Old Oct 10, 2001, 12:07 PM
electricrcflyer is offline
Find More Posts by electricrcflyer
Corvallis, OR
Joined Mar 2000
Help: EDF installation on HobbyLand Me-262
Anybody flying the aforementioned? How did you install the
MF480? Would appreciate any bulding tips, too.
Thanks.
Ron
electricrcflyer is offline Find More Posts by electricrcflyer
Old Oct 10, 2001, 06:19 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
ME-262 fan installation
What I did was clean up the inlet lip to be flat on the inside of the nacelle. I cut the flanges off the mini-fan unit and slipped in the nacelle at the wing mount area. Once I was happy with the way the fan unit sat on the lip. I used wooden glue sticks with double stick tape to keep fan aligned. I glue the fan unit to the lip with Zap-A-Dap-A-Do. Remove any excess glue from inside of fan. After the cured I poured a small amount of two part foam around the fan/nacelle joint. This expanded and locked the fan in place. Used this method in a number of other jets with great success. E-mail me with any other questions.
Bob Ruff
bruff is offline Find More Posts by bruff
Old Oct 11, 2001, 11:42 AM
uncljoe is offline
Find More Posts by uncljoe
Col.Hooligan Air Force
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
hobby world 262
Ron
The plane is a LEAD SLED ! I also used double sided tape to secure the fans and tried to clean the intake lip , its a DOG with retracks, perhaps it is better without LG. I ve used varrious cell counts and size all flights are Short, best flights achived with a "kluge" catapult . when you acheive take off speed
it jumps off (nose hi almost like a stall) max power is needed at all times. motors 1114's, kont.controller :
uncljoe is offline Find More Posts by uncljoe
Old Oct 11, 2001, 12:53 PM
Corvallis, OR
Joined Mar 2000
Very interesting...
I plan to power mine with 2 Aveox 1114, 2 Kontronik Smile 40-6-18, and 2 10-11 cell packs of 2400/3000s. What do you think of this power set-up? Would it be better to just use one sensorless controller (w/ a 70-amp rating) and 1 11-12-cell pack for the interest of weight saving?
I guess I'll have to give up the landing gear idea...
Thank you Mr. Bob Ruff and Uncljoe. I may have to e-mail you directly for some more questions.
Ron
Old Oct 11, 2001, 01:06 PM
p471701
p471701
Guest
n/a Posts
ron: if you went with cp1700's you'd save 12oz. on a 20 cell set up.might make the difference between a soso flyer and one with some zip to it..................gregg
Old Oct 11, 2001, 03:00 PM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
ME-262
Powering mine with 2 each Astro 05 sensorless with Kontronic 3SL-40-6-18 using 12 CP1300 per motor (24 total). This provides 32,000 RPM and 20 AMP current draw. Also using fixed landing, saves about 14 oz in weight.
Old Oct 11, 2001, 11:29 PM
uncljoe is offline
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
Ron
I used a single Kontronic 70-6-18 controller along with 2 1114
Bob Ruffs 262 is the way to go with fixed gear the weight saving
should make for MUCH Longer flights & more relaxing.
Later
Joe
Check EJF web page for a few of photo's of mine under construction
Old Oct 12, 2001, 03:57 PM
marshall is offline
Find More Posts by marshall
Brookville, Ohio
Joined May 2000
Uncljoe, You describe the Hobbyland 262 as a lead sled. What is the weight of yours, with the retracts? Thanks, Paul
marshall is offline Find More Posts by marshall
Old Oct 12, 2001, 11:10 PM
uncljoe is offline
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
Weight of 262
Paul
weight 70 OZS. WITHOUT BATTERIES
wing 2 LBS 12 OZS
FUS 1 LB 10 OZS
Old Oct 15, 2001, 11:26 AM
maserer is offline
Find More Posts by maserer
Germany
Joined Jan 2000
Hello,
my 262 is the same size, but built with wood. It has 8RC2400zapped an 2 MF480 working with Plettis 200/20/5.
I talked with an other owner and he said that flying with 10 cells (with a 200/20/6 setup) makes the plane critical in flight.
www.maserer.de
maserer is offline Find More Posts by maserer
Discussion Any news on the FSK Me-262? Airplane boy Foamy EDFs 103 Oct 27, 2006 11:57 AM
Discussion Hobbyland Me-262 with Retracts? Jim Ryan Electric Ducted Fan Jet Talk 16 Jan 28, 2006 01:50 PM
Need help with the Hobbyland ME-262 Art Newland Electric Ducted Fan Jet Talk 22 Nov 25, 2005 03:02 AM
Hobbyland Me-262 kit FT electricrcflyer Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2002 03:23 PM
HobbyLand Me-262 for Twin MF480 electricrcflyer Aircraft - Electric - Airplanes (FS/W) 1 Nov 15, 2001 03:28 PM
