Old Jul 04, 2012, 11:17 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
I would build another 104 with 7955's all around....2 on rudder, single on each elevator, and three on each aileron. I really enjoy my crisp feel from the current setup of 7955's all across the wing. I currently have a 7980 on the rudder...it's a little slower than a pair of 7955's would be. I've got 7955's and 7950's....but I've had way better luck out of the 7955's...so I'll keep using them....on direct 2s lipo power. I just bought 5 more for the 87 I've got to build.....
Also, I'm using FULL throw with no trouble on all surfaces.....even the ailerons with three 7955's.
The two main reasons I love Hitec servos are their programmability...and their customer service on repairs for free. I like programming the servos in each wing to function together...with no matchboxes or fancy boards required. Nothing to plug in wrong...and it's easy to setup a plane on a trainer box with it functions like a standard 6ch plane.
Bivens is offline Find More Posts by Bivens
Old Jul 11, 2012, 07:39 AM
Nicoflyer is offline
Find More Posts by Nicoflyer
Pushing the envelope
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
I putting Savox 2270sg servos in my, but I'm a little concerned with the gear lash in them. The 7955 may shake but they have virtually no gear lash. I'll going to try to stay withj the smallest servo arm and the longest control horn as possible to get the throws needed to help reduce the slop.
Nicoflyer is offline Find More Posts by Nicoflyer
Old Jul 11, 2012, 08:07 AM
ghoffman is offline
Find More Posts by ghoffman
USA, NH, Bedford
Joined Oct 2009
If I did it again, I would not use the Hitec 7955's again. The programming is indeed nice, but since my JR 9303 won't address each aileron servo, I had to get a Smart Fly EQ-10 anyway, negating the use for programming. I sent back the 7950 I had on the rudder because it shook like hell, had wicked blow back (it put out about 380 oz-in not the 480 claimed), and whatever they did (new firmware supposedly) it did not change anything. So I asked a guy (who said he was Mike Mayberry's boss) about it at the WRAM show, and he just said "Oh well, it worked on the test bench". So I went over to the Futaba booth and relayed the Hitec story and got a promise that the BLS-157HV would A) put out the 500+ oz-in advertised torque, and B) would not shake. He gave me a business card and said if there was any issues, he would take care of it. The BLS-157's are brushless and use less current, and the one I have on the rudder works great. It easily does full throttle KE loops, centers perfectly, and has no shake or jitter. If I had to do it again, or if I had the money now, I would use 2, -157's on each aileron, one on the rudder, and one each on the elevators. The only downside to the Futaba BLS-157's is cost.
ghoffman is offline Find More Posts by ghoffman
Old Jul 12, 2012, 10:58 PM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Yo Tim! We need some shots of the new "West Coast 104".
-Buzzed
P.S. How is the IMAC work coming along?
Buzzed is offline Find More Posts by Buzzed
Old Jul 13, 2012, 12:06 AM
XXLBMXER is offline
Find More Posts by XXLBMXER
Team 3DHS
XXLBMXER's Avatar
Los Alamos CA .
Joined Jan 2009
Hey Marty, this new 104 is friggin AWESOME! Just got back from the flying field a little bit ago and the sunset was goin off... made me think of your pictures. I really am impressed with how well the 104 is in IMAC style flying, I am still breaking in the 120, which scares me, if this motor makes any more power I wont know what to do. Did a little 3D with it today and well it was friggin awesome there too...duh. Ohh I here my charger yellin at me
XXLBMXER is offline Find More Posts by XXLBMXER
Old Jul 13, 2012, 02:42 PM
Buzzed is offline
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Sounds great! Can't wait to "Feel the Power" of the 120 next month.
Woohoo!
Old Jul 16, 2012, 06:05 AM
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
Just curious where roughly you guys are with the hi and low needles and what were they set on initial start up of new DA 120 with stock mufflers. (J&A Incowl muff)
I understand that they vary form place to place.
