Old Mar 02, 2011, 05:06 AM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Originally Posted by huggie9999 View Post
Who's going to be the first to do what this real 737 did?????
IŽll give it a try
I plan to maiden mine here in two weeks:
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Mar 02, 2011, 09:48 AM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
ColoradoHeliNut
misunderstanding and not knowing what your talking about.
I watched the video but only half of what he said is correct
whats correct :
the problem is inproper setup .of your heli gears ,yes I agree
this is also true of edf - unblanced rotor puts side loads on bearning's
what'S incorrect oil the bearing's these are the bearning for the motor
http://www.bocabearings.com/bearing-...2OS7AF2-4x11x4
they are SEALED bearnings . (see photo below) which means the
lub is sealed in and the bearning is maintenance free , so unless
the bearning becomes damaged no oil can get in.
at 4:00 in video (see photo) he is seen applying oil to stator
the bearning is located above in housing .
what he goes on to say at the end that is correct is that when
the heli is set up properly they have had hundreds of flights
with no maintenance and no problems.
conclusion , you can't oil sealed bearnings and if properly set up
you will not have any problem's. inproper setup will ruin your bearnings BEARNINGS ARE GOOD , BALANCE YOUR ROTOR
AND FLY AND HAVE FUN
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Mar 02, 2011, 10:06 AM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
Ming
I'm getting ready to start my build, I noticed from the early
photos that the upper hatch seem's to have beed moved
back on the fuse, from the earlier photo's
I would like to close the upper hatch and glass over it
where approx do the batterys sit ,I'm planing on using
2 3s 4000 packs
Good catch!
Yes, we relocated the battery bay almost 8 inch backward for CG issue.
The battery bay open on wrong position in the beginning. It cause the half of battery place after the bay.
Don't worry, all the 737 ship was after this amendment.
That why Windrider spend more time on each project.
Good! two pcs of 3s 4000mAh packs can bring you over 5 mins flight time.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Mar 02, 2011, 10:31 AM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
thanks Ming
where do the battery's sit to get proper cg?
Well I will begin my build I'm still thinking about mod's
where as ming have done a great job on this there are little improvements
in appearance and maintenance I would like to start with.
the tail ,I will rehinge elevators and rudder and then cut a hatch
as marked by red line so the servo's for the rudder and elevators
will be located inside the tail (for appearance) hatch removable
for mainenance.
on the engine pods I which to split the bottom so the edf
units can be removed for maintenance - trying diffrent motors
ect , to be held in place with hidden screws.
I would like to close the top hatch and make a new one from
one of two places possable between the wing mounts or
on the bottem fuse between nose wheel and wing
Old Mar 02, 2011, 10:37 AM
New York Flyer is offline
Find More Posts by New York Flyer
flying techy
NY
Joined Nov 2005
Originally Posted by Ben_E View Post
IŽll give it a try
Ben_E
dam u live there? lucky you have a valley for yourself.
I only have a park. Here is an aerial of my 757
New York Flyer is offline Find More Posts by New York Flyer
Old Mar 02, 2011, 10:40 AM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
New York Flyer
you live in Queen near whitestone?
Old Mar 02, 2011, 10:42 AM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
It depend on the battery size, but most likely the battery is on the middle of wings(root).
Because the CG is just there or not more than 1cm backward.
Ming Lou
Site Sponsor
Old Mar 02, 2011, 10:54 AM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Thanks ming
The hatch I'm think of in the photo is in the red , I would reinforce
the sides and make holders for packs with some ability to move them
fore and aft to achive proper cg, then run the balance plugs to
the wing bottem covers for charging
Old Mar 02, 2011, 11:05 AM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Ming
I'm working on decals , this is approx 1/14 scale?
Old Mar 02, 2011, 11:14 AM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
approx 1/18.5
Ming Lou
Site Sponsor
Old Mar 02, 2011, 11:36 AM
flying techy
NY
Joined Nov 2005
Originally Posted by pulsery2k1 View Post
New York Flyer
I live in Elmhurst, but i head to Kissena park. y?
Old Mar 02, 2011, 12:01 PM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
No, I don't. But the valley you see is remarkably flat... 100% level - water usually is
I have done some work on the tail-art today. I printed a test on paper and fitted it to the tail. This is the original:
Mine below:
Ben_E
Old Mar 02, 2011, 12:09 PM
HaventFlownSince2014 is offline
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
Looks fantastic!
This has been the hardest/most enjoyable thread to follow while at work... there are more posts per second on this page than any of the other threads I follow
Do you all have jobs?
HaventFlownSince2014 is offline Find More Posts by HaventFlownSince2014
Old Mar 02, 2011, 12:16 PM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
Ben
This is so cool!
Please Please Please be careful on your maiden!
This masterpiece can draw everybody attention.
Can you email me your art?
Ming Lou
Site Sponsor
Old Mar 02, 2011, 12:35 PM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Originally Posted by Ming View Post
Ben
This is so cool!
Ming Lou
I'll get back to you on that, I still have to make some final adjustments, the picture has to be moved slightly upwards to be 100% correct
Ben_E
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 10:31 PM
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 636 Jan 23, 2015 12:16 AM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 10:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 09, 2002 12:21 AM
