If you've seen a chart like this, it was wrong.
I know that's a bold claim, but in general there are better ways to pick a motor than by a comparison to something else. This is mostly because an electric system can be tuned to an airframe much better than an engine can, by varying voltage, Kv, and prop size. With an engine, you're given a size by the instructions and you get to choose 2-stroke or 4-stroke, with a bit of prop selection. It works, but rarely gives the best possible setup because there are so few options. With electric, it's best to size your motor based on the weight and desired speed of the model. It can be intimidating at first because there are so many hundreds of choices, but with a bit of care it can result in a power system perfectly suited to a particular airplane. For more details on this process, take a look HERE. |
| Thread Tools | |
| Discussion Brushless Motor Chart w/ Glow Comparison | waynejb | Electric Plane Talk | 2 | Nov 14, 2010 07:50 AM |
| Discussion Brushless Motor Chart | waynejb | Power Systems | 1 | Nov 06, 2010 08:18 PM |
| Question Heli motor and esc chart | frosaflyn | Power Systems | 1 | Oct 30, 2010 11:29 AM |
| Discussion Huge motor chart | watersteps | Electric Motor Design and Construction | 4 | Sep 08, 2010 04:52 PM |
| Biulding Estarter need conversion chart | radcast2 | Electric Plane Talk | 6 | Oct 28, 2004 06:33 AM |
