Old Mar 02, 2011, 08:53 PM
New York Flyer is offline
Find More Posts by New York Flyer
flying techy
NY
Joined Nov 2005
Originally Posted by pulsery2k1 View Post
New York Flyer
I live about 1 1/2 to 2 hours north , but was flying out
LGA before retireing , not many places to fly .in queen's
the old flushing airport is abondoned? could you fly
there? it had sort of a runway ( I owned a Piper arrow
and flew in there a lot) it closed ? maybe there
Hey actually flushing airport is under water the area was closed its a swamp now.
there is a mall at the far end with a small park, you can fly a small foamy there.
kissena only place to fly. or cunningham park early in tha morning before the baseball twits takeover. Either than that port washington or stillwellwoods u need ama and county permit. Or face the pain of traffic going to brooklyn.
New York Flyer is offline Find More Posts by New York Flyer
Old Mar 03, 2011, 05:39 AM
Fotor is offline
Find More Posts by Fotor
*** gravity sucks ***
Fotor's Avatar
Netherlands
Joined Mar 2007
Mine finally arrived yesterday. Beautiful piece of work. And BIIIGGGGGG
Testing the gear and a basic lighting set:
Test gear and lights Boeing 737 model (0 min 30 sec)
Fotor is offline Find More Posts by Fotor
Old Mar 03, 2011, 09:40 AM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
I think this must be one of the biggest foamies around What livey do you plan? Koninklijke Luchtvaart Maatschappij maybe?
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Mar 03, 2011, 10:24 AM
Fotor is offline
Fotor's Avatar
Netherlands
Joined Mar 2007
Nope, Transavia (my employer, daughter company of KLM).
What glue do you guys use? The build manual instructs to use epoxy. The material seems very similar to Elapor of Multiplex, and Multiplex advises NOT to use epoxy but slow CA. Thick CA works excellent on the Multiplex models, anyone tried it on this material? I would like to use CA because it works easier, faster en is lighter.
Old Mar 03, 2011, 10:53 AM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
Ben_E, the finish you got with vinyl is so good-looking!
You inspired me to try the same on my flyfly Mig-15, instead of glassing it....
Found some vinyl locally
kimhey is offline Find More Posts by kimhey
Old Mar 03, 2011, 11:51 AM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
There is not much gluing to do actually.
I have tried foam safe CA and that sucks.... I have used epoxy and it works well. The foam also handles regular CA.
Gluing the fuse together is impossible to do with CA, it's just too big. Wings and motor pods needs the strength that the epoxy gives in my opinion!
Ben_E
Old Mar 03, 2011, 03:45 PM
Fotor is offline
Fotor's Avatar
Netherlands
Joined Mar 2007
Multiplex says that on elapor CA (regular medium or slow, not foam safe) has a better bond than epoxy. The fuselage may in deed be a little big for CA drying time, but tail surfaces and engine pylons could easily be glued with slow CA.
One more question: anyone knows the function of the small slots in the foam of the stabilizers? (the small slot in the lower right corner in the picture) The slots look exactly the same as the slots in the wing where the carbon spars run through the wing. Would Ming have wanted a spar in the stabilizers at first? Would they be strong enough without spars? (I think they are)
Old Mar 03, 2011, 04:08 PM
michi3 is offline
Find More Posts by michi3
Joined Jan 2009
Originally Posted by Ming View Post
Next to do.
Ming Lou
Thanks Ming. Great!
michi3 is offline Find More Posts by michi3
Old Mar 03, 2011, 09:01 PM
Flexserve is offline
Find More Posts by Flexserve
Avoid The Ground!
Flexserve's Avatar
United States, FL, Tampa
Joined Sep 2008
Flexserve
I'm replacing the ones on mine , as I want to move the servo's
into the fuse and out of site, I'm using these
http://www3.towerhobbies.com/cgi-bin...&I=LXK110&P=ML
if you are spraying directly to foam I would use a very light sanding
to break the glaze
The hardened shell is what I'm after. It seems light weight and durable.
Flexserve is offline Find More Posts by Flexserve
Old Mar 03, 2011, 09:44 PM
jet-ster is offline
Find More Posts by jet-ster
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
I just ordered a set of:
Transavia.com Decal Sticker
So I should be on mine soon, unless the habu 32 gets here first I chose this scheme because is seem to be pretty easy. Just paint all white and put on stickers.
jet-ster is offline Find More Posts by jet-ster
Old Mar 03, 2011, 09:48 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Rear section is polyglassed
the weight gain just under 2 oz , servo openings filled with
pink foam and filler . servos moved to the inside
very easy to do with great results
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Mar 03, 2011, 09:51 PM
jet-ster is offline
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
I really love the blue livery but it would really hard to paint all those lines and tones inside those blues.
*Ming, why don't you make stickers for almost the whole jet for blue livery since it has all those curves and lines. That would be SUPER easy for us to just stick on!
Danny
Old Mar 03, 2011, 09:52 PM
jet-ster is offline
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
Just poly only did you use any silkspan or anything?
Old Mar 03, 2011, 10:02 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Jes-ster
polyglassing is the use of silkspan and WBPU
watch the video to see what I did
ployglass.wmv (3 min 2 sec)
Old Mar 03, 2011, 10:12 PM
jet-ster is offline
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
Love that video! I noticed you still have panel lines so I wasn't sure
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
