3DHS 104" AJ Slick
wingspan - 104"
length - 96" (including spinner) motor - Hacker A100-8 with 27x10 carbon prop lipos - 12S 10,000mAh ESC - Castle ICE HV160 ...can also be flown as a gasser with 100-120cc. 104 availability getting close, more and more people gathering equipment, time to get the thread rolling... When final touches are in place, all specs will be updated into this post. 104" wingspan, about the same length with the spinner on as far as I know (I could measure it, but the specs will be along soon ). Designed around the output of a 100cc gas engine, it's perfect for a Hacker A100-8 with 12S 10,000mAh. For those with gasser aspirations, a DA100 will provide plenty of power for 3D, but the cowling will have the room to drop in a DA120 without needing a shoe-horn (and providing truly awesome amounts of power on the 120).Being 3DHS it comes with the full lineup of carbon pieces (landing gear, wing tubes, etc) and info as I have it is that it will also come with: cloth wing bags, two piece cowling, carbon spinner, and two horizontal stabs (3D stab with counterbalance, IMAC stab without). When package, price and preorders are up, this package will also be updated. Will be available in two schemes, a red/white/blue dynamic AJ scheme, and bright orange variant that is a little sharper race-like feel... same as is planned for the 59" Slick. Gear required... - 8x 7955TG Hitec servos or equivalent - metal gear throttle servo - 2" SWB arms (8x if push-pull rudder servos, 6x for pull-pull) - 4" SWB offset arm for pull-pull rudder - engine - prop sized for engine - flight pack power system - ignition cut off (recommended if going gas) A few handy measurements for transportation needs... (sitting on fully assembled landing gear including tail wheel) - rudder height: 28" - fin height without the rudder: 22.5" - canopy height: 26" - top of turtle deck without canopy: 24.25" - top of the cowling: 24.5" - length from rudder post to front of cowling: 83" Now for some pics and videos... Andrew Jesky flying the 104 at a San Antonio fly-in:
(flown with DA120, Mejzlik 28x12, stock mufflers) Joe Smith maiden flight of prototype:
(also DA120, on stock mufflers, Vess 28A) . |
| Thread Tools | |
| New Product 3DHS 42" AJ Slick Gear Fix | jake48 | 3D Flying | 25 | Nov 26, 2010 01:01 PM |
| Sold NEU 1512 2.5D w/6.7 GB & Castle 80 AMP, Perfect for 3DHS AJ SLICK 70" / 72" Extra | Alkaline | Aircraft - Electric - Power Systems (FS/W) | 4 | Nov 07, 2010 08:34 AM |
| Question 3DHS 41" Edge and 42" AJ Slick | RC_Feen | 3D Flying | 26 | Oct 12, 2010 01:29 AM |
| Found 3DHS 51" AJ Slick BNF | ShoGinn | Aircraft - Electric - Airplanes (FS/W) | 8 | Sep 05, 2010 05:19 PM |
