Old Jan 04, 2011, 10:26 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Build Log
IBCrazy's Minion - The ultimate FPV plane
Despite not being done with my Spirit FPV plane, I decided to start a new build. This one is the Minion. This is an upscaled version of my Wraith FPV plane.
The Wraith has been a stellar performer as it flies for almost 20 minutes on a single 2250 3S Lipo and can sustain a 55 mph flight for 11 minutes at WOT with enough carrying capacity for another battery if needed. Add to that the fact that the plane is nearly indestructible as I wreck it almost every other flight and it still flies great.
So now I am upscaling it. The Wraith isn't exactly stable. It is quite maneuverable and therefore twitchy so low altitude flying is always hair raising. I want a more stable platform that I can load up with batteries for long duration flights and still skim the ground and tree tops. However I also want to keep the durability and maybe add a bit more speed to it and possibly landing gear as well.
While I don't expect it to be as durable as it's predecessor, I expect that simple bumps and tree hits will leave it unharmed.
The Wraith V2 VS cement pole:
FPV slalom Wreck (2 min 37 sec)
IBCrazy is offline Find More Posts by IBCrazy
Old Jan 04, 2011, 10:34 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Cutting the wing
The wing is again made of EPP foam. This will be laminated with 7 mil laminating sheets for stiffness. I used a USA 22 airfoil for a good balance of lift to drag. The wing is swept forward to help shorten the tail booms and control tip stalls.
I used two fiberglass spars to stiffen the wing. The tail booms will lay across them which will hopefully help resist the wing's tendency to flex under the torsional load. They will be embedded in the top instead of the bottom. I will also be shortening them once I figure out what length I want them.
The wingspan is 62" with a central chord of 10.25" and a tip chord of 8". This gives me a wing area of 3.9 square feet. That means that this plane will do well if the final weight is between 3 and 5 lbs. That should be easy enough to do.
-Alex
Old Jan 04, 2011, 10:39 PM
Po73 is offline
Find More Posts by Po73
Thou who know not
Po73's Avatar
USA, MI, Mason
Joined Jul 2010
Nice foil! *Chants praise be all be crazy*. All joking aside, looks promising. Might be one to keep around you busy body.
Po73 is offline Find More Posts by Po73
Old Jan 04, 2011, 10:45 PM
SamB125 is offline
Find More Posts by SamB125
Fly it like you stole it!
Rosamond,Ca
Joined Jun 2008
dang you never stop building do you! good job
SamB125 is offline Find More Posts by SamB125
Old Jan 05, 2011, 04:23 PM
rawlmark is offline
Find More Posts by rawlmark
Who done it?
rawlmark's Avatar
Erie, CO
Joined Oct 2010
Subscribed
rawlmark is offline Find More Posts by rawlmark
Old Jan 05, 2011, 05:42 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
Thread title said "IBCrazy's Minion"- So I clicked on it thinking you were going to start mass-producing antennas...
Looks awesome! I'm definitely going to be watching.
Kmart is offline Find More Posts by Kmart
Old Jan 05, 2011, 09:19 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Wing spars and booms installed
Tonight I finished installing the spars and installed the booms. I used fiberglass arrow shafts for these parts. Thanks to Trappy's RiteWing thread, I found that using a modified soldering gun is an excellent way to cut a channel in the foam. It sure beats melting it down with a soldering iron. The tip is made from music wire. The current running through the wire heats it up and it melts out a nice channel for the spar.
Now to do the covering.
Old Jan 05, 2011, 09:22 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I could use some of these little guys to help me with the antenna building...
Old Jan 05, 2011, 09:59 PM
Wise_Man is offline
Find More Posts by Wise_Man
Bolingbrook, IL
Joined Jan 2009
Alex,
Where do you get the fiberglass tubes/shafts, and what is the diameter?
Great job by the way.
Wise_Man is offline Find More Posts by Wise_Man
Old Jan 05, 2011, 10:54 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Lol awesome video, did you jump when you hit the pole from being startled? I sure would have.
Nice looking bird.
airbagit13 is offline Find More Posts by airbagit13
Old Jan 05, 2011, 11:49 PM
rawlmark is offline
Who done it?
rawlmark's Avatar
Erie, CO
Joined Oct 2010
Originally Posted by Wise_Man View Post
Alex,
Not to speak out of turn... but I seem to remember him saying he bought a bunch of fiberglass arrows from Walmart a while back that he's been using. Seemed like a really good idea at the time which is why I remember.
Old Jan 06, 2011, 01:21 AM
etman is offline
Find More Posts by etman
Flying with the eagles
etman's Avatar
Eagle's nest
Joined Nov 2008
Despicable ME....
etman is offline Find More Posts by etman
Old Jan 06, 2011, 06:29 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Nice looking bird.
Admittedly I winced and jerked my head to the side. I was pretty immersed under the hood. That pole snuck up on me.
Oddly, that plane has been wrecked at least 6 more times since then and still flies great.
Old Jan 06, 2011, 06:31 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Carbon fiber and fiberglass arrow shafts can be found all over the place at the end of hunting season for a fraction of the cost of carbon spars at the hobby shop. WalMart had them on sale for $2.50 each
Old Jan 06, 2011, 06:36 AM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
Where do you get the epp? I'm tired of using home depot insulation.
bracky72 is offline Find More Posts by bracky72
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 358 Yesterday 12:20 PM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 459 Mar 30, 2016 06:38 AM
New Product IBCrazy's inexpensive DIY FPV kits! IBCrazy FPV Talk 78 Apr 16, 2014 02:04 AM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
Build Log IBCrazy's Vampire FPV project IBCrazy FPV Talk 28 Mar 05, 2010 04:06 PM
