Batteries and Chargers 544 Feb 22, 2016 04:10 PM
Help! HP Server Power Supply conversion memory Batteries and Chargers 4 Feb 14, 2016 01:47 AM
Question Can I Use This Compaq Server Power Supply? LowFlier07 Batteries and Chargers 2 Oct 28, 2010 04:23 PM
