Old Jan 09, 2011, 12:14 PM
swarick is offline
Find More Posts by swarick
Stay Thirsty My Friends
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
Ming,
Did you have to prepare the foam in any way prior to using the Tamiya paints?
Rick
swarick is offline Find More Posts by swarick
Old Jan 09, 2011, 12:16 PM
Rookie2008 is offline
Find More Posts by Rookie2008
Rookie2008's Avatar
Southern California
Joined Mar 2010
Ben I found it at the LHS but here is A link in the U.S
http://www.tamiyausa.com/paints/
Rookie2008 is offline Find More Posts by Rookie2008
Old Jan 09, 2011, 12:19 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Swarick, when I asked Ming if you have to prep or sand the plane he said no just paint it. Use Tamiya TS as he used it on his other plane. But make sure you test a piece because from what I hear every color reacts different?
Old Jan 09, 2011, 12:20 PM
swarick is offline
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
Ming,
What kind of control throws did you fly your prototypes with?
Rick
Old Jan 09, 2011, 12:23 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
I have been considering covering my 737 with liquid sheeting from Wowplanes.com
Should give it a solid surface ideal for painting and to avoid dents and scratches
Any thoughts guys?
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Jan 09, 2011, 12:50 PM
SJ is offline
SJ
Find More Posts by SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
Does it work on EPO.....guess you will find out :-)
Please try to weigh the parts before and after.
Got yours from lindinger yet ?
SJ is offline Find More Posts by SJ
Old Jan 09, 2011, 01:33 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Any thoughts guys?
Ben_E
The only one I've ever seen have decent results with that is the owner of Wowplanes himself. It is very sensitive to humidity and temperature at the time of application.
Don't forget you can use low-temp covering like Econokote. Also, many have had good success using sign vinyl. This is available in many more colors than Econokote but it does not shrink. You actually have to stretch it.
The 737 shoud be fairly easy to cover....
chalmrast is offline Find More Posts by chalmrast
Old Jan 09, 2011, 01:39 PM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
OK! I have another project that I will test it on to get the hang of it. My Windrider A380 is covered with brown paper and white glue, lots of work. I think I'll stick to spraypaint. Sign vinyl is rather heavy, so I only use it for decals.
Ben_E
Old Jan 09, 2011, 02:16 PM
Fotor is offline
Find More Posts by Fotor
*** gravity sucks ***
Fotor's Avatar
Netherlands
Joined Mar 2007
I haven't. Waiting anxiously......
Fotor is offline Find More Posts by Fotor
Old Jan 09, 2011, 03:14 PM
pulsery2k1 is online now
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
one of the best way's to cover is WBPU and tissue
it can be applyed quickly and gives excelent results add very little weight
but yet is strong enough to avoid dent and dinks
fiberglass is better, but for foam I belive this is better because if
you damage fiberglass it much harder to fix then this,
with the tissue it sits down on the foam so you don't loos detail
and on foam (epo and alike ) the paint stick's so you can do
masking for more colors
very easy to do add almost no weight:
ployglass.wmv (3 min 2 sec)
pulsery2k1 is online now Find More Posts by pulsery2k1
Old Jan 09, 2011, 07:00 PM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
http://www.youtube.com/watch?v=JPBrpKrk7Oo
THANKS FOR SHARING...
Great tutorial for those who's never done one.
I wonder if you'd be able to paste a link of those 3 materials basic materials you used to keep us started.
Just want to make sure that I don't pick-up the wrong one, trying your technique.
Thanks again
Spyro37 is offline Find More Posts by Spyro37
Old Jan 09, 2011, 07:12 PM
_Sergey_ is offline
Find More Posts by _Sergey_
Ugly planes do not fly
_Sergey_'s Avatar
United States, MA, Boston
Joined Mar 2007
Lights
Originally Posted by Spyro37 View Post
Sergey could you kindly tell me where you got your COOL navigation lights.
I made them myself. It was fun project!
The lights controller is based on PIC microcontroller with four transistors to handle five 1W LEDs (two red and three white 200 ma each) and fourteen 10,000 mcd regular LEDs, (20ma each). Three input channels from Rx (Throttle, Gear, Flaps) and three output channels to LEDs.
Here is the details with pictures: http://www.rcgroups.com/forums/showt...8#post16580835
I am planning to make similar board for 737. Only instead of cool white LEDs use warm white for landing lights. They look more realistic. Cool white is too blue for lights but fine for strobes.
_Sergey_ is offline Find More Posts by _Sergey_
Old Jan 09, 2011, 07:28 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Spyro37
I used Miniwax polycrylic- you can buy this at almost any hardware
paint store.
I use Sig Silk span
which come' in 3 grades
sigst001 light
sigstoo2 meduim
sigst003 heavy
these can be purchased from sig or tower hobby
the last the val-spar can be purchased at craft ,paint- home depot
but remember you can also use elmers mixed 50/50 with water instead
of polycrylic
some and I also use craft store paper-
and the clear coat you can use many diffrent brand's of waterbased
acrylic one of my favorites is Future floor wax
so you don't need to spend alot to get good results
Old Jan 09, 2011, 11:50 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
Spyro37
paint store.
I use Sig Silk span
sigst001 light
sigstoo2 meduim
sigst003 heavy
of polycrylic
Great, I will bookmark this too, and try "glassing" a couple of my planes.
Spyro
Old Jan 10, 2011, 03:48 AM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
Wow, that work of yours must be something related to what you do for a leaving. That was a THUMBS-UP!
Now, I don't have any access on programing ICs or transistors to implement codes on PIC microcontroller project module.
I had one until it started smoking on my science project I was working on
Just kidding.
Those Foil wrap was a great idea too...
I wonder if you'd be willing to sell me a couple of PIC modules, or do I have to go back in my science room?
-Spyro
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
