Old Jan 08, 2011, 05:23 PM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
Maximum length between Esc & Motor
Hi All i'm sure this qestion has been asked before
i need to move my esc as far back as i possibly can to be able to get the COG right in one of my planes but dont want to kill a 500+ $ esc , the minimum that i need is 300mm (12 inches)is this possible ? and will i loose any performance by doing so?
I know that i could add some wheight to the tail of the plane but this thing already wheights 800 grams more then what it's supposed to be
Many thanks
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Old Jan 08, 2011, 06:48 PM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Between ESC and motor, length is not critical. You won't notice a 12" extension at all. The critical side is between ESC and battery, and even there, 12" would be tolerable. I'd match the motor wire gauge with good quality silicon wires.
whitecrest is offline Find More Posts by whitecrest
Old Jan 08, 2011, 07:08 PM
Adrian_M is offline
Joined Dec 2010
Hi Thanks for that would i still be able to use 4 mm bullets i know it would be better to solder the wires but i dont have the room i only have a 25 mm hole for the wires to go thru
hanks again for your help
Cheers
Old Jan 08, 2011, 09:32 PM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
I'd use the bullets too. There is very little loss in those. Good luck with the installation.
Old Jan 08, 2011, 09:54 PM
Arkansas Travelr is offline
Find More Posts by Arkansas Travelr
God of Gravity Poisoning
Arkansas Travelr's Avatar
Joined Nov 2010
You shouldn't have any worries extending your ESC output wires your motor is full of wire that side of the ESC is more tolerant of inductance than the battery side. The only issue I've ever heard from longer ESC motor wires is minor RF interference with the rx this can be avoided by braiding or twisting the three motor wires together or careful wire placement.
Arkansas Travelr is offline Find More Posts by Arkansas Travelr
Old Jan 08, 2011, 10:55 PM
Adrian_M is offline
Joined Dec 2010
Hi Guys many thanks to you both i have done the install and will try it out next weekend
Discussion Multirotor Arm Length & Motor Placement & Reaction/Response Rate bob4432 Multirotor Talk 8 Sep 09, 2010 05:46 AM
Discussion Max wire length between motor and ESC? makeitworst Power Systems 6 Mar 04, 2009 01:32 PM
Discussion qestion- wire length between esc and motor pimaa Power Systems 1 Mar 17, 2008 03:08 PM
Question maximum recommended wire length DerekLieber Castle Creations 5 Jan 04, 2006 01:35 PM
Maximum servo wire length. oilman Radios 1 Nov 26, 2004 08:41 AM
