Old Jul 25, 2003, 07:49 PM
Jim W is offline
Find More Posts by Jim W
Joined May 2003
12 volt power supply
I am trying to find a good way to power my triton battery charger. I have a 12 volt power supply from Radio shack but it is unregulated and puts out 16 volts which my Triton will not handle. I then switched to a 12 volt lawn tractor battery charged from a 500 ma wall transformer. This is not a good solution becaucse I cannot charge both my 12 cell 2600 mAh one after the other. The best solution would be to buy or construct a voltage regulator for my power supply. Or buy a regulated power supply that can handle 5 amps which I cannot find a source for.
What do y'all use to charge battery packs?
Jim Weirauch
Jim W is offline Find More Posts by Jim W
Old Jul 25, 2003, 07:56 PM
misskimo is offline
Find More Posts by misskimo
TeamTP,Minicopter,Spartan
misskimo's Avatar
Mississippi 31 years , Now Kotzebue , Alaska 12
Joined Apr 2001
you can buy a 12 v power suppy that puts out about the same as a 12 v car battery , which is about 13v , up here in Alaska everyone has a 12v power supply , they hook a CB up to it or a VHF radio , the kind that go in trucks or boats , best to get one that can handle 10 amps or more Tony
misskimo is offline Find More Posts by misskimo
Old Jul 25, 2003, 08:05 PM
misskimo is offline
misskimo's Avatar
Joined Apr 2001
hey , heres the specks on mine
SemlexAmerica model # sec 1212
in 120v 60hz 2.5 a
output 13.8 vdc 10A
distr. in Canada
made in taiwan
huh? get the name "america" , the the distr. "canada" , then the maker , taiwan , but it works great except I cant use 2 chargers at the same time unless I charge at around 4A each
Tony
Old Jul 25, 2003, 08:10 PM
Jim W is offline
Joined May 2003
thanx--I'll see if I can find it onthe web
Jim
Old Jul 25, 2003, 08:12 PM
domlou is offline
Find More Posts by domlou
LAS VEGAS
Joined Jun 2001
I got mine from here :
Nice PS and a good price.
http://www.millionbuy.com/caudio-kit-sup.html
The 10AMP power supply is only $35
domlou is offline Find More Posts by domlou
Old Jul 25, 2003, 08:13 PM
misskimo is offline
misskimo's Avatar
Joined Apr 2001
hey , I was hecking if I could find it on msn search sure anough there it was , and look at some of the refurbished ones by them , good price on the 20 a one 1220 http://www.samlexamerica.com/samlexhome.htm
Old Jul 25, 2003, 08:53 PM
gmaster is offline
Find More Posts by gmaster
Hooked Heli Human
gmaster's Avatar
Western NC
Joined Dec 2002
i use a 25A DC Power Supply from Radio Shack with my Triton and it works fine.. weird about the problem you are having..
gmaster is offline Find More Posts by gmaster
Old Jul 25, 2003, 09:18 PM
Jim W is offline
Joined May 2003
Thanks guys. that gives me a couple of good choices.
Jim
Old Jul 26, 2003, 02:13 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
I use a 1000 amp spiral wound 12v battery and a 25 amp Radio shack PS on my Orbit V6 and Pro chargers.
I am moving this to Batteries and Chargers.
FB
Fred Bronk is offline Find More Posts by Fred Bronk
Old Jul 26, 2003, 06:37 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Universal Radio has a good selection and excellent service.
http://www.universal-radio.com/catalog/hamps.html
RC Man is offline Find More Posts by RC Man
Old Jul 27, 2003, 02:32 AM
OzzieFlyer is offline
Find More Posts by OzzieFlyer
Melbourne Australia
Joined May 2003
a lot of people use an old PC power supply. They are generally 12V regulated. The only thing to watch out for is that some are switchmode so need a load before it will turn on. Not sure how you get around that problem with a switchmode power supply. This all got too hard for me so I bought a cheap 13.8V regulated power supply off ebay.
Also, I am told that you shoulg get 13.8V instead of 12V as if you want to charge 3S Lipolys, you won't be able to. I am not sure if this is correct, but have heard it a few times so have no reason not to believe it.
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old Jul 27, 2003, 04:55 AM
hansen is offline
Find More Posts by hansen
Denmark
Joined Jun 2003
Hi,
The easiest way, is to go to your local used pc store. Buy a pc power supply, with at least 200w and a min of 8a on the 12v output. Cost me around 10$. I have built two, and they work great. Charging my packs at 5 amps with my power peak infi. 2 with no problem.
Regards
hansen is offline Find More Posts by hansen
Micronta 12 Volt Power Supply??? glider34 Batteries and Chargers 8 Feb 24, 2009 06:54 AM
amperage for 12 volt power supply datsun74 Batteries and Chargers 3 Apr 19, 2005 10:13 AM
F/S 12 Volt Power Supply steve f Aircraft - Electric - Airplanes (FS/W) 3 Aug 23, 2004 03:51 PM
$15.00 - 22 Amp 12 volt power supply. Will it work? asperkins Batteries and Chargers 11 Jun 28, 2002 02:31 PM
12 Volt Power Supply - lost link rc4metoo Electric Plane Talk 6 May 01, 2002 03:13 PM
