This thread is privately moderated by wolw, who may elect to delete unwanted replies.
Old Jun 10, 2011, 03:58 PM
hobbyclub is offline
Find More Posts by hobbyclub
United States, CA, Orange County
Joined Feb 2003
Reichard Magic ALES-LMR-F5J 2.0m under 20oz AUW
Gents:
The MAGIC has arrived. Beautiful piece of engineering and building skills.
Our first shipment just came in
There are quite some very interesting changes when compared to the MAXX.
1) Tail Feathers: not built-up but made of single pieces of balsa wood with
hole cutouts to make it lighter
2) Newly designed fuselage pod. Shorter in length. 2 screws will hold the wing
with 2 aluminum pins to secure the wing LE against the fuselage.
3) Slightly longer tailboom.
4) No more pushrods. Spring loaded rudder and elevator handled by a single kevlar line.
5) No more battery/servo box. Only a half moon servos holder.
Overall we're very impressed, to say the least..!!
If you follow this link, a more detailed information can be obtained:
http://www.hobbyclub.com/product_inf...oducts_id=1226
Thanks for your time,
Alberto
www.hobbyclub.com
hobbyclub is offline Find More Posts by hobbyclub
Old Jun 11, 2011, 03:05 AM
lebenj is offline
Find More Posts by lebenj
flying is not a dream
lebenj's Avatar
Spain, CT, Cardedeu
this version looks really better!
everything wich was not so good une the MAXX (in my case ) is now corrected. lighter and longer tail and shorter noise!!!!
in mine, even with the very heavy pushrod, i had to put 8gr in my tail to get the CoG. and except the motor, everything are under the wing (RX, LIPO, ESC, altimeter, servos.....
so the magic must be better. more surface, less weight and better balanced...
lebenj is offline Find More Posts by lebenj
Old Jun 11, 2011, 03:38 AM
wolw is offline
Find More Posts by wolw
<- Balsa flies better ->
wolw's Avatar
Gustafs, Sweden
Joined Feb 2006
Does it come with spare time
wolw is offline Find More Posts by wolw
Old Jul 23, 2011, 09:57 AM
Mathelo is offline
Find More Posts by Mathelo
USA, CT, Stamford
Joined Jun 2006
Any build or flying reports on the Magic? How does it compare in use to the MAXX?
Louis
Mathelo is offline Find More Posts by Mathelo
Old Aug 22, 2011, 08:27 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
actually, with my motor configuration, i'm really not enjoyed of the climb:
and hyperion 2S 900mah lipo 45C
ESC hyperion Atlas 35A
motor hyoperion GS2213-16 (around 70gr)
prop Aeronaut 13x8, 12,5x6,5 and also 14x6, but it's still difficult for me to reach 200m in 30s....
can someone can help me to choose another 2S motor???
regard.
Benjamin
Old Aug 23, 2011, 09:05 AM
glasairdriver is offline
Find More Posts by glasairdriver
Glasairdriver
United States, IN, Lafayette
Joined Jul 2007
Louis
Here is the Magic forum:
http://www.rcgroups.com/forums/showthread.php?t=1482279
glasairdriver is offline Find More Posts by glasairdriver
Old Jan 08, 2012, 04:03 PM
skranish is offline
Find More Posts by skranish
From The Lab
Beverly, MA 01915 USA
Joined May 2001
Can anyone offer comments (based on experience, not opinion!) about the choice of servos for the MAXX? I have a kit, and I am trying to figure out what servos to use.
It looks like it was designed for D47 and possibly D60 servos. Esprit suggests HS45, which may fit, although they look a little too thick for the ailerons.
My concerns here are
1) adequate torque for control during climb
2) gears strong enough to not break under normal use.
My usual flying fields have well maintained grass, so that is all the flaps are likely to catch on.
Steve
skranish is offline Find More Posts by skranish
Old Jan 08, 2012, 04:22 PM
wolw is offline
wolw's Avatar
Gustafs, Sweden
Joined Feb 2006
I can only speak for the Vigor VS-12 I've used
Old Jan 09, 2012, 01:51 PM
cmanley_nl is offline
Find More Posts by cmanley_nl
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
@skranish
In my Maxx, I use the HS45HB servos for the flaps only (because these take the most beating) and they're about 1mm too thick for the wing. I use D47's for the ailerons, rudder, and elevator and they haven't failed me (yet). I think you should be more concerned about servo torque during high speed descents, not the relatively slow climbs. I think VS-12's are a good choice too for the ailerons and may be a safer choice than the D47's.
cmanley_nl is offline Find More Posts by cmanley_nl
Old Jan 09, 2012, 02:44 PM
Joined Feb 2003
Steve
Steve:
I'm using Airtronics 94802 Sub-micro digital (flaps).One of the best servos on the market:
http://www.hobbyclub.com/product_inf...oducts_id=1199
and Arrowind AWD-3012 Micro Digital for the ailerons:
http://www.hobbyclub.com/product_inf...oducts_id=1316
If you need any further comments, please let us know,
Alberto
www.hobbyclub.com
Old Jan 09, 2012, 02:52 PM
Joined Feb 2003
Reichard 2.5m CUMULUS ARF just landed
Gents:
Just received the first batch of 2.5m CUMULUS.
An exceptional well built model for ALES-F5J-LMR events or pure flying fun.
Empty weight: 450g (15.8oz)
Alberto
www.hobbyclub.com
Old Aug 02, 2014, 02:36 PM
skranish is offline
From The Lab
Joined May 2001
Did anyone ever figure out the appropriate downthrust/sidethrust for the MAXX. My model arrived with the nose cut for about 4 degrees of downthrust AND I found I have about 0.5 degrees between the wing saddle and the top of the tail boom. I realize that can be adjusted a bit by sanding the rear of the fuselage to adjust how it fits into the boom.. but what is the correct angle? I contacted Esprit Models, and got a much-less-than-helpful response, essentially 'set it all straight and fix it with trim'. Thoughts, anyone? Experiences?
thanks
Steve
New Product Scorpion X !!! (F5J outrunner) Marko Gala Electric Sailplanes 225 Jan 19, 2015 03:26 PM
Discussion Reichard MAXX F5J thumbhead Electric Sailplanes 18 Jun 18, 2011 07:25 PM
Sold Reichard Quatro 59" LMR w/gb-motor-servos - $100 airpilot38 Aircraft - Sailplanes (FS/W) 1 Jan 20, 2008 08:15 AM
FS - Reichard Blizzard 3500 w/ Aveox LMR 16 blumj Aircraft - Sailplanes (FS/W) 3 Mar 20, 2005 01:47 PM
