It's built entirely from 6mm EPP (grade 20L – this is the soft stuff) and a little 3x0.5mm carbon strip. The prop's in the middle and it's got a big, blunt, bouncy nose.
It's virtually immune to head on collisions with walls, floors and roof beams (we've tested this several times now!). There's no landing gear or other breakable bits sticking out (but it can still take off easily from a smooth floor due to the new fuselage shape). The prototype shown weighs 130g. You should have no problem getting a similar weight with similar equipment. Hardware Motor: Infinite A1705-2250 (17g) Battery: 2s Rhino 360mAh lipos (21g) Prop: GWS 6x3DD Servos: Waypoint W-060BB (6.6g) If you fly indoors you’ll probably have suitable cells, ESC and servos already. The motor is a little more critical because you need to end up with the right size prop for the slot. I think this Infinite motor is a very good copy of the Hyperion Z1705-11. There are other motors that will do the job but I suggest keeping motor weight below 25g. Thrust available from my setup is a little over 200g which is plenty for the 130g plane. Below are some construction pictures. It's an easy build. The only part that takes any real time is cutting out the parts. Aidan
Video
Here's some video.
This is from the start of our Monday session before we cracked out the streamers. These 3 are all the previous version which has a slightly more swept delta. I'll add plans for this version too it also flies great and some people may prefer it. I think the new one holds speed a little better in tight pitch manoeuvers. They will happily slow down to a crawl but it's mostly fast-ish flying in this video. They're a little noisy because of the slot but not as loud as the camera makes them seem. No video of some of the more lively stuff later in the session - I was too busy flying!
Well in that case it might work very well. What sort of planes will everyone else be flying?
I'd be interested in taking a look at the rules for this if you can point me in the right direction? Edit - Nevermind, I found the website So 10oz max, 800mAh and no touching the floor.....it doesn't say how the winner is judged. Is it simply last up wins? It also doesn't say if 3s packs are allowed. If they are you get an extra 50% available energy - just need to spec the motor and prop to match. I presume you'll want to weigh nearly 10oz so you have the inertia to hold your own. You could remove the "chin" if you want since touching the floor isn't allowed so a take off skid is no use. As it's not a one design competition and is going to be very aggressive it might be better to go with the previous version. It's got a smaller span but similar wing area. I think it's just a little bit more robust and will be easier to beef up. It's not quite so good on pitch response but I don't think that's as important for full contact as for streamer cutting. It would also be wise to put a strip of carbon along each LE and maybe in the fuselage too for protection. Aidan |
Joined Apr 2009
Aidan,
Looks like yall were having a blast! Can I ask a question about your elevon pushrods? They look very light. I also see an extra piece just before the servo heat shrink. Does that piece make them adjustable? I have thought about going light on some builds but have had concerns about not being able to fine tune elevons/alierons (after crashes). Thanks |
[QUOTE=Aio_1;17021226
I presume you'll want to weigh nearly 10oz so you have the inertia to hold your own. You could remove the "chin" if you want since touching the floor isn't allowed so a take off skid is no use. Aidan[/QUOTE] There's no limitation except the 10oz and 800mah. In the past I've been using the Firefly on 3S. This year I'll run 4S if I can find a low enough Kv motor. It's basically a fly what you brung, with the MS Composit Swift and Leadfeather's Firefly being pretty popular. In the past it's been last man flying wins. Unfortunately that means both surviving and having duration. Hence the quest for low Kv motor on 4S. There have been some proposals to change it from a duration finish, but the management is being mum. I wouldn't be surprised to see a change at the event. Azarr |
Aidan |
Plan for previous version
I've attached a plan for the previous version of the Imp. This is the one being flown in the video and it flies great. It took a while to get this one laid out properly and the newer one will take longer so no chance of getting it tonight I'm afraid (it's 2am!). I'll be away from home for the weekend so it'll be early next week before I can get the new one up.
Aidan |
dstrout,
The latest version is quite closely based on the "Pre-Imp" above but it's been modified as follows: Span goes from 629mm to 706mm Root chord reduced to 385mm (measured nose to aileron rear) Nose to hingeline distance reduced from 295mm to 282mm Fuselage is stretched 10mm longer (same height) Aidan |
| Thread Tools | |
| For Sale All EPP Combat ready crash resistent P-38 lightning flys both indoor and outdoor | shschon | Aircraft - Electric - Airplanes (FS/W) | 0 | Nov 24, 2008 10:25 PM |
| For Sale All EPP Combat ready crash resistent indoor P-38 lightning Outdoor OK too | shschon | Aircraft - Electric - Micro & Indoor Airplanes | 0 | Sep 25, 2008 09:45 PM |
| For Sale NIB P-38 Lightning Street Fighter indoor/outdoor All EPP Combat ready crash resistent | shschon | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 13, 2008 04:02 AM |
| For Sale NIB P-38 Lightning Street Fighter indoor/outdoor All EPP Combat ready crash resistent | shschon | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 08, 2008 09:10 PM |
| For Sale NIB P-38 Lightning Street Fighter indoor/outdoor All EPP Combat ready crash resistent | shschon | Aircraft - Electric - Airplanes (FS/W) | 0 | Feb 17, 2008 09:50 PM |
