Old Jan 09, 2011, 06:26 PM
ScotY is offline
Find More Posts by ScotY
ScotY's Avatar
Joined Feb 2001
Flush cut router bit for Dremel?
Has anyone ever seen this type of bit in an 1/8" shank to fit a Dremel? It would be similar to the type of router bit used to trim laminate for countertops or to cut multiple parts using a template. I've searched and would assume someone would sell one but have not found anything yet.
Thanks, Scot
ScotY is offline Find More Posts by ScotY
Old Jan 09, 2011, 06:34 PM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
http://www.dremel.com/en-us/Attachme...me=Router+Bits
Your local hobby shop of harware should be able to help you with availability.
Try the cut on a scrap piece of like-material first. Keep the RPMs slow as not to burn the wood and bit.
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Jan 09, 2011, 07:27 PM
ScotY is offline
ScotY's Avatar
Joined Feb 2001
I didn't see anything like what I'm looking for. See the bit by clicking the link below. Looking for something like it.
http://ecx.images-amazon.com/images/...500_AA300_.jpg
Old Jan 09, 2011, 07:54 PM
jcpatrick is offline
Find More Posts by jcpatrick
Jim C Patrick
jcpatrick's Avatar
Shenandoah County
I use tungsten-carbide bits from McMaster-Carr. Technically they are die-grinder burrs, but they work fine in the Dremel tools. They cost ≈$5 nowadays, but I have four and they have lasted almost 20 years in all sorts of use.
For the use you propose, I'd recommend the double-cut (faster cut) but the trick is the 1/8" shank, 1/8" diameter head which does a 1:1 transfer. Just adjust the seating of the bit in to the dremel so the smooth shank contacts the pattern and the teeth engage the raw material. If you use the radiused-end, you can plunge-cut into soft materials as well.
McMaster is where I got the ones I have, but they are available from a dozen places, and the pictures are from a Karnasch catalog.
jcpatrick is offline Find More Posts by jcpatrick
Old Jan 09, 2011, 08:06 PM
hammerd is online now
Find More Posts by hammerd
Las Vegas, NV
Joined Mar 2008
http://routerbitworld.com/PhotoDetai...log-page26.jpg
#46196 or #46296
Nevermind, those have an 1/8" cutter diameter, but a 1/4" shank.
hammerd is online now Find More Posts by hammerd
Old Jan 09, 2011, 08:12 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Okay, so you're looking for a trim/bevel bit with a live bottom bearing? Sorry, I haven't seen a bit with such a small bearing either. As you may know, the extension on the bottom of the bits in the Dremel link serve the same purpose, although a live bearing avoids burning the wood, and serves on a trim bit to bring the material you're removing flush with the work piece.
I'm afraid that chances are you'll only find the extended fixed "bearing" on a 1/8" shaft router bit. If you do, PLEASE post where to get them!
EJWash
Old Jan 10, 2011, 12:38 AM
ScotY is offline
ScotY's Avatar
Joined Feb 2001
Thanks for the ideas, guys. I guess those McMaster Carr bits would work, but would probably be better on a router table setup since the "bearing" surface would be on the bottom, closer to the collet.
EJ,
A ball bearing would be nice but not necessary at all. It's a shame Dremel doesn't make such a bit already...wonder why?
Old Jan 10, 2011, 05:46 AM
Jim C Patrick
jcpatrick's Avatar
Shenandoah County
. . . A ball bearing would be nice but not necessary at all. It's a shame Dremel doesn't make such a bit already...wonder why?
That when people trim laminate, they use 'real' routers? The cost of the bearing? . . . a bearing that is not only smaller, but must turn at higher RPM?
You haven't explained why you want this; what the purpose is. Laminate trimming is one thing, but pattern cutting and sign routing is normally done pattern-above, stock-below.
For Sale Carbide Router Bit set for Dremel SkyKing RC Aircraft - General - Miscellaneous (FS/W) 6 Jun 10, 2009 12:00 PM
Discussion Ersatz router attachment for Dremel mototool. Steven S Foamies (Scratchbuilt) 1 Jun 08, 2009 10:00 PM
Best Dremel Bit to Cut Depron? / Magnet Mounting on Alfa FW190 product Parkflyers 4 Sep 06, 2004 05:17 PM
Dremel bit or other for cutting CF plate? JoeR Power Systems 3 May 28, 2002 09:20 AM
Which dremel bit to cut plywood? Steph280 Electric Plane Talk 12 Nov 09, 2001 03:45 PM
