Old Jan 19, 2013, 09:44 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
And me, as well! Hope you will design it with flaps, similar to many Dynam models.
bamaguy is offline Find More Posts by bamaguy
Old Jan 20, 2013, 02:55 AM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
Windrider start to accept pre-order of Boeing 747-400
http://www.windrider.com.hk/product.asp?id=170
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Jan 20, 2013, 10:10 AM
hi2nr is offline
Find More Posts by hi2nr
United States, TX, League City
Joined Jun 2008
I think the EDFs should be optional, most of us have or have a different fan unit in mind
hi2nr is offline Find More Posts by hi2nr
Old Jan 20, 2013, 12:18 PM
Phaedra is offline
Find More Posts by Phaedra
An unexpected error occurred
Phaedra's Avatar
Belgium, Flemish Region, Duffel
Joined Apr 2012
I started on my own lights controller with an Arduino microcontroller.
Each output can be progranned as a steady light or a strobe light.
In strobe mode, a delay can be programmed, so that not all strobes flash at the same moment, making it a bit more realistic.
An output channel can also be controlled by the value of a receiver channel. This way, I am able to switch landing lights automatically on or off, depending on the landing gear position, or top and bottom strobes depending on engines on or off.
Now I'm thinking of adding a switch to switch all lights on or off or automatic.
Big fun!
Phaedra is offline Find More Posts by Phaedra
Old Jan 20, 2013, 12:22 PM
Rookie2008 is offline
Find More Posts by Rookie2008
Rookie2008's Avatar
Southern California
Joined Mar 2010
Boeing 747 RC model First Flight (3 min 23 sec)
Rookie2008 is offline Find More Posts by Rookie2008
Old Jan 20, 2013, 02:52 PM
F-86FLIER4LIFE is offline
Find More Posts by F-86FLIER4LIFE
Landin' On The Canopy BAD
F-86FLIER4LIFE's Avatar
Lee's Summit, MO
I know its a little early, but I started the 747 thread http://www.rcgroups.com/forums/showt...ht=windrid+747
F-86FLIER4LIFE is offline Find More Posts by F-86FLIER4LIFE
Old Jan 20, 2013, 02:56 PM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
This is what I've waited for! A 747-400 kit with flaps and retracts! I'll have to have one.
av8ersteve is offline Find More Posts by av8ersteve
Old Jan 21, 2013, 09:23 PM
atvs2828 is offline
Find More Posts by atvs2828
Joined Jan 2013
Hi All,
I just received my Windrider 737 and it looks amazing. I am anxious to get building. I would really like to add flaps, spoilers, and nose gear doors. Does anyone have a good DIY for that? Also I saw in some videos on youtube, someone used polyacrylic from minwax with micro balloons on there plane. Can any tell me what should I coat and why it was used? I would also like to cover in adhesive vinyl? Any thoughts?
Thanks!
atvs2828 is offline Find More Posts by atvs2828
Old Jan 21, 2013, 10:52 PM
Cocg is online now
Find More Posts by Cocg
Fly and let Fly!
Cocg's Avatar
United States, CO, Grand Junction
Joined May 2010
Anybody.. Please.. A Poll if I may...
Or Survey..
What are your all Up Weights? Looking for the heaviest..
Sincere thanks.. Cliff
Cocg is online now Find More Posts by Cocg
Old Jan 22, 2013, 07:45 AM
carrerars is offline
Find More Posts by carrerars
carrerars's Avatar
Joined Aug 2008
Ok, mine has 4kg (8.8 pounds) with 2x 4s 3300mAh
Markus
carrerars is offline Find More Posts by carrerars
Old Jan 22, 2013, 09:02 AM
hi2nr is offline
Joined Jun 2008
Mine hit 10.5lbs AUW before, that was using 2x 5500mah 4s 1x 3300 3s all vinyl, had many flights that way then switched to a lower KV motor and 1x 5500mah pack
Old Jan 22, 2013, 04:22 PM
NCRealEstateGuy is offline
Find More Posts by NCRealEstateGuy
I Used To Have More Free Time!
Charlotte, NC
Joined Feb 2011
I will weigh mine tonite.
NCRealEstateGuy is offline Find More Posts by NCRealEstateGuy
Old Jan 22, 2013, 09:00 PM
Cocg is online now
Fly and let Fly!
Cocg's Avatar
Joined May 2010
My Inspiration
Primera, Air Scandinavia
Based in Copenhagen Denmark.. They have 2 737 700s and 7 800s..
Description:
Name: Primera Wet Landing.jpg
Description: Name: Primera Boeing.jpg
Description:
Name: Ohh Primera..!.jpg
Description: Name: OY-PSF-Primera-Air-Scandinavia-Boeing-737-700_PlanespottersNet_284618.jpg
Description: Name: OY-PSF-Primera-Air-Scandinavia-Boeing-737-700_PlanespottersNet_305728.jpg
Description: After scanning Everything.. looking for practicality and different.. Colors I liked .. This is what I figured I would try.. Next posting..!!
Old Jan 22, 2013, 09:17 PM
Charlotte, NC
Joined Feb 2011
Mine wieghs in at 9.0 pounds.
Looks like hi2nr is winning.
Old Jan 22, 2013, 09:20 PM
Cocg is online now
Fly and let Fly!
Cocg's Avatar
Joined May 2010
Another Windrider 737 to Join All Those Who Led The Way
Well, with a few graphic mistakes and trials and tribulations.. A maiden yet to come..... Here she be...
Name: Windrider Final  1sts 039.jpg
Description: No lights Too much brain power.. I am lacking .. resistors, watts, leds.. !!
Name: Windrider Final  1sts 066.jpg
Description: Name: Windrider Final  1sts 079.jpg
Description: Vinyled wings and Elevator. Painted Everything Else.. (3 coats WBPU, No tissue) Flaps and nose gear doors..
Name: Windrider Final  1sts 046.jpg
Description: Name: Windrider Final  1sts 047.jpg
Description: Name: Windrider Final  1sts 040.jpg
Description: .... Except the main graphics.. A couple tries with and from our favorite... Callie from Callie Graphics ..
Planning on 2 3300mah 4s with Change Sun 10 blade and 2 Red Brick 70 ESCs.. Seperate Castle BEC powered with a 1000mah or 1300mah 2s ..
AUW at 8lbs. 12ozs..
Misc. things to do, CG, Control surface throws, Watt/Amp check, Calm sunny warm day..!
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
