Old Oct 12, 2011, 10:55 AM
Dahly is offline
Find More Posts by Dahly
Dahly's Avatar
Joined Apr 2011
Originally Posted by theKM View Post
1.5" arms will work if you max out your end points properly... 2" arms if you want absurd throws, mine has 1.5" arms at the moment.
I like to gang rear mounted rudder servos one on each side... one servo and arm can completely fail and the other will still be happily connected to the rudder. That said, you can easily gang both the servos on one side no problem.
I agree with KM on the ganging...
I am using 2" on my air brake, sorry I mean elevator.
Be advised, the 2" arms come very close to the rear screw that holds the stabs on. I actually used the "single side" ball joint end to provide additional clearance to the head of the bolt as it is gets very close. The geometry is very much in line and I did not see any binding at the end points.
Dahly is offline Find More Posts by Dahly
Old Oct 12, 2011, 01:54 PM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
PimP the RaFFLe (again) !
Get in while the geTTin is gOOder !!
Purchase your raffle tickets by clicking the awesome image below !!
No need to be present !!! Simple and FAST....just a few clicks !
Lonelasso is offline Find More Posts by Lonelasso
Old Oct 12, 2011, 08:59 PM
mytms is offline
Find More Posts by mytms
Joined Oct 2010
Thanks for the info. Figured 2" is what i would need cause i only have 1.5's, figures thats my luck. Guess i"ll be calling troybuilt
mytms is offline Find More Posts by mytms
Old Oct 12, 2011, 09:03 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
max out your endpoints, 1.5 will work... I get 50 degrees throw on elevator with 1.5" arms
2" can get you some more wild throws, but for what it's worth, 1.5" arms on all servos...
104" AJ Slick - 3d comfort food (9 min 19 sec)
theKM is offline Find More Posts by theKM
Old Oct 13, 2011, 06:13 AM
DalAv8r is offline
Find More Posts by DalAv8r
DalAv8r's Avatar
Peachtree City, GA
Joined Jun 2008
I'd like to try this also, (one rudder servo each side) but I only have 1 pushrod long enough(approx 5") that came with the kit. Where did you purchase a second pushrod? I looked on the 3DHS site and was unable to find anything.
Scott
DalAv8r is offline Find More Posts by DalAv8r
Old Oct 13, 2011, 06:36 AM
ghoffman is offline
Find More Posts by ghoffman
USA, NH, Bedford
Joined Oct 2009
Hanger 9 sells them, they look identical except that they are titanium.
ghoffman is offline Find More Posts by ghoffman
Old Oct 13, 2011, 08:11 AM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Scott
You can use the Hangar 9 ones or Troy Built models has some also.
http://www.troybuiltmodels.com/items/TBMLINKT5.html
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Oct 13, 2011, 08:31 AM
Lonelasso's Avatar
Joined Dec 2006
**Additional Raffle Prizes Information !!**
2 additional prizes have been added !!!
47" Osiris !!!
48" Super Vyper !!!
Purchase your raffle tickets by clicking below !! Need NOT be present to WIN !!
Old Oct 13, 2011, 09:40 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
I do need to rework my throttle linkage a little, it hovers at a click or 2 over idle. That will be a Winter project.
just a 3 minute project if you fix it with throttle curve....and infinitely adjustable....
Bivens is offline Find More Posts by Bivens
Old Oct 13, 2011, 09:58 PM
Dahly is offline
Dahly's Avatar
Joined Apr 2011
Scott
TBM 5" if my memory serves me correct.
Old Oct 13, 2011, 10:00 PM
Dahly is offline
Dahly's Avatar
Joined Apr 2011
At theKM...
Do you have a 120 in your 103"
I was wondering if DA 120 plugs will hit cowl?
Old Oct 13, 2011, 10:05 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Originally Posted by Dahly View Post
At theKM...
they miss the cowl... 104 is designed with the 120 dimensions in mind.
Latest blog entry: Updated Hatcam - Apr2016
Old Oct 13, 2011, 10:17 PM
Dahly is offline
Dahly's Avatar
Joined Apr 2011
Thanks, actually I was wondering about your 103" Extra- wrong forum I know, but just saw your green light was on ....
Old Oct 13, 2011, 10:29 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
sorry, I didnt read the 103 right...
there is some rubbing... I need to add a thin ply or carbon rub plate and a zip tie around the plug connector. but while it has manage to rub through the high spot on the heat shrink it's not so bad as to be a massive concern to me
Old Oct 13, 2011, 10:30 PM
bobby808813 is offline
Find More Posts by bobby808813
bobby808813's Avatar
United States, OH, Youngstown
Joined Jul 2009
104 slick
Got the smoke working great thanks km and joe for the great advice i love this plane its flying perfect .km let me know if you have any great ideas getting the oil heated up .
bobby808813 is offline Find More Posts by bobby808813
New Product 3DHS 42" AJ Slick Gear Fix jake48 3D Flying 25 Nov 26, 2010 01:01 PM
Sold NEU 1512 2.5D w/6.7 GB & Castle 80 AMP, Perfect for 3DHS AJ SLICK 70" / 72" Extra Alkaline Aircraft - Electric - Power Systems (FS/W) 4 Nov 07, 2010 08:34 AM
Question 3DHS 41" Edge and 42" AJ Slick RC_Feen 3D Flying 26 Oct 12, 2010 01:29 AM
Found 3DHS 51" AJ Slick BNF ShoGinn Aircraft - Electric - Airplanes (FS/W) 8 Sep 05, 2010 05:19 PM
