Espritmodel.com Heli Air
Old Feb 26, 2011, 12:03 AM
Ming's Avatar
Hong Kong
Joined Jun 2002
I can ship you this two piece of plywood ASAP.
Please email me your shipping address.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Feb 26, 2011, 12:06 AM
Rookie2008's Avatar
Southern California
Joined Mar 2010
Ok Thanks Ming
Rookie2008 is offline Find More Posts by Rookie2008
Old Feb 26, 2011, 01:14 AM
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Nacelles, temporarily installed (not glued yet).
Will be covered and fixed once rookies power plant are available.
We'll also post weights before and after coverings.
Spyro37 is offline Find More Posts by Spyro37
Old Feb 26, 2011, 01:19 AM
Spyro37's Avatar
Joined Jun 2009
Ming Lou
Thanks Ming, that's what we need...
(for the above picture)
Old Feb 26, 2011, 10:01 AM
flying techy
NY
Joined Nov 2005
Originally Posted by Spyro37 View Post
This glue.
This is the newer version. White, and Faster drying time.
Very light weight, compared to epoxy.
Ah yes good old gorilla glue.
New York Flyer is offline Find More Posts by New York Flyer
Old Feb 26, 2011, 02:17 PM
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
A bad quality photo from the "paintshop"!
Covering the fuse is a time consuming job and I have had my professional friend do it for me. Unless it would end up in a mess. It's a very difficult job to cover the curves of the fuse.
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Feb 26, 2011, 05:02 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
I have a question. If my planes weigh in at approx 2000g (4.4lbs) would a 3S LiPo performance setup with over 2lbs of thrust pulling in at Max power: 500+ watts be enough power?
Old Feb 26, 2011, 05:15 PM
Avoid The Ground!
Flexserve's Avatar
United States, FL, Lutz
Joined Sep 2008
Im planning on 10000mah worth of 3s.
Flexserve is offline Find More Posts by Flexserve
Old Feb 26, 2011, 05:19 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
My original plan was to use the HET 2w 500 watts max on a 3s setup but not sure if that will be enough power for the plane the auw may be around 6.6lbs is that right Sergey? keep in mind I am extra 170 grams max in vinyl.
Old Feb 26, 2011, 05:46 PM
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
The plane parts weigh in at just under 2000g ex motors and batteries:
Originally Posted by _Sergey_ View Post
Airplane data
Plane parts_____________________________Weight, g
2x Wings................................358
Tail section............................243
Fuselage................................625
2x Engine pods..........................90
2x H stabs..............................66
V stab..................................78
2x Wing tips............................9
6x Pylons...............................11
Wing spar...............................50
Accessories (bolts, clevices etc).......125
_______________________________Subtotal 1,655
3x Landing gear.........................291
Landing gear mounts.....................11
__________________Subtotal Landing gear 302
__________________________________Total 1,957
I'm considering leaving the 3S trail... Mine will come out heavy due to both vinyl and the fact that I have done a lot of work on the fuse, adding weight...
If I end up at 3000g or about 6lbs I will have about 106W pr lbs That seems too low to me. I'll have to get hold of some new motors fast. We leave for the show in 18 days... Lots of things to do first!!
Ben_E
Old Feb 26, 2011, 05:48 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
WOW thanks Ben so then for sure I am going to need a 4s setup right.
Old Feb 26, 2011, 05:50 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
just tested one het 2w drawing 42.5 amps, 452 watts sustained at 20 seconds on 3s 30c 2200 mah.
Ming's Avatar
Hong Kong
Joined Jun 2002
I think AUW less than 3kg is good.
Ming Lou
Site Sponsor
Old Feb 26, 2011, 05:54 PM
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Ming Lou
What did the 3 planes in your video Weigh in at?
They had 3S and 4S setups, but from the video I could not tell anything about the difference in performance. Maybe 4S would help to take off from a grass strip.
And what do you recommend as max AUW?
Ben_E
Old Feb 26, 2011, 05:57 PM
Rookie2008's Avatar
Southern California
Joined Mar 2010
well my wings covered in vinyl weigh in at 486g plus the motor fans esc servos maybe total 850g? I wondering if I have enough power and about 2050g on the fuse
Discussion Windrider Boeing 737 Ming Scale Electric Planes 628 Mar 30, 2013 07:20 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 44 Jan 06, 2011 07:47 PM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
