Espritmodel.com Heli Air
Old Jan 06, 2011, 09:27 AM
Joined Apr 2008
RCLander large metal electric retract
Dear all,
We would like to introudce our new large metal electric retract for sharing with you. It can be handled the planes weight from 3.5 -7kg. BTW, it has been come with rotating function (45 / 90degree) to fit the planes such as P-40 & F4U. Also the nose gear is able 90 degree rotating and steering function.
You are welcome to visit our website www.rclander.com for more information.
RCLander Rotating function metal electric retract operation video.wmv (1 min 44 sec)
BRs,
Tim
Tim Wan is offline Find More Posts by Tim Wan
Old Jan 06, 2011, 11:22 AM
Spaceshuttle1's Avatar
United States, NV, Pahrump
Joined Jun 2005
Does this mean that Landers is coming out with a new F4U or P40 to install these new retracts, or are they just replacements for the larger p40 an F4U out there?
Spaceshuttle1 is offline Find More Posts by Spaceshuttle1
Old Jan 06, 2011, 04:17 PM
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Tim where can you buy them from? Pricing?
Glacier Girl is online now Find More Posts by Glacier Girl
Old Jan 06, 2011, 08:55 PM
Joined Apr 2008
Dear Glacier Girl,
You can contact our USA dealers for further arrangement. Pls visit our website lower left conrner to locate their contact list.
Thanks for your interesting of our products.
BRs,
Tim
Old Jan 07, 2011, 07:37 PM
Ldm
Ldm's Avatar
Pa
Joined Jun 2006
Tim , my question is that the struct does not have a scissor spring . So I have seen this type if gear and the wheels want to turn left and right under the pressure of landing .
The set screws that hold the struts onto the retracts tend to come loose .
Have these retracts been tested under load of a plane on landing , do you have any video ?
Ldm is offline Find More Posts by Ldm
Old Jan 09, 2011, 08:20 PM
Joespeeder's Avatar
Davison, MI
Joined Sep 2007
Hi Tim,
I am ready to order your retracts can you detail the strut options available?
I see hese options are available.
- 4mm Wire struts - Do these need a Bushing?
- Single suspension Metal Legs
- Dual suspension Metal Legs
I see several styles of single suspension legs.
In looking a the note on your site it says the single suspension legs are adjustable to two lengths of 120m and 140mm.
I also see a strut package on your site that includes a nose wheel strut but I not sure if that's available.
Could you list each style of strut available.
I need these measurements for each style of strut.
- From the end to the center of the axle or if adjustable what are those
measurements?
- Wheel Size that will fit that strut.
- Weight Range of Model it was designed for
- Wire Connector size or if a bushing is needed.
Thanks for all your help. I have been looking all over at struts and very few have the dimensions we need to know if they'll work on custom projects. After a while I get very confused
Joe
Joespeeder is offline Find More Posts by Joespeeder
Old Jan 09, 2011, 10:19 PM
Crash Test Dummy
Pilot_Tony's Avatar
Youngstown, PA 15696
Joined May 2002
Can I use this in my Airfield P-40?
Pilot_Tony is offline Find More Posts by Pilot_Tony
Old Jan 10, 2011, 08:25 PM
Joined Apr 2008
Originally Posted by Joespeeder View Post
Hi Tim,
measurements?
Joe
Dear Joe,
Attachd is some photos with illustraction for your referecne.
The wheel size range is from 55 -80mm (main gear) & 40-50mm (nose gear).
Our metal electric retract can be handled 60 -120 size and 3.5 - 7.5kg weight planes. The standard wire version is come with 4mm x 160mm with wheel adaptor holders. The 90 degree rotating function main gear set is designed for P-40 & F4U. All struts dia. size is 12mm and come with strong spring for suspension function.
If you have any question, pls feel free to contact me.
BRs,
Tim
Old Jan 10, 2011, 09:40 PM
Joespeeder's Avatar
Davison, MI
Joined Sep 2007
Hi Tim,
Thanks for your posts.
On the struts that show they are available form 100-140mm in length. Are they adjustable be the user or do we order them in the length we need?
Thanks for your help.
Joe
Old Jan 11, 2011, 08:36 AM
Joined Apr 2008
Hi Tim,
Joe
Dear Joe,
You need to mention into your order of the length size of struts.
Tim
Old Jan 24, 2011, 09:07 AM
Joined Apr 2008
Additional spare parts for RCLander metal electric retract
Dear All,
I would like to introduce our new metal axle wheels (come with PU material tires) as an option spare parts for our metal electric retract. It will be applied to our full range products struts size (30 - 80mm). Attached is initial series for CMP - T45 version for sharing with all of you.
The stocks will be ready for order after Chinese New Year holiday.
If you are interesting, pls feel free to contact with our dealers.
BRs,
Tim
Discussion RCLander new design large full metal electric retract announcement Tim Wan Foamy EDFs 24 Jan 07, 2013 04:22 PM
Sold Rclander 70mm Metal shroud with typhoon 2w-25 motor and HET 70mm Rotor TurboFanElectric Aircraft - Electric - Jets (FS/W) 3 Oct 25, 2010 07:50 PM
Video RCLander Electric Retract Gear System testing video Tim Wan Electric Plane Talk 15 Feb 13, 2010 06:18 AM
Discussion RCLander New Electric Retract Gear System Tim Wan Foamy EDFs 19 Feb 01, 2010 10:45 AM
Video RCLander Mig 17 PC version w/metal mechanical retract /gear doors system Tim Wan Electric Plane Talk 0 Jan 28, 2010 03:20 AM
