Old Jul 25, 2003, 04:22 PM
dodgeboy is offline
Find More Posts by dodgeboy
Joined Jul 2003
My first brushless (questions)...
I have a local shop willing to part cheaply with a Astroflight 020 "Corona" brushless 4 turn helicopter motor with controller. I've never had a brushless before, so I have a few questions. Please answer what you can:
1) I would like to put this motor in a WingWarrior Zipper plane. What's the difference between the helicopter and aircraft versions of the 020, besides the removable flange?
2) How do you reverse a brushless? Do I need a different controller, or is it as simple as reversing two of the three wires going to the motor?
3) Do I have to use a zero loss connector between the battery and ESC? (as recommended in the manual)
4) Can I remove the plug between the ESC/motor and solder the wires directly? I understand that there are very strict rules on the length of the wire between the ESC and motor...
Any input would be greatly appreciated!
Thanks in advance,
Dave
dodgeboy is offline Find More Posts by dodgeboy
Old Jul 25, 2003, 04:58 PM
t.nollett is offline
Find More Posts by t.nollett
coventry uk
Joined Nov 2002
it has a kv of 3300.[rotations per volt] a bit high for direct drive
link http://www.astroflight.com/e/env/000...ucts:af-803hcm
needs a gearbox.
i use 2mm gold connectors between controller and motor, just switch cables to change rotation
4mm gold between battery and controller.
t.nollett
t.nollett is offline Find More Posts by t.nollett
Old Jul 25, 2003, 05:01 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
1) just a special wind, probably 'torquey' which means it will swing a larger prop slower..
2) depends on what controller it has - Astro sensored controllers require a lot - switch power wires, sensor wires and retime the motor (physically) so it's usually not worth the effort. If it's a recent, sensorless, controller, however (OEM Castle Phoenix), then just switching 2 of the 3 wires b/w the ESC and motor will work.
3) No. Deans Ultra, Sermos, etc. will work fine.
4) Yes - just don't make them too long. If there are ONLY three wires b/w motor and ESC, then you're good in #2, above. In fact, the 3-way Zero-Loss that Astro sends out the new 020's with will in fact allow you to just reverse the motor by flipping the connector.
..a
Old Jul 25, 2003, 06:03 PM
dodgeboy is offline
Joined Jul 2003
What kv range should I be looking at? I checked out all of the specs on the motor before posting this, but I'm not sure exactly what I'm looking for in terms of kv. I was previously running a cobalt with a 7x3 prop on a Zagi. I had to run such a large prop because the cobalt didn't spin very fast, even without a load. I would like to stick to a 5-7" prop...
The motor is sensorless, with a sensorless (Castle) 35A controller, so it looks like I'm good on #2.
Sorry I'm such a newbie at brushless. Most of my motor/prop combinations have come to fruition by trial and error. It's just too expensive to use that method with brushless, which is why I appreciate your help so much.
Dave
Old Jul 25, 2003, 08:41 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Ah, it's all on Astroflights web page:
http://www.astroflight.com/e/env/000...ducts:af-803hc
Not sure if that controller is suitable to an airplane? Programming may be different.. use the Castle Creations forum to ask them if there's much of a difference..
..a
Old Jul 26, 2003, 01:35 AM
coventry uk
Joined Nov 2002
never seen a WingWarrior Zipper , but if i was you i would do a search in foamies and park flyers as they go into great detail of what combo's they have in there zagi's, cuts out the trial and error.
t.n
look here http://www.rcgroups.com/forums/showt...Warrior+Zipper
Old Jul 27, 2003, 07:33 PM
dodgeboy is offline
Joined Jul 2003
Thanks for the input, guys... I'm leaning toward a Mega 16/15/4, which should be a nice, middle of the road start into brushless for my foamies. I don't want to run a gearbox, because I can't really run a larger prop with a flying wing. I'm going to stick with a relatively small (5x5, 4.75x4.75 or 6x4) prop and see how it works out.
Dave
Old Jul 27, 2003, 08:33 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I ran a 9x5 on my old Zagi. My new one is cut so I can swing a 12"..
..a
Old Jul 28, 2003, 07:28 AM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
"I can't really run a larger prop with a flying wing."
http://www.rcgroups.com/forums/showt...hlight=lue+tic
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Jul 28, 2003, 11:20 AM
coventry uk
Joined Nov 2002
well if motocalc is to be believed this is a better set up,16-15-6
zagi
NC = 8
Gear Ratio = 1.00
Diam (in) = 8.0
Pitch (in) = 5.0
Batt Amps = 15.5
Motor Amps = 15.5
Motor Volts = 9.3
Input (W) = 143.6
Output (W) = 100.4
Loss (W) = 43.2
Motor Ef(%) = 69.9
InPLd (W/lb) = 135.2
OutPLd (W/lb) = 94.5
Elect Ef(%) = 67.5
Prop RPM = 10149
Thrust (oz) = 17.5
PSpd (mph) = 48.1
Time (m:s) = 4:16
from motocalc...''With a wing loading of 6.4oz/sq.ft, a model of this size will have very sedate flying characteristics. It will be suitable for relaxed flying, in calm or very light wind conditions.
The static thrust (17.5oz) to weight (21.3oz) ratio is 0.82:1, which will result in very short take-off runs, no difficulty taking off from grass surfaces (assuming sufficiently large wheels), and steep climb-outs.
At the best lift-to-drag ratio airspeed, the excess-thrust (12.2oz) to weight (21.3oz) ratio is 0.57:1, which will give steep climbs and excellent acceleration. This model should be able to do consecutive loops, and has sufficient in-flight thrust for almost any aerobatic maneuver''.
with a 16-15-4 and a 4.75x4.75,you will get a much higher prop speed but it would be a pig at slow speeds as the prop would stall
NC = 8
Gear Ratio = 1.00
Diam (in) = 4.8
Pitch (in) = 4.8
Batt Amps = 11.6
Motor Amps = 11.6
Motor Volts = 9.4
Input (W) = 108.8
Output (W) = 92.1
Loss (W) = 16.8
Motor Ef(%) = 84.6
InPLd (W/lb) = 102.4
OutPLd (W/lb) = 86.6
Elect Ef(%) = 82.4
Prop RPM = 20096
Thrust (oz) = 9.6 ...........very low thrust
PSpd (mph) = 90.4
Time (m:s) = 5:40
t.n
Maidened my first brushless fwilly Parkflyers 6 Mar 19, 2003 04:07 PM
Need your thoughts on my first Brushless! DiabloKid Power Systems 8 Feb 18, 2003 10:15 AM
my first Brushless....help! witstick Power Systems 4 Nov 30, 2002 07:53 PM
My first brushless flight! Switchback 3D + Hacker Martin Hunter Parkflyers 84 Oct 27, 2002 08:38 PM
Not my first brushless Boot Electric Sailplanes 1 Dec 18, 2001 03:54 AM
