Old Feb 28, 2011, 07:30 PM
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Originally Posted by Rookie2008 View Post
Ben, No one will notice. Well as long as you keep her in the SKY!! . Have a safe flight.
I really don't feel safe, due to this bearing issue. Hope this won't haunt me during maiden flight
And if someone with better knowledge than me can point me to witch of the two bearings mentioned I should get, I might get rid of the thought of going down due to some silly bearings that can't handle my determination to keep the 737 in the air safely.
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Feb 28, 2011, 07:33 PM
Avoid The Ground!
Flexserve's Avatar
United States, FL, Lutz
Joined Sep 2008
Ben_E
I already linked them, see above!
man I feel ignored...
Flexserve is offline Find More Posts by Flexserve
Ming's Avatar
Hong Kong
Joined Jun 2002
Dear Fellow
I finished over 200 flights by 4S battery with Scorpion HKII2221-8 motor on BD-5J(60mm EDF), F35(70mm EDF), Ele-Bee pod(small prop pusher) and 737(70mm EDF) never have problem.
Please note that the Amps to draw is just 30A on 3S and 35A on 4S.
This is the reason why we choice this US$55 motor for 737 combo not US$15 cheap motor.
BUT, please thurst me, 3S is good enough on smooth runway and just keep you plane light by max 8000mAh battery. 10000mAh is still OK but no need to do so.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Feb 28, 2011, 07:36 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Ming should we be using (2) lipos or one?
Rookie2008 is offline Find More Posts by Rookie2008
Old Feb 28, 2011, 07:38 PM
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
My bad, it's close to 3 o'clock in the morning here (for the 3rd night in row) and the small grey ones does not work at full speed anymore (they won't at work tomorrow either).
But to wrap it up; I need one of each type per motor, is that right?
Ben_E
Old Feb 28, 2011, 07:42 PM
DFC~ We Do Flyin' Right
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
Ben~ You're looking great! I can watch your TV on the gloss of your fuse
bsbauman is offline Find More Posts by bsbauman
Latest blog entry: Burned Retina Shorts
Ming's Avatar
Hong Kong
Joined Jun 2002
Should be use two battery for two motors, but we did try one 5000mAh battery(Hyperion 45C) for two motors and result is acceptable(not my suggestion).
MingLou
Site Sponsor
Old Feb 28, 2011, 07:48 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Ok so I will use Just one. How are we looking on those New Continental rudder logo? Are you redoing the Continental Logo to fit the 737 or just the rudder?
Old Feb 28, 2011, 08:50 PM
Avoid The Ground!
Flexserve's Avatar
Joined Sep 2008
My bad, it's close to 3 o'clock in the morning here (for the 3rd night in row) and the small gey ones does not work at full speed anymore (they won't at work tomorrow either).
Ben_E
Yes. 1 set per.
Old Feb 28, 2011, 09:55 PM
kevinb120's Avatar
Joined May 2009
Rookie what vinyl are you using to cover that airframe? I was thinking about using Oracal 600 series (2.75m) or similar
kevinb120 is offline Find More Posts by kevinb120
Old Feb 28, 2011, 10:45 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
I am not sure I got it from my father-n-laws Graphic Design shop.
Old Mar 01, 2011, 12:27 AM
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
When covering the wings, the quality is not so important, but be sure it's not a "campaign type" a lesser quality that doesn't stick that well due to the fact that it is designed to be removable at at later time. Hence it is slightly thicker and more difficult to form round compound curves.
Ben_E
Old Mar 01, 2011, 01:06 AM
kevinb120's Avatar
Joined May 2009
I was actually thinking about this stuff.
http://www.uscutter.com/ORACAL-651-I...hed_p_260.html
Albeit I'm putting it on a Habu, which has a bit more complicated fuselage, but no more complicated the the 737's nacelles. I figure I can slightly heat it with a hair dryer before setting down on more compound curves, and 'panel' it if needed. Two 15"x10 yard rolls costs about the same as a few cans of spray paint and adhesion promoter.
Old Mar 01, 2011, 06:24 AM
Ming's Avatar
Hong Kong
Joined Jun 2002
One more choice for Continental.
http://www.windrider.com.hk/product.asp?id=200
Ming Lou
Site Sponsor
Old Mar 01, 2011, 06:42 AM
Lars N's Avatar
Joined Apr 2007
Looking good I think!
Have also used some of the the included in the kit to stiffen up the wing. And after I covered it it's much stiffer
Ben_E
This lloks realy nice Ben E
Lars N is offline Find More Posts by Lars N
Discussion Windrider Boeing 737 Ming Scale Electric Planes 628 Mar 30, 2013 07:20 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 44 Jan 06, 2011 07:47 PM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
