Old Mar 06, 2011, 12:53 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Originally Posted by Ming View Post
Ben
Sure you can feel relax on your 737 maiden flight(when?).
Ming Lou
Thursday 17th of march, weather permitting
at this place (in the video) 450m of runway should be enough, even if it is easy to land the 737...
skyfun from hobbycity (1 min 55 sec)
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Mar 06, 2011, 12:58 PM
Highfly! is offline
Find More Posts by Highfly!
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
Ben, is this the standard setup from HK?
All that snow and ice.. Now I know why I left Europe and moved to California!
Highfly! is offline Find More Posts by Highfly!
Old Mar 06, 2011, 01:28 PM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
My setup is the setup recommended by Ming, and that comes with the kit (if you select that option.
Ben_E
Old Mar 06, 2011, 02:23 PM
Highfly! is offline
Highfly!'s Avatar
Joined May 2007
Ben, sorry I meant standard HK setup for the skyfun..
I will be ordering my 737 soon and will go for a KLM livery.
Old Mar 06, 2011, 02:27 PM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Oh! I really don't know, but in the comments on Youtube the setup is mentioned.
KLM is nice! I have a KLM 777 hope that the 737 flies just as nice
Ben_E
Old Mar 06, 2011, 02:46 PM
Highfly! is offline
Highfly!'s Avatar
Joined May 2007
That 777 looks way cool in the air!
I am finishing now a Baron 58 using the colors of the KLM flight academy. The setup includes also a real sound system to simulate engine startup/shutdown at a whopping 40W!
When done, the 737 will be next
Old Mar 06, 2011, 11:00 PM
Doug W is offline
Find More Posts by Doug W
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
Does anyone have a simple wiring diagram they could post showing the layout with two motors, two escs, two lipos and a BEC for the 737 all connected to the RX? I am in this case, assuming a BEC would be recommended as a fail safe for the RX.
Thanks.
Doug W is offline Find More Posts by Doug W
Old Mar 06, 2011, 11:09 PM
Doug W is offline
Doug W's Avatar
Joined Jul 2010
Also, I have decided finally (with my airplane enroute from Ming), that I am going to build the RAAF E-737 "Wedgetail." As much of a pure airliner and winglet fan as I am, this bird has been at the "local" airport for the past 5 years and I just have to make it. I have been experimenting with the dual aft strakes on the existing foamie EDF I have and they are quite nice actually- very stable.
Old Mar 06, 2011, 11:26 PM
jetspud is offline
Find More Posts by jetspud
shreveport
Joined Oct 2003
Stickers
Here was one of the schemes I was going to do.. Ill do it on my next one
jetspud is offline Find More Posts by jetspud
Old Mar 06, 2011, 11:32 PM
jetspud is offline
shreveport
Joined Oct 2003
Schemes
This is what I am doing Ming if you want to make these stickers I know I would like it...
David
Old Mar 06, 2011, 11:51 PM
jetspud is offline
shreveport
Joined Oct 2003
737
Here is what I got so far
David
Old Mar 06, 2011, 11:54 PM
jetspud is offline
shreveport
Joined Oct 2003
737
Couple more. These are the paints I have been useing
David
Old Mar 07, 2011, 09:38 AM
Rookie2008 is offline
Find More Posts by Rookie2008
Rookie2008's Avatar
Southern California
Joined Mar 2010
Its coming along now Jetspud.
Rookie2008 is offline Find More Posts by Rookie2008
Old Mar 07, 2011, 10:11 AM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Working on my motor installation. I have given this some thought. In most of my planes I have had the possibility of changing motors and fans, and I would like to have it the same way on my 737 as well.
I will mount the EDF as you see in the pictures and glue the lower part of the engine pod at 3 points with epoxy. I will also use the self adhesive vinyl to cover the gap between the two pieces. This will allow me to change fan, housing and motor without too much hazzle.
Ben_E
Old Mar 07, 2011, 10:37 AM
Rookie2008's Avatar
Southern California
Joined Mar 2010
That's a Great Idea Ben, I was thinking about that on another plane. But it still seems like a lot of work removing the EDF.
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
