| Thread Tools |
| This thread is privately moderated by tim.fuggdesign, who may elect to delete unwanted replies. |
servos and thrust tube
I'm using Hitech HS65 HB servos at the back, spent the extra as they're doing all the work, plus if I feel like upping the power later on they should be up to the job.
They're a nice tight fit but require some foam to be removed to allow the leads out and also there a little bit taller than 9g servos so had to remove some of the bottom half of the fuse so the horns didn't rub, but not much. Set the fan unit 142mm back from the lip where the fuse ramps up and added some 0.5mm styrene sheet to cover the wires and esc. I cut a hole out to allow for cooling. The fan is glued in with a small blob of 5min epoxy either side so I can still get a knife in to cut it out if needs be. I've cut and sanded back the rear edge of the cheater holes to allow smoother air flow into the fan, rather than the 90degree step that was there before. This also has to be replicated on the bottom half of the fuse.
Intake fairing
For the intake fairing I've used 0.5mm styrene, hot glued into place then the join covered in electrical tape just to smooth things out as much as possible
missile rails
Covered the missile rail this eve, really makes a difference to the look of the wing. Bit fiddly but worth it.
Also started on the rear of the fuselage tried to get it done in one piece but just wrinkled, instead I've used several strips running perpendicular to the length of the fuse. Not ideal but due to the very thin nature of the covering once you step back you really cant notice the slight over lap and it just sort of looks like panel lines. I think the rest of the body will be done this way. |
fuse covering
bulid has slowed down slightly but have covered the fuselage now which worked really well, using 3 separate panels for each side , had to remove the black bits fore and aft of the cockpit in order to cover the fuse easier. These were stuck back down with double sided tape. Also have finished the wings
Fusealage underside
I cut the lower fuse into 3 sections to allow access to the fan and ESC.
4 magnets hold the middle section in place whilst the front and back sections are expoxied. In hind sight I would have mounted the magnets further from the motor possition but I think they are far enough away to avoid having any adverse affect on the motor (I hope). |
| Thread Tools | |
| Build Log FMS Mini F16 Build and Mods (alternative to Phase 3 EF16) | Si Goodchild | Foamy EDFs | 15 | Dec 06, 2010 06:00 AM |
| Video Phase 3 EF16 EDF Jet | Dynomike | Electric Plane Talk | 12 | Jun 24, 2009 10:53 PM |
| Discussion Phase 3 HP EF16 maiden . . . not pretty | Scooter04 | Foamy EDFs | 20 | Jun 09, 2008 02:54 PM |
| Sold NIB Phase 3 EF16 ducted fan jet $99 | ratedz | Aircraft - Electric - Airplanes (FS/W) | 4 | Apr 22, 2008 02:27 PM |
| Discussion Perkins Tigershark or Phase 3 EF16? | trevorvilla | Foamy EDFs | 8 | Aug 23, 2007 02:24 PM |
