Old Jan 10, 2011, 07:47 PM
Canada, MB, Oakbank
Joined Dec 2004
how to use this elevon mixer
Hi there. Just got this mixer and need help on how to hook it up. It has 2 plug ins on the unit itself, one on top of the other, where I plug my servos into. Then on the trailing end there is a Futaba plug (black, white, red wires), and a JR plug(orange, brown, yellow wires). I am using it on a GWS Rx, and need info on how and where to hook it up to.
NEW222 is offline Find More Posts by NEW222
Old Jan 10, 2011, 07:59 PM
58 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Plug the two servos onto the pins and the cables into aileron and elevator on the receiver and start experimenting. Keep track of what you do because there are several combinations and only one of them will give you the right results. First you'll have to figure out which way round the servo plugs go on the pins. They will only work one way. Getting it wrong won't harm anything. Do one to find out and then the other to match it.
Focus on getting the control surfaces to move together with elevator input and in opposite directions for aileron input. You don't tell us what transmitter you are using. Does it have servo reversing?
Daedalus66 is online now Find More Posts by Daedalus66
Latest blog entry: Polaris Aileron Pushrods
Old Jan 10, 2011, 08:20 PM
Canada, MB, Oakbank
Joined Dec 2004
Yes, it has servo reversing. Futaba Conquest 4 channel FM.
Old Jan 10, 2011, 08:32 PM
Canada, MB, Oakbank
Joined Dec 2004
Well, when I plug the Futaba end into port 2 and the JR end into port 1 the annoying bell stops. Then I plug the servos in. When I plug the servos in, they move, but when I push up and down on the right stick, it acts as the ailerons, and when I move it side to side, the elevators go up and down together. Unplug one lead from the Rx, that damn buzzer goes off.....
Old Jan 10, 2011, 10:47 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I told you you are going to have to experiment. I'm assuming you have the radio in the model so you can see which way the surfaces, not just the servos move. The three variables are: (1) elevator reverse, (2) aileron reverse, and (3) which cable goes to aileron and which to elevator. So get experimenting.
Where is the buzzer?
Old Jan 11, 2011, 05:57 PM
Canada, MB, Oakbank
Joined Dec 2004
Buzzer is in the end of the mixer, opposite of the leads to the Rx. Will try again now, and report back. Thank you.
Old Jan 11, 2011, 07:08 PM
Canada, MB, Oakbank
Joined Dec 2004
Ok, so the new results.... It works as I had originally thought and hooked it up, only thing different was that I made a big mistake. I was using a Berg DSP Rx. I don't know what I was typing. Sorry. But after hooking up the GWS Rx, it worked great.
Now, I tried the Berg DSP 5 and 6 again, along with a Cirrus Rx, and neither worked with the mixer. I hooked up the same as the GWS was while it worked, but no go. I swapped the servo leads, nothing, I then tried swapping the leads to the receiver, again, nothing. Not a big deal as I will use the GWS, but was wondering what may be causing this? Thanks again for the help and sorry for my mistake of Rx.
Sold Ohmark Elevon/V Tail Mixer EBerris Aircraft - General - Radio Equipment (FS/W) 0 Dec 29, 2010 08:49 PM
For Sale Elevon or V-tail mixer, Fm crytals mikeochs Aircraft - General - Radio Equipment (FS/W) 1 Dec 29, 2010 06:18 PM
Rave FirmTronics DigiMix - II Programmable Elevon and V-tail mixer WLJayne Sailplane Talk 0 Nov 08, 2010 12:26 PM
For Sale RX crystals, Hitec rx pack, Elevon, V-tail mixer mikeochs Aircraft - General - Radio Equipment (FS/W) 2 Oct 31, 2010 03:32 AM
Discussion How do i use this ESC.......so many wires?? scorpion1 Racing Boats - Electric 28 Sep 05, 2010 07:43 AM
