Old Jan 09, 2011, 09:16 AM
maineflyer1 is offline
Find More Posts by maineflyer1
USA, ME, Caribou
Joined Nov 2006
Help!
Need foamy for Eflite 300 set up
Guys,
I need a 3D foamy for an Eflite 300 set up. I will be flying it outside primarily.
Thanks in advance for any suggestions.
Jeff
maineflyer1 is offline Find More Posts by maineflyer1
Old Jan 09, 2011, 09:54 AM
Dan5.0 is offline
Find More Posts by Dan5.0
Joined Dec 2008
Whats a 300 set up. Motor weight, esc, and servo sizes?
This?
http://www.e-fliterc.com/Products/De...rodID=EFLM1150
Dan5.0 is offline Find More Posts by Dan5.0
Reply With Quote  (Disabled)
Old Jan 09, 2011, 09:57 AM
USA, ME, Caribou
Joined Nov 2006
Eflite servos S75s, 18 amp ecs (I think) and TP 3s 830s.. I had it in an Eflite 260 originally and then a Yak.. Not sure of Man..
Old Jan 10, 2011, 07:44 AM
USA, ME, Caribou
Joined Nov 2006
This is the motor I have, need a 6-9 oz 3d plane.
Old Jan 11, 2011, 12:29 PM
USA, ME, Caribou
Joined Nov 2006
Anyone with any suggestions?? Please??
Old Jan 11, 2011, 12:45 PM
hankg is offline
Find More Posts by hankg
Lost but making good time
Joined Nov 2008
maineflyer1,
That motor would be perfect for Leadfeathers Yak55, Edge 540, Slofly 28" or any of the 30"-32" Epp profile 3Ds you will find on the "Scratchbuild Thread" on this site. There are a lot of people selling precut kits that run anywhere from $35.00 to $200.00 depending on whether you want an exotic paint job or not. I have purchased a few from Mike at www.E-foamy.com and have had good luck with them all. I know Dan 5.0 has a few more on his list that he could probably add. Also...www.Techonehobby.com sell some really great kits that that motor would go well with.
I don't have any experience with anything but 3D EPP profile models that I have built myself. I have a few prints of full fusalage EPP planes that would fit that motor but here again, you will have to build them.
Regards,
Hankg
hankg is offline Find More Posts by hankg
Last edited by hankg; Jan 11, 2011 at 06:31 PM. Reason: additional thought popped into my brain housing
Old Jan 12, 2011, 05:39 AM
USA, ME, Caribou
Joined Nov 2006
Thanks for the info, how much do the e-foam 32" planes weigh?
Old Jan 12, 2011, 07:39 AM
USA, ME, Caribou
Joined Nov 2006
I checked out Techonehobby but can't see where you can buy them on the site...
Old Jan 12, 2011, 08:21 AM
hankg is offline
Joined Nov 2008
maineflyer1,
Go to www.84hobby.com for a few Techone planes. The f3p site might have more info on them. The 32" E-foam planes come in at around 8 oz, depending on battery size. I've built a few that were closer to 7 oz AUW, but had to really watch glue, pushrod size, battery etc.
Regards,
hankg
Old Jan 12, 2011, 10:12 AM
USA, ME, Caribou
Joined Nov 2006
Thanks for the info!
Old Jan 12, 2011, 11:53 AM
hankg is offline
Joined Nov 2008
mainflyer1,
http://www.rcgroups.com/forums/showt...t=piaget+build
Check out the build specs and log on this Piaget build by "Tallflyer" along with the pictures...it will give you an idea of what it takes to build a TechOne airplane.
Blow up the pictures for a really clear view.
Regards,
Hankg
Old Jan 12, 2011, 03:14 PM
USA, ME, Caribou
Joined Nov 2006
Hankg,
Thanks for all the help, I was looking at a Extra 300 on Tower but it is 3mm and doesn't look at sturdy as the TechOnes... I have a bunch of 3S batteries for this motor 830ma?? Thunder Powers and will be using those so I may be a little heavy. I will leave the gear off as we fly from grass. Can you use regular CA on these??
Again thanks,
Jeff
Old Jan 12, 2011, 05:28 PM
hankg is offline
Joined Nov 2008
maineflyer,
The Piaget I own is made of 5mm EPP. I fly over grass at a local soccer field so none of my planes have landing gear on them. Unless i get into real trouble I bring them in into the wind and set them down nose up, tail down in the grass.
I used Loctite Stick and Seal (Walmart) on the Piget because it is made of EPP. Welders will also work fine but is harder to find. You will be surprised on the sturdiness of TechOnes planes, especially the mid wing planes that use a lot of 1mm carbon reinforcing. They are very well thought out and strong. I use 3S 500 milliamp batteries on my foamies to keep the weight down.
Regards,
Hankg
Old Jan 12, 2011, 05:57 PM
USA, ME, Caribou
Joined Nov 2006
Sounds great, I am really looking hard at those planes and think that is where I am gonna buy, Looking at the Piaget or the Spirit.
Old Jan 12, 2011, 06:28 PM
hankg is offline
Joined Nov 2008
maineflyer,
Check out the all up weight on both planes and go for the lighter plane. I didn't realize the size of the Piaget until it arrived at my house. It doesn't look like much in the box, but when you start putting everything together, you end up with a lot of airplane. Mine comes in at 8.5 oz without the battery, so add in the weight of your battery and you will have an idea of the AUW your motor will be dealing with.
The directions are hard to read due to the poor picture quality. Use Tallflyers build thread to supplement. I think the build protocol is basically the same for both planes.
It's a great plane to fly and with the airbrakes (I pinned them on the wing with straight pins rather than gluing), the plane will almost stop on a dime when you cut throttle.
Post Script...check this out
http://www.rcgroups.com/forums/showt...techone+spirit
Regards,
Hankg
Discussion I Need your shopping list for the BEST LONG RANGE FPV Set up patrick21x FPV Talk 43 Jul 31, 2011 11:30 AM
Question Foamy For this set up? Lilbanks96 3D Foamies 5 Dec 26, 2010 11:00 AM
Discussion Need help to set up Heli cdllt Fuel Heli Talk 6 Oct 19, 2010 10:11 PM
Need help with twin engine set up - foamy P38 watts Foamies (Kits) 0 Jul 31, 2005 03:02 PM
