This thread is privately moderated by hobbykinglive, who may elect to delete unwanted replies.
Old Nov 16, 2012, 03:54 PM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
The Kinetic is back on HK's global site for $67.90. http://www.hobbyking.com/hobbyking/s...ider_PNF_.html
"LIMITED TIME ONLY - WHILE STOCKS LAST"
Better grab one while you can. I can see why MPX were so Pi**ed off with HK as they even copied MPX's excellent horn design.
Andy
headlessagain is offline Find More Posts by headlessagain
Old Nov 16, 2012, 06:42 PM
MRN is offline
MRN
Find More Posts by MRN
MRN
Sunnyvale, CA
Joined May 2002
The Kinetic 800 appears to have come from the Multiplex factory. It appears to be identical to the Merlin.
It's possible that Multiplex sells some of their less popular planes to Hobby King.
Read the thread. The Kinetic and the Merlin both have a sudden stall characteristic that leads to a short life.
MRN is offline Find More Posts by MRN
Old Nov 25, 2012, 09:05 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
Parts are NOT interchangeable with the Multiplex Merlin. It's not from the same factory, it's a copy.
jtaylor996 is offline Find More Posts by jtaylor996
Old Dec 26, 2012, 12:35 PM
TheSelf is offline
Find More Posts by TheSelf
Los Angeles, CA
Joined Jan 2011
Originally Posted by kiviglider View Post
I think I found the manual for ESC. It was not the first hit on Google but I had nothing better to do this evening. It's in here
I followed beeps in programming table and they made sense. I turned brake on and off a few times and then set motor start to very soft. I feel it will lessen wear to propeller joints.
Just built my kinetic 800-been wiaitng to be built for over a year now- after binding ( with a spektrum dx6i)- on turning it on the throttle is turning the prop at a low rate but nevertheless still turning with the throttle stick on the dx6i at a minimum- ive tried to put the ESC into programming mode- but dont seem to be able to- can you only program the ESC ( by putting the throttle stick to max, turning on the TX and then plugging the lipo to the ESC , RX, motor combo) [I]after[I] binding or before binding? Any other ways to set the max and minimum (zero) throttle levels? ( as a workaround I've trimmed down the throttle till the prop stops turning with the stick in the lowest position though of course not ideal as the max throttle of course is reduced as a result)- thank you for any feedback
TheSelf is offline Find More Posts by TheSelf
Old Dec 26, 2012, 12:40 PM
Registered Crasher
Joined Feb 2011
Trim the throttle channel all the way down.
Old Dec 26, 2012, 12:42 PM
Registered Crasher
Joined Feb 2011
The ESC should auto calibrate for range. Getting that last bit of full throttle isn't very important, anyways.
ESC programming will need to be done after binding.
Old Dec 27, 2012, 01:56 AM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
TheSelf,
On a lot of ESCs you set the throttle range to match your transmitter by moving the stick to full throttle before you switch on the plane / plug the battery in, wait for the first beep and then immediately close the throttle (move the stick all the way down).
I don't have a Kinetic 800 so I don't know if that works with the ESC you have.
Andy2No is offline Find More Posts by Andy2No
Old Jan 02, 2013, 10:09 AM
kenstogie is offline
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Originally Posted by Andy2No View Post
TheSelf,
I seem to recall this is the case, there was something about trimming the throttle all the way down prior to doing this other wise the esc disarmed thinking the throttle was on inadvertantly. Maybe the Swift maybe this not sure. worth a try but hold on to it tightly incase it goes full throttle.
kenstogie is offline Find More Posts by kenstogie
Old Jan 02, 2013, 09:06 PM
TheSelf is offline
Los Angeles, CA
Joined Jan 2011
thanks guys for your feedback- still haven't managed to program the ESC - in the end I just gently trimmed down the throttle till it stopped turning with teh TX stick at the minimum-fortunately it didn't seem to affect the top/max allowed rpm of the motor- flies beautifully, especially on 3S! think I'll add spoilerons as it does come it quite 'hot' and would like to try flying from my back yard with limited landing space - so being able to slow it down will hopefully help..
Old Jan 04, 2013, 12:14 PM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Yea 3s s the way to go or maybe 4s It's a great flyer can go slow or fast and handles very well. I don't think I ever flew it on 2s might be a good slower flyer on 2s not sure about the COG.
Old Jan 04, 2013, 02:09 PM
Registered Crasher
Joined Feb 2011
Good luck finding a motor that fits in this plane that can deal with 4s voltage. Even if possible, the cooling is pretty bad in there, so even 3s can be marginal at times.
In my experience the lighter weight of running 2s on this plane really helps the flying characteristics. I didn't notice all that much difference in the power, just a big increase in heat after finishing the flights... but that was a long time ago.
Old Mar 08, 2013, 02:16 PM
Wavewash is offline
Find More Posts by Wavewash
Joined May 2008
Missing Hatch
If anyone is throwing out their Kinetic 800. Could you please send me the battery hatch door? I love my little Kinetic but lost the hatch door awhile back and have had to tape over the battery to keep it in the plane. I'd appreciate any help and would gladly pay for shipping/postage.
Thanks.
Wavewash is offline Find More Posts by Wavewash
Old Mar 08, 2013, 03:20 PM
Registered Crasher
Joined Feb 2011
Let me see if I have a spare door at home. I think I saved it from a nasty wreck, but I'm not sure what condition it's in. I'll check and let you know. Where are you located?
Old Mar 08, 2013, 04:39 PM
Wavewash is offline
Joined May 2008
I'm in Boston. Thanks for looking!
Old Mar 08, 2013, 06:56 PM
Registered Crasher
Joined Feb 2011
I looked all over the place and couldn't find it.
I remembered the battery bay (what the hatch clicks in to) didn't survive the crash, but I was hoping the hatch did. I guess it didn't, and got chucked.
Discussion The 130" Kinetic DP! sll914 Dynamic Soaring 38 Jan 08, 2016 06:30 PM
Discussion Cool Kinetic Pictures daboz Dynamic Soaring 12 Apr 10, 2011 10:26 AM
Discussion New H-King ESC? (not SS) dude_109 Power Systems 31 Dec 20, 2010 12:45 PM
Discussion Kinetic DP 130 Maiden Video 403mph!! daboz Dynamic Soaring 9 Oct 27, 2010 04:10 PM
For Sale Kinetic 50 with OS 50SX-H mundo330 Aircraft - Fuel - Helis (FS/W) 1 Oct 10, 2010 07:15 PM