Old Jul 16, 2012, 11:25 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
Both of my 120's ran on needles set by DA before they shipped me each one new....I DID make slight adjustments to get them running a little better for me...adjusting as needed with weather and breaking in....but they both ran on initial startup of stock needle settings.
The sad part is that I've got hundreds of flights on my 120's...but I don't think I've ever actually counted turns....Basically, I've never needed to make large adjustments...so I've never found a need to find out exactly where I am......lucky I suppose...but unfortunately I can't really answer your question about initial startup...I don't recall where they were set...but I do know I didn't have to change them to get it running and flying. I've been very happy with my DA's.
Old Jul 17, 2012, 06:13 AM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Needle Adjustments
• The needle farthest from the motor is the “High End” needle. The needle closest to motor is the “Low End” needle. Turning the needles clockwise “leans” the fuel mixture. Turning the needles counter-clockwise “richens” the fuel mixture.
• Settings will vary with altitude, temperature, humidity, fuel, carb variances, etc. A general starting point is: 1 1/2 open on the Low needle, 1 1/2 open on the High needle.
• Adjusting either needle can have a slight effect on the other. Example: leaning the low needle can "slightly" lean the high range.
• Adjust the High End needle to peak rpm. A tachometer is a great help, but remember that the RPM may drop a little bit after every start due to residual heat build up. Don’t lean the mixture any more than necessary. If the rpm steadily drops at full throttle or fades on long vertical maneuvers, the motor is too lean and is over heating.
• Adjust the Low End needle until you achieve a smooth idle and a reliable transition to high throttle. Generally if the motor “stutters” or “coughs” in the mid range or when the throttle is advanced, the low end needle is too rich and possibly even the high end needle. If the motor dies quickly, the low end is probably lean.
• Don't set the needles overly rich to protect the engine. Operating the motor overly rich not only reduces power, it creates other problems such as poor transition, pre-mature carbon build up, fouled plugs, excessive exhaust residue, sticking rings, and overall rough running.
jsmith285 is offline Find More Posts by jsmith285
Old Jul 17, 2012, 08:19 AM
RotorJockey is offline
Find More Posts by RotorJockey
Fly Low-Crash-Rebuild-Repeat !
RotorJockey's Avatar
Jackson, MO
Joined May 2009
Thanks Jim!
I copied and pasted that in a word document so I have it to refer back to!
Fred
RotorJockey is offline Find More Posts by RotorJockey
Old Jul 17, 2012, 08:59 AM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
Jim you should update the "DA sheet" as I call it with this info. I have it on my iPhone so I can torque prop bolts on my 60 and 120 and just double check!
aerosheldon is offline Find More Posts by aerosheldon
Old Jul 17, 2012, 11:39 AM
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Updated my blog post for the DA information.
Old Jul 17, 2012, 02:18 PM
sk8rob is offline
Find More Posts by sk8rob
3D Wanna Be
sk8rob's Avatar
Oahu, Hawaii
Joined Jul 2009
An absolute thing of beauty...quite possibly the lowest roll on take off I've ever seen!
The Take Off (0 min 12 sec)
theKm = Beast
sk8rob is offline Find More Posts by sk8rob
Old Jul 17, 2012, 04:28 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
I suppose that's what you've gotta do with Chris and Cody standing right there....I'm sure Joe was close by also....nice job KM...that's tough to top!
New Product 3DHS 42" AJ Slick Gear Fix jake48 3D Flying 25 Nov 26, 2010 01:01 PM
Sold NEU 1512 2.5D w/6.7 GB & Castle 80 AMP, Perfect for 3DHS AJ SLICK 70" / 72" Extra Alkaline Aircraft - Electric - Power Systems (FS/W) 4 Nov 07, 2010 08:34 AM
Question 3DHS 41" Edge and 42" AJ Slick RC_Feen 3D Flying 26 Oct 12, 2010 01:29 AM
Found 3DHS 51" AJ Slick BNF ShoGinn Aircraft - Electric - Airplanes (FS/W) 8 Sep 05, 2010 05:19 PM
