This thread is privately moderated by hobbykinglive, who may elect to delete unwanted replies.
Old Aug 23, 2011, 05:51 PM
lacemi is offline
Find More Posts by lacemi
Joined Dec 2008
Originally Posted by Gildas View Post
Hello Everybody
I am like marco and I am going to buy the PNF version of the Kinetic 800, to put my own servos, Esc and motor, but I don't find the specification of the 2226-1250 KV motor. I saw on a french forum that the lenght is 26, diameter 22 and shaft 3. Does anybody can confirm this?
I am thinking of this motor which is said to fit well the Merlin for aerobatic flights.
http://www.hobbyking.com/UNITEDHOBBI...idProduct=8141
Diameter is a little bit more than 22, it's 26. Do you think that can fit ?
No,it is a mistake to buy this engine, the shaft no is still valid.
HK besides a mistake on their website:
This is the url http://www.hobbyking.com/hobbyking/s...idProduct=2110 to a powerfull engine for our glider, but in this item said:"This is an archived page. This product is no longer available and has been replaced by a newer product.
CLICK HERE TO VIEW THE NEW PRODUCT".
If you click here you can see this:
http://www.hobbyking.com/hobbyking/s...dproduct=12919
What is the problem???
The problem is the shaft, it is diferent, it is like your enginer, the Motor mount and Prop can not be screwed.
is another enginer that can put more potent than the original?
Sorry for my English.
lacemi is offline Find More Posts by lacemi
Old Aug 23, 2011, 08:24 PM
rcflyer40plus1 is offline
Find More Posts by rcflyer40plus1
I'd rather be flying!
rcflyer40plus1's Avatar
Joined Jul 2010
I use small piece of EPP from a profile plane I built under the battery which gives a snug fit for a 460mAh in the forward compartment. CG seems about right, can glide around with or bring it in at a relatively quick speed. I did have an issue recently where I went to fly and motor sounded way to loud. Tore it down and the mounting screws had shaken use over the many flights I've put on it. Tightened down, and back in service. Just something to be aware of. I hope you have as much fun with yours as I've had with mine
rcflyer40plus1 is offline Find More Posts by rcflyer40plus1
Old Aug 24, 2011, 01:57 AM
RickenB is offline
Find More Posts by RickenB
Björkvik, Sweden
Joined Aug 2009
Elevator not parallell with the wing
The elevator and wing where easy to mount with their type of snapp in mounts, but I discovered they are not parallell to each other. I do not see anny way to adjust them. Is there any else who might have discovered the same? Will it have remarkable negative influence in flight performance?
Erik
RickenB is offline Find More Posts by RickenB
Old Aug 24, 2011, 08:17 AM
kman24 is offline
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
Erik
Mine is the same way. I have 50+ flights on mine and haven't had any issues. I have twisted the whole tail section the other way to correct it. It has helped some but it isn't totally straight yet. Just be careful when you twist the tail section because the little side spars may come loose. One of mine did so I had to reglue it.
KMan
kman24 is offline Find More Posts by kman24
Old Aug 24, 2011, 03:01 PM
RickenB is offline
Björkvik, Sweden
Joined Aug 2009
50+! Then I will feel confidence when I try to maiden tomorrow if weather permits.
Old Aug 24, 2011, 09:56 PM
brett.c is offline
Find More Posts by brett.c
Foam is where the heart is
brett.c's Avatar
Australia, NSW, Sydney
Joined Aug 2010
The tail on mine was twisted as well.
I peeled off the side spars rear of the wing and it sprung back into shape.
Obviously they were glued in under tension.
I then reglued the spars and have had no problems since.
brett.c is offline Find More Posts by brett.c
Old Aug 24, 2011, 10:31 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
Thanks, I will have to give it a try
KMan
Old Aug 25, 2011, 06:33 AM
bmsweb is offline
Find More Posts by bmsweb
bmsweb's Avatar
Australia, VIC, Melbourne
Joined May 2011
Hi Guys, Thought I would share this video of my son's Kinetics being attacked by a Magpie lol
Magpie Attacking RC Model Glider Aerial View. Kinetic 800 vs Bird KeyChain Camera (2 min 6 sec)
bmsweb is offline Find More Posts by bmsweb
Old Aug 25, 2011, 12:22 PM
RickenB is offline
Björkvik, Sweden
Joined Aug 2009
Successfully maiden today!
Wow what a feeling!
Some aileron an rudder adjustments an she flew like a bird despite the twisted elevator. Thanks for all comments about fixing it. I will definitely try it out.
Old Aug 25, 2011, 12:33 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
bmsweb - Good stuff with the magpie!!! I have the same thing with Barnswallows in my neck of the woods.
RickenB - Yeah!!!! Good job on the maiden. You have officially been initiated
KMan
Old Aug 25, 2011, 01:28 PM
mr..speed is offline
Find More Posts by mr..speed
mr..speed's Avatar
near Stgt/Germany
Joined Feb 2003
The elevator and wing where easy to mount with their type of snapp in mounts, but I discovered they are not parallell to each other. I do not see anny way to adjust them.Erik
Heating up and bend could help.
mr..speed is offline Find More Posts by mr..speed
Old Aug 25, 2011, 02:23 PM
lacemi is offline
Joined Dec 2008
increible jajajjaajaj COOL VIDEO
Old Aug 25, 2011, 02:49 PM
bmsweb is offline
bmsweb's Avatar
Joined May 2011
Thanks Guys, we had a lot of fun . . well not sure if my son enjoyed having a Magpie chase his plane most of the time.
I was just wondering has anyone purchased a Kinetics that was straight? Mine was bent like a banana straight out of the box. I should post a picture of its Ailerons Neutral Trim! Looks like it should do a roll as soon as you throw it lol
Old Aug 27, 2011, 06:15 PM
lacemi is offline
Joined Dec 2008
my modifications and my mistakes.
I put my bad shopping for other newbies like me do not say the same mistakes
Click into de picture to see big size.
The Kinetic, no t had a rudder casing pipe, I had to use shrink tube two twice, one hot and one not hot so that one fits inside the other, not find a better solution, I am newbie
Increase with the help of a knife the size for the servos (1,2kg and 6gr de weight), these are Turnigy TGY-1600A:
in this position does not fit, it is also very heavy:
Engineer is a horrible mistake, is useless, should have the axis on the other hand:
1550 and 1000 and 40A esc
It is very thin:
It is very big:
can anyone advise a more powerful engine than the original is suitable for the kinetic and that fits easily? (in HK)
As you can see my Engine is not worth.
Thanks.
Old Aug 31, 2011, 04:59 PM
lacemi is offline
Joined Dec 2008
anybody answer what enginer ???
Discussion The 130" Kinetic DP! sll914 Dynamic Soaring 38 Jan 08, 2016 06:30 PM
Discussion Cool Kinetic Pictures daboz Dynamic Soaring 12 Apr 10, 2011 10:26 AM
Discussion New H-King ESC? (not SS) dude_109 Power Systems 31 Dec 20, 2010 12:45 PM
Discussion Kinetic DP 130 Maiden Video 403mph!! daboz Dynamic Soaring 9 Oct 27, 2010 04:10 PM
For Sale Kinetic 50 with OS 50SX-H mundo330 Aircraft - Fuel - Helis (FS/W) 1 Oct 10, 2010 07:15 PM
