Old Feb 06, 2013, 05:04 PM
hi2nr is offline
Find More Posts by hi2nr
United States, TX, League City
Joined Jun 2008
My slats so far, first picture is closed, second is extended, and last picture shows what its like with wings under load.
Its still naked and im making the inserts out of pink foam to fill, the slats themselves will have a thin sheet of balsa extension to finish it off. Other than that im happy so far
I still have to work on the other wing....then make the spoilers and flaps.
The thrust reversers are going to be the suprise once I finish the plane
hi2nr is offline Find More Posts by hi2nr
Old Feb 06, 2013, 06:47 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
How did you do it???
Keenan smith is offline Find More Posts by Keenan smith
Old Feb 06, 2013, 07:44 PM
hi2nr is offline
Joined Jun 2008
Its just balsa on rails lol. Pretty sturdy so I doubt it'll collapse when working. There will be 1 servo under the wing that will push/pull
Old Feb 06, 2013, 09:17 PM
measy is offline
Find More Posts by measy
United States, CA, Fairfield
Hi hi2nr, looks like your slats only slides out not out and down. Is that correct? Nice job in any case.
measy is offline Find More Posts by measy
Old Feb 06, 2013, 09:39 PM
hi2nr is offline
Joined Jun 2008
In the picture it slides out only, the rails are being made now to give it the out downward motion and will replace the mock up rails. I rigged up the rails to test the wing flexing and if there will be any failures of the slat from flexing
It should or will come very close to the real deal
Old Feb 06, 2013, 09:42 PM
hi2nr is offline
Joined Jun 2008
I think my main concern is that since air is air and it does change scale like your scale model would so deploying the slats during final would cause a stall or no?
Old Feb 06, 2013, 10:20 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
hi2nr
slats are lift devices and help delay stall's , what I would worry
about is the wing flex's and one jam's and one extends , it could
cause loss of control?
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Feb 06, 2013, 10:30 PM
hi2nr is offline
Joined Jun 2008
I doubt it'll jam up, they're all linked together underneath
Old Feb 06, 2013, 11:40 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
hi2nr
I was looking at your photo's of your leading edge slats,
I'm not sure they will help , looks more like they may do the
oppsite.
Old Feb 07, 2013, 08:50 AM
hi2nr is offline
Joined Jun 2008
I think those are Krueger flaps, I'll be adding those to the inboard soon
As for the slats I'm trying to achieve these:
Old Feb 07, 2013, 08:57 AM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
hi2nr
Yes - but if this photo of yours is the extended slats .the big
gap between the wing and leading edge won't add lift
Old Feb 07, 2013, 09:04 AM
hi2nr is offline
Joined Jun 2008
I'm still making the inserts out of foam to fill the gap and complete the foil. It should also serve as a flat surface for the slats trailing edge to slide on
Old Feb 07, 2013, 09:08 AM
hi2nr is offline
Joined Jun 2008
1st picture closed, second picture extended
its just a mockup and not completed yet but once i make the inserts for the airfoil and finish the rails for the slats to drop downwards itll be extremely close to the real deal
Old Feb 07, 2013, 09:11 AM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
hi2nr
Yes that looks much better
Old Feb 10, 2013, 03:22 AM
8492ND is offline
Find More Posts by 8492ND
United States, CA, Pasadena
Joined Jun 2007
Instead of carving this probe out of foam, I decided to take an old foam wheel ( since it was black foam) and carve from it instead. Came out nice I think. Not exactly scale but nor was I trying to achieve a scale look.
8492ND is offline Find More Posts by 8492ND
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 10:31 PM
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 636 Jan 23, 2015 12:16 AM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 10:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 09, 2002 12:21 AM
