Old Apr 15, 2011, 11:35 AM
Brian Molloy is offline
Find More Posts by Brian Molloy
Pitch - Roll - Y'all
St. Louis
Joined Oct 2001
Originally Posted by kcobra View Post
Thanks for the info. How much more quite would you say the Sunon fan is compared with the original fan?
A lot quieter . . . think I saw 24 dBA somewhere but don't quote me. There is a spec in PDF out there somewhere but I can't find it right now. Found it: http://datasheet.octopart.com/KDE120...eet-605185.pdf
Here's one: http://www.google.com/products/catal...4585227467012#
Apparently <22 dBA.
Brian Molloy is offline Find More Posts by Brian Molloy
Old Apr 15, 2011, 04:14 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
To answer the question about turning the power supplies off/on I plug them into a plugstrip and flip the switch. I can use the other outlets for my Tx or phone charger.
feathermerchant is offline Find More Posts by feathermerchant
Old Apr 15, 2011, 06:51 PM
kcobra is offline
Find More Posts by kcobra
Joined Dec 2004
Apparently <22 dBA.
Cool. Thanks again for the info.
kcobra is offline Find More Posts by kcobra
Old Apr 15, 2011, 08:45 PM
St. Louis
Joined Oct 2001
My "single" receptacle powerstrip to turn on/off the power supply.
The rest of the clutter protects my workbench from those harmful dust particulates.
Old Apr 15, 2011, 08:55 PM
tjinguy is offline
Find More Posts by tjinguy
TJin(Guy + Tech)
tjinguy's Avatar
United States, NM, Socorro
Joined Jun 2008
Just out of curiosity, what is wrong with just plugging in the power supply when you want to use it?
tjinguy is offline Find More Posts by tjinguy
Old Apr 15, 2011, 09:34 PM
St. Louis
Joined Oct 2001
My wife's on/off switch for her curling iron is the plug too. I end up replacing/servicing that plug and wires at least a couple of times a year. Designed duty cycles for a switch are probably much higher than those for the plug I'd bet.
I'm lazy too; just easier to flip a switch for me.
Throw the first switch Egor . . . yeeesss, Master. Always wanted a largish working knife switch that threw sparks in my workshop. Ah, the sweet perfume of ozone.
Old Apr 16, 2011, 12:30 AM
Gottria is offline
Find More Posts by Gottria
Joined Apr 2011
Brian, very nice like the switch idea. I got one of mine built tonight but waiting till morning to cut the aluminum. I ditched the switch idea, I'm just going to use one of those power strips with short cords on the PS. I used the crimp on lug to 10 gauge wire and screwed it down to the posts for positive and negative like in akschu kit. But I think I might remove the posts and just solder the wires to the board, more room for the wires.
Gottria is offline Find More Posts by Gottria
Old Apr 16, 2011, 10:42 PM
Gottria is offline
Joined Apr 2011
Well got mine built today and all I gotta say is, buy the kit for the $50. Not hard but to build but a lot nicer with the kit as everything is already done.
Old Apr 17, 2011, 12:13 AM
Stan Hinman is offline
Find More Posts by Stan Hinman
Old gasbag glider guy...
Stan Hinman's Avatar
Tehachapi, CA
Joined Aug 2006
Well done, Akschu!
I assembled mine today as well, and all I can say is "Wow!" This is a well thought out and elegant solution to a potentially problematic mod. Thanks again for sharing your insight and expertise with those of us - like myself - who are electrically challenged, and I truly hope and pray that things are improving on the personal front.
Kind regards,
Stan
Stan Hinman is offline Find More Posts by Stan Hinman
Old Apr 20, 2011, 10:53 PM
stickybeatz is offline
Find More Posts by stickybeatz
stickybeatz's Avatar
USA, AZ, Phoenix
Joined Apr 2010
Are any more kits going to be made?
stickybeatz is offline Find More Posts by stickybeatz
Old Apr 21, 2011, 01:34 AM
z3scot is offline
Find More Posts by z3scot
Joined Mar 2011
I like one too, my two power supplies arrived last week and I haven't figured out how to turn them on.
z3scot is offline Find More Posts by z3scot
Old Apr 21, 2011, 01:22 PM
fscii is offline
Find More Posts by fscii
United States, PA
Joined Apr 2011
Originally Posted by akschu View Post
The white wires plug into the header to turn the power supply on when the breakout board is missing.
schu
Can you tell me how to get/make some of those? I'm having a heck of a time trying to work with that terribly small ribbon cable, I'd GREATLY appreciate it if you'd help me out w/making the white wire headers or something.
Thanks!
fscii is offline Find More Posts by fscii
Old Apr 21, 2011, 02:31 PM
akschu is offline
Find More Posts by akschu
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
I'll probably order parts this week. I'll keep you guys updated when I make more.
schu
akschu is offline Find More Posts by akschu
Old Apr 21, 2011, 02:32 PM
USA, AZ, Phoenix
Joined Apr 2010
sweet!
Old Apr 21, 2011, 07:15 PM
St. Louis
Joined Oct 2001
schu
schu,
Please put me down for two full kits when ordering parts.
Again thank you for your product and hard work!!
Question Hp DPS 800gb a power supply Nocept1 Batteries and Chargers 213 Yesterday 05:00 PM
Discussion COnverting Server Power Supply - EMERSON pluto_26 Power Systems 14 Apr 24, 2016 02:37 PM
Discussion Getting a Compaq HP DL580 Proliant Server Power Supply to Work earlwb Batteries and Chargers 544 Feb 22, 2016 04:10 PM
Help! HP Server Power Supply conversion memory Batteries and Chargers 4 Feb 14, 2016 01:47 AM
Question Can I Use This Compaq Server Power Supply? LowFlier07 Batteries and Chargers 2 Oct 28, 2010 04:23 PM
