Old Jan 30, 2012, 08:29 PM
hosam is offline
Find More Posts by hosam
hosam's Avatar
United States, MI, Livonia
Joined Nov 2004
okay, radio battery questions... two 2S 4000 lipos or two 3S 2500 lipos for servos? also, what discharge rate should I look for (15c, 20c, etc). I am ready to order batteries for the 104 not thought if I got a 3S I may not need as large of a pack. The voltage will be regulated to 8 volts input...
okay, bring on the comments
Hosam
hosam is offline Find More Posts by hosam
Old Jan 30, 2012, 08:32 PM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
kind of depends on the regulator. I use Smart Fly so I use 2S lipos as that is what it says to use
Oh and is that your Viper?
aerosheldon is offline Find More Posts by aerosheldon
Old Jan 30, 2012, 08:36 PM
ctunder77 is offline
Find More Posts by ctunder77
Team 3DHS
ctunder77's Avatar
USA, DE, Newark
Joined Jul 2008
I would get the 3s batts but go a little bit bigger, maybe to the low 3000s. More flights and the 104 is not going to feel it at all.
Chris
Hosam
ctunder77 is offline Find More Posts by ctunder77
Old Jan 30, 2012, 08:46 PM
RFairbairn is offline
Find More Posts by RFairbairn
RFairbairn's Avatar
United States, SC, Simpsonville
Joined Aug 2011
Hosam,
I'm going to use 2 Gen's Ace 2S 25C 3300's, 7oz ea. I bought 4 so I can swap them out and keep flying while I recharge. Should be good for quite a few flights between charges.
I would stick with 2S, it'll be more than enough power. No need to add extra weight and an extra pt of failure with a regulator IMO.
I started using the Gens's Ace brand after a member here (Losifanatic) recommended them for my electric planes. I was leary because of the price but they've been outstanding so far and you can charge at 5C.
RFairbairn is offline Find More Posts by RFairbairn
Old Jan 30, 2012, 08:49 PM
ghoffman is offline
Find More Posts by ghoffman
USA, NH, Bedford
Joined Oct 2009
No contest, get a DA-120.
ghoffman is offline Find More Posts by ghoffman
Old Jan 30, 2012, 09:34 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
I use a pair of Gensace 2s4000's in my 103/104. They work well.
Bivens is offline Find More Posts by Bivens
Old Jan 30, 2012, 09:37 PM
ssflylow is offline
Find More Posts by ssflylow
TEAM CANUCKER HUCKER
ssflylow's Avatar
Canada, AB, Medicine Hat
Joined Sep 2003
Pretty much the same here. I use a pair of Hyperion 2s 3300's.
ssflylow is offline Find More Posts by ssflylow
Old Jan 30, 2012, 09:41 PM
sk8rob is offline
Find More Posts by sk8rob
3D Wanna Be
sk8rob's Avatar
Oahu, Hawaii
Joined Jul 2009
I use 2-2200 mah turnigy 25c. work great, light, and cheap.
sk8rob is offline Find More Posts by sk8rob
Old Jan 30, 2012, 09:44 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
me too
cmala is offline Find More Posts by cmala
Old Jan 31, 2012, 06:52 AM
hosam is offline
hosam's Avatar
Joined Nov 2004
thanks for the information guys... battery shopping today
I wish... it was a test vehicle we had for a month (it was a month of pure joy) to work on and test new products for our transmissions... that is me driving it though...
Old Jan 31, 2012, 04:21 PM
dccdmd is offline
Find More Posts by dccdmd
dccdmd
dccdmd's Avatar
USA, CA, San Diego
Joined Jul 2008
Wait! No one wants to suggest a LiFe pack (A123)? Solid pack, doesn't lose voltage fast on the tail end of capacity. I like the 6.6 3300, probably good for at least 5-7 flights and they hold a charge in the hanger very well!
dccdmd is offline Find More Posts by dccdmd
Old Jan 31, 2012, 04:25 PM
bobby808813 is offline
Find More Posts by bobby808813
bobby808813's Avatar
United States, OH, Youngstown
Joined Jul 2009
Chris
i went with 3s 2100mah and two bec pros on my 104 slick you get a nice consistent voltage i get a solid 8 flights at about 30% left in the packs. i read a while about running 3s i think it was KM's 104 build where he talked about it running that setup
bobby808813 is offline Find More Posts by bobby808813
Old Jan 31, 2012, 04:31 PM
Team 3DHS
ctunder77's Avatar
USA, DE, Newark
Joined Jul 2008
Yeah that's what I'm doing also 3s lets me regulate to 8V for the full capacity of the battery. With 2s it's only above 8V for a small portion of the discharge. 2s however, is better if you're regulating to a lower voltage.
Old Jan 31, 2012, 04:35 PM
Joined Jul 2009
i got my regs set at 7.5v is it ok to set them at 8v ive got all hv servos
Old Jan 31, 2012, 04:51 PM
skippy78 is offline
Find More Posts by skippy78
skippy78's Avatar
USA, VA, Narrows
Joined Mar 2009
If you are using 3s then setting it to 8v will be fine. If it is 2s then 8v will be to high since the battery is only at 8.4 when it is at full charge.
skippy78 is offline Find More Posts by skippy78
New Product 3DHS 42" AJ Slick Gear Fix jake48 3D Flying 25 Nov 26, 2010 01:01 PM
Sold NEU 1512 2.5D w/6.7 GB & Castle 80 AMP, Perfect for 3DHS AJ SLICK 70" / 72" Extra Alkaline Aircraft - Electric - Power Systems (FS/W) 4 Nov 07, 2010 08:34 AM
Question 3DHS 41" Edge and 42" AJ Slick RC_Feen 3D Flying 26 Oct 12, 2010 01:29 AM
Found 3DHS 51" AJ Slick BNF ShoGinn Aircraft - Electric - Airplanes (FS/W) 8 Sep 05, 2010 05:19 PM
