Goodlettsville, TN
Joined Sep 2006
Very nice work. This I think I could do as opposed to the other. What did you have to do or remove to mount the aluminum with binding posts? Did you put the resistors in series? Don't suppose you took any pics of the modification to the board?
Also, what about using a fusible link on the DC output side, so if there were ever an issue it wouldn't be a total melt down? ![]() http://www.amazon.com/Beck-Arnley-17.../dp/B000CRVM12 |
Wayne,
That sounds like a good idea. I'm assuming that they would be put in like this: GND -----i>| ----- DC - How about this one? 1N5364BRLG http://www.onsemi.com/pub_link/Collateral/1N5333B-D.PDF I'm not sure how to size these things, I'm thinking it would probably burn out of there was a transformer failure, but perhaps not before the power supply shuts down. Can you recommend one that will work? I am going to order a few power supplies and build a new updated version for myself and a few extras for others that want them. But before I place my parts order, I would like to nail down exactly which diode to use. schu |
Rugby, UK
Joined Feb 2007
Yes that one (33V) or the 28v version should be OK and I agree with connecting it across the 24V rail and retaining the output earth connection on the lower unit. Or you could put a 15V one across each 12V output. You obviously understand the situation, so even this is not a 100% fix, it must depend on the resistance of any fault path. The lower the resistance, the bigger the zener capacity you need. If you have an earth leakage trip on the mains input it does not need to be larger, but with a hard short and no trip who knows? We are talking about remote chances but that's what safety is about. There is no guarantee; specifically from me! But it would make it safer. Just retaining the output earth on the lower unit would help; it's having completely floating outputs that would make me uneasy. Wayne |
Well, I'm going to use a 15v diode on the floating power supply since that is all of the potential it will ever see before we are in some kind of failure.
One thing I'm wondering about is how to test to see if the diode is even doing it's job. As long as nothing blows up when I turn it on I guess I would need to have a real fault to know since that is the only way we are going to see over 15v where the diode is. I think this is a reasonable step to try and add back the protection removed to make them run in series. I think this solution is much better than getting rid of the ac ground and isolating the cases. It looks nice too. schu |
Rugby, UK
Joined Feb 2007
I think you are correct about testing as well. If you use a minimum size mains fuse commensurate with the full load current, then it has the max chance of clearing on a fault without blowing the zener open. Overall looks best solution. Wayne |
Agreed - slickest and most thorough solution yet.
I must admit, I am more than a little concerned these days about folks connecting different power supplies in series without a full understanding of the dangers. High powered chargers demand more power, and to get it many people having heard of this practice are haphazardly connecting power supplies in configurations for which they were not designed for and have not been tested or CE certified. All we can do is fight the good fight and continue to educate people. Every week now I get a call or two with a story about series connecting two random, disparate power supplies in an attempt to get more power - with varying success. I sincerely hope the chances of disaster are infinitesimally small and that most all modern supplies have adequate protection built in to avoid anything catastrophic. My concern is for the people playing around modified industrial or hobby grade equipment who don't understand the physics involved and that their actions may be potentially dangerous. Cheers, David |
Dave, that's always been a concern and the reason I started the "Two supplies - safety issues" thread. The problem is I suspect that many of the regular contributors tend to be reasonably knowledgeable while the occasional Google driven searcher who comes across the idea and neither knows nor cares about the whole story may not be.
Not much we can do about it. I would be happy to add your warning to the Sticky thread. Any objections? John"That Quote:
| Thread Tools | |
| Question Hp DPS 800gb a power supply | Nocept1 | Batteries and Chargers | 31 | May 09, 2013 10:45 AM |
| Discussion Getting a Compaq HP DL580 Proliant Server Power Supply to Work | earlwb | Batteries and Chargers | 509 | May 05, 2013 02:34 PM |
| Discussion COnverting Server Power Supply - EMERSON | pluto_26 | Power Systems | 5 | Dec 09, 2010 04:19 AM |
| Question Can I Use This Compaq Server Power Supply? | LowFlier07 | Batteries and Chargers | 2 | Oct 28, 2010 04:23 PM |
| Help! HP Server Power Supply conversion | memory | Batteries and Chargers | 3 | Aug 29, 2010 12:15 AM |
