Old Apr 14, 2011, 10:33 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
@Sergey~ Looks like I will be coming out on Saturday where are you camped out?
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Apr 15, 2011, 02:38 AM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Originally Posted by Highfly! View Post
Do you know what kind of possibilities exist to print on vinyl?
There are several kinds of vinyl that can be printed on. You need special equipment though... The tail of my 737 was done in that way
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Apr 15, 2011, 11:09 PM
Ming is online now
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
Three more choice.
Ming Lou
Ming is online now Find More Posts by Ming
Site Sponsor
Old Apr 16, 2011, 04:09 AM
ernie69_2000 is offline
Find More Posts by ernie69_2000
Senior Technical Lecturer
ernie69_2000's Avatar
United Arab Emirates, Abu Dhabi
Joined Jan 2007
Aircraft
Hey Ming,
Where do you get your side views for the aircraft, or do you make them.
I'm after the views for the RAAF 2SQN Wedgetail.
ernie69_2000 is offline Find More Posts by ernie69_2000
Old Apr 16, 2011, 07:04 AM
scottd9990 is offline
Find More Posts by scottd9990
scottd9990's Avatar
United States, NC, Charlotte
Joined Jun 2009
737
Hi guys! I just ordered my 737 kit and looking forward to flying one of these jets. I also have the A380 from HK finished in Quantas Airlines so this one will be adding to my fleet. Ming, send me a good one please! Thanks for all your support on here. I have been reading this thread alot and seems that you support the hobby much better than most kit makers.
I have not decided what airline to make the 737 yet. I ordered the basic kit with retracts and plan to install the following:
2x Delta-V 15 69mm EDF Unit (EFLDF15)
2x BL15 Ducted Fan Motor, 3600Kv (EFLM3015DF)
2x 50A Controllers
1x 5000ah 3cell batt (I also have several 2350ah 4c batts) thinking I could run two if needed.
Will this set up work ok?
Thanks for all the great setup info on here!!!
Scott Davis
Concord, NC
scottd9990 is offline Find More Posts by scottd9990
Old Apr 16, 2011, 07:41 AM
Ming is online now
Ming's Avatar
Hong Kong
Joined Jun 2002
Hey Ming,
We made it.
2x 50A Controllers
Davis
Your power system is perfect!
3S is good enough.
Ming
Site Sponsor
Old Apr 16, 2011, 11:27 AM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Progress
entire model is Poly glassed , begining to paint , also if any one is instrested , the tail mod's to put the servos in side the fuse .
I made a small hatch for service and adjustments , I hopeing to done
ready to fly 2 in more weeks
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Apr 16, 2011, 01:54 PM
scottd9990's Avatar
Joined Jun 2009
Nice!!
Fill me in on how you glassed the airframe. I have one on order and was thinking of glassing it as well. How did you do it?
Thanks!!
Scott
Old Apr 16, 2011, 02:18 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
scottd9990
well what I did is call Polyglassing , which is a simpler way
of covering foam , it keeps the model from getting the hanger
rash /small dings and dent's and can be made to give a glass like finish
what it is is miniwax Water based Polycrylic and tissue (silkspan)
ployglass.wmv (3 min 2 sec)
Old Apr 16, 2011, 05:15 PM
Flexserve is offline
Find More Posts by Flexserve
Avoid The Ground!
Flexserve's Avatar
United States, FL, Tampa
Joined Sep 2008
Originally Posted by Ming View Post
We made it.
Davis
3S is good enough.
Ming
Ming I want to run 10,000 Mah of 3s (5000 Mah X2) What is recommended CG for this type of configuration? I want to stay in air longer.
Flexserve is offline Find More Posts by Flexserve
Old Apr 16, 2011, 06:05 PM
scottd9990's Avatar
Joined Jun 2009
pulsery2k1
[QUOTE=pulsery2k1;17985801]scottd9990
That looks easy enough to complete. My only question is once completed. What paints can be used? Am I still limited to only paint that will not eat foam?
What paints are you guys using? On my A380, I painted with Plasticote from Lowes, but could not mask off anything without lifting the first layer of paint back off. Makes it hard to get a great finish if you can't paint more than one color. Looking for ideas???
Thanks!!!
Scott
Old Apr 16, 2011, 06:48 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
scottd9990
once polyglassed you could use most paints ,I used water based
paints
as far as masking , no problem the undercoat will not lift
below is my dc-3 done the same way - I painted the white then
the blue and got clean lines with no lifting or peeling.same with the
silver and the black on the wings.
tamiya, testor's or other will work but on a large model ,I used
the latex(water based) sample from home depot $2.99 for a large
jar and they will match any color
Old Apr 16, 2011, 07:24 PM
Ming is online now
Ming's Avatar
Hong Kong
Joined Jun 2002
I am not suggest to use 10000mAh battery.
This is too heavy for take off, flying and especially landing.
Please use max 3300mAh X 2 pcs or one pcs 5000mAh.
Ming
Site Sponsor
Old Apr 16, 2011, 07:33 PM
scottd9990's Avatar
Joined Jun 2009
Painting, Thanks!
Originally Posted by pulsery2k1 View Post
scottd9990
paints
Thanks Pulsery2k1!! That's great info. I will give the polyglass a try on my 737. I don't care for the foam look and really hate hanger rash and dinks on my planes. Great Info and thanks!
Scott
Old Apr 16, 2011, 09:02 PM
swarick is offline
Find More Posts by swarick
Stay Thirsty My Friends
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
SWA 737 Update
ALL 737 Fans,
Here are some pictures of my Southwest airlines 737. Due to some last minute radio problems my maiden may once again have to be rescheduled.
But in the meantime enjoy the pix. NOTE: The dark "smudging" at the aft fuselage joint is really a slight difference in the thickness of the gloss topcoat. It looks much nicer in person.
Rick
swarick is offline Find More Posts by swarick
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
