Old Mar 03, 2011, 10:19 PM
pulsery2k1 is online now
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
jet-ster
the panel lines are covered ,so they are very shallow I left
them for decal aligment . when painted they will be even less
noticable
pulsery2k1 is online now Find More Posts by pulsery2k1
Old Mar 03, 2011, 11:11 PM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
*Ming, why don't you make stickers for almost the whole jet for blue livery since it has all those curves and lines. That would be SUPER easy for us to just stick on!
Danny
The official blue livery sticker area too big, too heavy and too many curves surface.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Mar 04, 2011, 01:28 AM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Originally Posted by Fotor View Post
Multiplex says that on elapor CA (regular medium or slow, not foam safe) has a better bond than epoxy. The fuselage may in deed be a little big for CA drying time, but tail surfaces and engine pylons could easily be glued with slow CA.
I have all the respect for the engineers at Multiplex, having 2 Easygliders, the Cularis and a Blizzard. But Im not sure that the Elapor and the EPO are the exact same material. Similar, yes - but not the same.
The engine pods are placed at a critical point of the wing and, has to be secured 100% to ensure the total strength of the wing. When gluing in such critical places its important to prepare the foam with small holes, so that the glue can penetrate into the foam and make a stronger joint. Nevertheless I will follow Mings advise and continue to use epoxy for this plane.
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Mar 05, 2011, 04:44 AM
rc4every12 is offline
Find More Posts by rc4every12
Joined Aug 2009
Hey Ming. Could you make stickers for the EL-AL 737? That would be awesome.
rc4every12 is offline Find More Posts by rc4every12
Old Mar 05, 2011, 09:26 AM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
Photo?
Ming
Site Sponsor
Old Mar 05, 2011, 11:32 AM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
here are some photo's
and a couple of extra's
Old Mar 05, 2011, 08:03 PM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Just painted lower half of fuse, (+13 grams after painting). Used Design Master Spray Paint which I've been using for a while now on my previous projects.
I will be painting the upper fuse tomorrow with Valspar Spray paint with Valspar Primer & Valspar Gloss (white) for Plastic, just like one I used with the Qantas.
Spyro37 is offline Find More Posts by Spyro37
Old Mar 05, 2011, 08:31 PM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Looks good Spyro37!
Nice to see that someone is progressing with their build!
I'm progressing slowly. Only 11 days to maiden day. All servos and the accompanying servos are mounted and moves correctly
Next is the fans. Going to test them tomorrow and continuing with the installation of them after the tests. Unfortunately I don't have a proper testbed so I can't measure the static thrust generated...
I also have finalized the graphics, and I will have all logos and markings cut during next week. Hope to conduct taxi tests next weekend
Ben_E
Old Mar 05, 2011, 09:44 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
Originally Posted by Ben_E View Post
Looks good Spyro37!
Ben_E
THANKS BEN.
Tomorrow, another 2 hrs. of work on her for top fuselage paint job, plus another layer of gold pin stripe over the white, so that the lower gold stripe will meet the upper gold striple. In short, the gold stripe on the above picture is not the actual width, it will be twice as wide.
Just waiting for the all the electronics, decals, Chrome tapes, and missing wood blocks for the gears for the flight video. Maybe take a day off and enjoy her soon maiden.
Old Mar 06, 2011, 02:36 AM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
Beware!
One 737 use 4600Kv motor with 4S battery cause flutter on the wing tips during full throttle today in Hong Kong. Luck the pilot able to land it safe.
Ming
Site Sponsor
Old Mar 06, 2011, 03:58 AM
Joined Aug 2009
Here are photos of the inside and outside wingtip:
Bottom:
Top:
Tail/side:
Old Mar 06, 2011, 05:57 AM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Originally Posted by Ming View Post
Beware!
Ming
not good, not good at all... My vinyl coverd wings are now much stiffer than the bare foam, so I'm not that concerned, but I do have some questions Ming, to sort this out:
  • How was the winglet attached to the wing? Glued, or done in some other way?
  • How was he flying? diving, level flight, full throttle?
  • When you state the kv of the motor, do you suggest he was flying too fast?
  • Did he use the stock fan?
Thanks!
Ben_E
Old Mar 06, 2011, 07:14 AM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
Beware!
Ming
Thanks!
Ben_E
How was the winglet attached to the wing? Glued, or done in some other way?---glue.
How was he flying? diving, level flight, full throttle?---level full throttle flight.
When you state the kv of the motor, do you suggest he was flying too fast?---Yes, sure too fast we can see on the ground, it even faster than some of foamy fighter.
Did he use the stock fan?---No, is Lander 4370kv metal fan.
Don,t worry, it will be OK to use less than 3800Kv motor with 4S battery.
That why we choice Scorpion HKII2221-8(3595Kv) for our combo, it good for 3 or 4S battery.
Ming
Site Sponsor
Old Mar 06, 2011, 10:16 AM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
[/B]When you state the kv of the motor, do you suggest he was flying too fast?---Yes, sure too fast we can see on the ground, it even faster than some of foamy fighter.
Thanks Ming!
To fly fast is not difficult at all Realistic scale speed is what I intend to achieve, reducing power at cruise and only use WOT on takeoff, and in emergencies...
Ben_E
Old Mar 06, 2011, 10:37 AM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
Thanks Ming!
Ben_E
Ben
Sure you can feel relax on your 737 maiden flight(when?).
Reducing power at cruising and enjoy the realistic scale speed of landing.
To landing this plane is too easy I can say.
Ming Lou
Site Sponsor
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
