This thread is privately moderated by jmpdgs, who may elect to delete unwanted replies.
Old Jan 06, 2011, 04:31 PM
jmpdgs is offline
Find More Posts by jmpdgs
A Global Force For Good
jmpdgs's Avatar
USA, OH, Cincinnati
Joined Jun 2009
HL/Freewing SU-34 Alternative Programming
I'm on my 3rd (yes that's right) SU-34, a testament to both how much I like the aircraft and how poorly I seem to fly it. During the interval between #'s 2 & 3 I changed from radios from a DX7 to a JR9303. I also decided to attempt "full implementation" of the 360 capabilities of the AC so I dropped in a seven channel RX.
The best laid plans it is said, often go awry and I began struggling with the various available radio programming suggestions. Both the one in the manual and those found in the RCG and HL forums all shared one commonality, none of them seemed to work for me, so after talking to Scott in Tech Support at Horizon for the better part of an hour, I decided to abandon what had been tried before and simply go with a completely new and what I hoped would prove to be a more intuitive approach. In truth, all of the programs I saw, including my own, are very similar. The main difference in this program is that it allows you to TURN OFF the majority of the thrust vectoring with a single switch. The exception to this (and it's advantage) is that some limited yaw movement remains, acting as a very effective rudder substitute.
The beauty of this setup is that the TV nozzles will act as a rudder when the TV switch is off and fall into full elevator/aileron assist mode when the TV is activated. Take offs and landings can now be done with the TV OFF without sacrificing the advantage of having a rudder (even though no rudders exist) which as anyone who flies on windy days will tell you is a God send. In addition, I've programmed in some cross control aileron assist to help hold altitude in those steeply banked turns.
All in all I like the program, which fits my flying style. Try programming it into a free slot and give it a whirl. -- Happy flying
The following is how I programmed a JR 9303 on 2.4 using an AR7000 receiver.
Start with:
Vector control 1 to AUX 1 on RX
Vector control 2 to AUX 2 on RX
Vector control 3 Y'd to the Rudder (may be necessary to put a reverser in the line for the nose wheel)
Prog Mix 1:
AIL to AUX 1
Point 0 = -75
Points 2, 3, 4, 5 INH
Point 3 = 0
Point 6 = +75
Switch select = Mix ON the rest OFF
Prog Mix 2
AIL to AUX 2
Point 0 = -75
Point 3 = 0
Point 6 = +75
Switch select = Mix ON, the rest OFF
Prog Mix 3
ELEV to AUX 1
POS 0 = 0%
POS 1 = - 80%
MIX SW to Pos 1, all the rest in Pos 0
Offset 0
Prog Mix 4
ELEV to AUX 2
POS 0 = 0%
POS 1 = -80%
MIX to Pos 1, all the rest in Pos 0
Offset 0
Prog Mix 5
AIL to RUDDER
POS 0 = 0%
POS 1 = +90%
Offset 0
Prog Mix 6
AIL to RUDDER
POS 0 = -50%
POS 1 = 0%
MIX all to Pos 0
Offset 0
Set all D/R and Exp values to whatever makes you comfortable.
For me a good set of starting values are:
Ailerons & Elevators : Low Rates = 75% Travel & +35 Expo
: High Rates =100% Travel & +20 Expo
Rudder & Steering : Low Rates = 35% Travel & +40 Expo
High Rates = 75% Travel & +25 Expo
REV/NORM Servo Switches
THR = NORM
AIL = REV
ELE = REV
RUD = REV
GER = NORM
AX1 = NORM
AX2 = NORM
AX3 = NORM
AX4 = NORM
Device SEL
Flight mode = INH
Bottom line all = INH
Wing Type = NORMAL
V-tail = INH
Mate = all INH
Type Sel = ACRO
Programmed as above, the "MIX" switch turns the "Vector Thrusting" ON and OFF
jmpdgs is offline Find More Posts by jmpdgs
Found Hobby Lobby/Freewing Su-34 retractable landing gear Thomas B Aircraft - Electric - Jets (FS/W) 1 Dec 26, 2010 11:26 PM
For Sale 2 Freewing F-15/Su-34 Power systems teha99 Aircraft - Electric - Jets (FS/W) 4 Oct 12, 2010 10:16 PM
Wanted NIB Freewing SU-34 360 jmpdgs Aircraft - Electric - Jets (FS/W) 2 Oct 10, 2010 08:15 PM
Discussion anyone know where i can get a blue freewing su-34 arf cheap? aferguson Foamy EDFs 0 Sep 26, 2010 09:59 PM
Wanted WTB Freewing / HL SU-34 360TV TTRotary Aircraft - Electric - Jets (FS/W) 1 Jul 10, 2010 07:43 PM
