Old Mar 07, 2011, 11:41 AM
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
Originally Posted by Ben_E View Post
Working on my motor installation. I have given this some thought. In most of my planes I have had the possibility of changing motors and fans, and I would like to have it the same way on my 737 as well.
I will mount the EDF as you see in the pictures and glue the lower part of the engine pod at 3 points with epoxy. I will also use the self adhesive vinyl to cover the gap between the two pieces. This will allow me to change fan, housing and motor without too much hazzle.
Ben_E
Hey do u have any numbers on those CS 70mm?
jet-ster is offline Find More Posts by jet-ster
Old Mar 07, 2011, 12:46 PM
Ugly planes do not fly
_Sergey_'s Avatar
USA, GA, Alpharetta
Joined Mar 2007
Just got back from vacation and had to catch up lots of posts. Wow! You guys rock! Very nice planes and great job done!
There was question about glue. I am going to use 3M77 to glue together fuse and other parts. It is in a spray can but can be sprayed into a container and applied with a brush. Works like contact cement, flexible and has no weight.
Here is something I did while on vacation and it is somewhat related to the topic since there is 737 take off in the video as well. Hope you enjoy
St. Maarten airport (5 min 45 sec)
_Sergey_ is offline Find More Posts by _Sergey_
Old Mar 07, 2011, 01:12 PM
_Sergey_'s Avatar
USA, GA, Alpharetta
Joined Mar 2007
UA livery
Very cool livery I saw a few days ago.
Old Mar 07, 2011, 03:11 PM
*** gravity sucks ***
Fotor's Avatar
Netherlands
Joined Mar 2007
Anyone dares to try the Kulula schemes?
Fotor is online now Find More Posts by Fotor
Old Mar 07, 2011, 04:06 PM
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Originally Posted by Rookie2008 View Post
That's a Great Idea Ben, I was thinking about that on another plane. But it still seems like a lot of work removing the EDF.
Yea, but it's possible without ruining the plane
No. What numbers did you have in mind, most is in the tread above
This evening I'm at my girlfrends place, and I have made covers for the fuse, wings and tail!
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Mar 07, 2011, 05:38 PM
Stay Thirsty My Friends
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
Ok you all, here is just a small sample of the progress so far on my 737. Fuselage will be done tomorrow then assembly can begin.. All parts will be sprayed with a sealing clear gloss coat once I'm done.
Rick
swarick is offline Find More Posts by swarick
Old Mar 07, 2011, 05:51 PM
_Sergey_'s Avatar
USA, GA, Alpharetta
Joined Mar 2007
Rick, that looks very nice! What paint are you using?
Those charcoals must be to speed up drying?
Old Mar 07, 2011, 06:09 PM
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
They are Faskolor paints applied with an airbrush.
I am NOT the artist. A gentleman named Dante at my local hobby shop is painting it.
Rick
Old Mar 07, 2011, 06:16 PM
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
Ben_E
Just havn't had any real info on the CS 70mm, but I think the CS 90mm are pretty good other then not coming balanced.
Danny
Old Mar 07, 2011, 07:01 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
SWARICK, its coming along nicely.
Rookie2008 is offline Find More Posts by Rookie2008
Old Mar 07, 2011, 07:58 PM
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
I've got to say I think outsourcing the painting is quite a good idea. SWA looks good- kudos to your painter.
Doug W is offline Find More Posts by Doug W
Old Mar 07, 2011, 09:13 PM
Bermuda, Pembroke, Hamilton
Joined Aug 2010
I'm probably going to get a few frowns with this question however....
Would it possible to modify the Windrider 737 with two glow engines as a propeller rather than DF?
My reasoning for this is because i dont like LiPo's and and can't afford a turbine.
tom.e.denton is offline Find More Posts by tom.e.denton
Old Mar 07, 2011, 09:30 PM
Joined Dec 2007
HEY MING, What about this decal
http://www.flightglobal.com/blogs/fl...del-adorn.html
greggk is offline Find More Posts by greggk
Old Mar 07, 2011, 09:41 PM
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
greggk
if ming can't try here
http://www.callie-graphics.com/
tom.e.denton
this is mostly foam , could you use 2 nitro motors ? yes but I have
flown nitro twins and I would never do it again , new lipos and way
better then just a couple of years ago.
you would need to reinforce the air frame adding weight , now it
has a fairly light wing loading , makeing it nitro would ruin
mings wounderful 737 model . but just my opion
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Mar 08, 2011, 12:09 AM
Screw the wind, let's fly!
Naval Warfare's Avatar
Lawrenceville, Ga
Joined Feb 2008
Rick
will air tran become southwest or the other way areound?
Naval Warfare is offline Find More Posts by Naval Warfare
Discussion Windrider Boeing 737 Ming Scale Electric Planes 628 Mar 30, 2013 07:20 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 44 Jan 06, 2011 07:47 PM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
