Old Dec 26, 2012, 04:09 PM
Hollywood2979 is offline
Find More Posts by Hollywood2979
Hollywood2979's Avatar
United States, TX, Cibolo
Joined Nov 2011
Yeah I tend to do that with all my plane now, I may just scrape in a dirt packed runway and get away from the grass all together.
Hollywood2979 is offline Find More Posts by Hollywood2979
Old Dec 26, 2012, 09:37 PM
Hawaiian Flyin is offline
Find More Posts by Hawaiian Flyin
Hawaiian Flyin's Avatar
United States, HI
Joined Dec 2007
Originally Posted by hi2nr View Post
Make sure to need up your LG strut rods and to glue those wooden plates down good. I used to always bend my LG landing on grass
+1 on that. I have only 1 flight on mine and had one plate come unglued and the other 2 bent. Although my landing wasn't what i would call pretty.
Thanks Bama & Jurgen. Already have the shafts ordered.
Hawaiian Flyin is offline Find More Posts by Hawaiian Flyin
Old Dec 26, 2012, 10:24 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
you guys will like this and a shout out to sergey i hope he doesnt mind that i used some of his video in mine
Stabilised approaches: why do them? (2 min 50 sec)
Keenan smith is offline Find More Posts by Keenan smith
Old Dec 27, 2012, 09:08 AM
Fotor is offline
Find More Posts by Fotor
*** gravity sucks ***
Fotor's Avatar
Netherlands
Joined Mar 2007
In real aviation we use the term 'stabilised approach' not for a certain way of controlling the airplane (control speed with pitch and descent rate with throttle), but for having the airplane stabilised by a certain altitude. Some companies use 500 ft, but more and more companies use 1000 ft. At this altitude you should have a number of parameters within certain limits (on speed, on the correct glide path, aligned with the runway, wings level, flaps and gear configured, throttles not idle, checklist completed), otherwise you have to make a go-around.
Research showed that unstable approaches increase the chance of an accident dramatically.
It's something I try to achieve with most model airplanes, but certainly with the 737. I want to have the correct speed starting the base turn, and on final there should be no need for big corrections of any kind.
Fotor is offline Find More Posts by Fotor
Old Dec 27, 2012, 03:37 PM
Major12 is offline
Find More Posts by Major12
Joined May 2012
"Here is a short fly by vid of my airliner with the 12 blade fans installed, (not a b737) you will lose about 1/3 of your flight time using these fans, I went from a 3300mah 4s battery 5 blade fan and 3200kv motor to a 4500 4s 2300kv motor to achieve the same flight time, 4-5 minutes depending on wind"
Hi Mike,
Thanks for your advice. What ESC are you using? I dont have to much of a clue ref the electrics, and want to get get the best set up for the fans. You sound like you have done a fair amount of testing. Any specific motor and ESC brand you recommend?
Gav
Major12 is offline Find More Posts by Major12
Old Dec 28, 2012, 05:15 AM
limodune is offline
Find More Posts by limodune
limodune's Avatar
Australia, QLD, Toowoomba
Joined Oct 2011
Gav
The motors I have been testing only draw about 40-50 amps or so (L2836 2300kv 2800kv outrunners and a Tacon 2618kv inrunner) so I use 55amp ESC Turnigy Trust, I used this chart as a guide (from the Change Sun 10 blade fan thread), the numbers I got were a little different, lower, bought this stuff from HK
limodune is offline Find More Posts by limodune
Old Dec 28, 2012, 08:16 AM
Major12 is offline
Joined May 2012
Hi Mike,
I really appreciate your advice. I am going to order this same set up myself. Im assuming this also helps with lower heating issues?
Also, what did you use to balance your fans, and did you find they where off by much? I haven't balanced fans before, looks straight forward online though to do.
thanks
Gav
Old Dec 29, 2012, 06:12 PM
limodune is offline
limodune's Avatar
Joined Oct 2011
Just a normal prop balancer, one was fine the other needed balancing, if you are going to use an out runner motor you will need to make a notch on the motor plate to clearance the wires where the motor attaches to, other wise they could hit the fan
Old Dec 29, 2012, 08:05 PM
Major12 is offline
Joined May 2012
What specific motor are you currently using? I'm just going to play it safe and get the same set up as you, other wise I'd honestly be guessing the set up.
Old Dec 30, 2012, 11:44 AM
8492ND is offline
Find More Posts by 8492ND
United States, CA, Pasadena
Joined Jun 2007
Originally Posted by Ming View Post
I think 1 X 3 or 1 X 4mm is good enough.
Ming Lou
Please give me tracking info on my purchase, thank you
8492ND is offline Find More Posts by 8492ND
Old Dec 30, 2012, 06:36 PM
limodune is offline
limodune's Avatar
Joined Oct 2011
I am using the 2300 kv motor, your AC is heavier than mine so I would look at the 2800kv motor, but the choice is yours----
Old Dec 31, 2012, 03:52 PM
Major12 is offline
Joined May 2012
Thanks for your help Mike!
Old Dec 31, 2012, 08:19 PM
Ming is online now
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
We aleays suggest to use Scorpion HKII2221-8(3595kv) motor for 3S or 4S on stock CS70/4 EDF unit.
Ming Lou
Ming is online now Find More Posts by Ming
Site Sponsor
Old Jan 03, 2013, 11:47 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
http://www.youtube.com/watch?feature...&v=MOxs-VWsmDE
The 12 blade fans have almost same exact total pitch as 10 blade fans....I'm seeing similar thrust\watt numbers
erh7771 is offline Find More Posts by erh7771
Old Jan 07, 2013, 04:54 AM
Pannoch RC is offline
Find More Posts by Pannoch RC
Paul B
Australia, TAS, Launceston
Joined Dec 2009
Its been a while but I finally maidened mine on Saturday. The flight was exciting so say the least. The RHS flap hung slightly lower than the LHS causing a constant roll to the left which was manageable but required concentration.
The current draw was huge, setting off the LVC after only 2 min of flight. This also heated the battery connection to the point where the solder melted. Only the heat shrink kept the cable to the connector which finally separated on landing.
I didn't quite make it back to the strip, landing in a field which only caused minor bending to the landing gear. Otherwise not a scratch.
I've already fixed the retracts and I'm in the process of designing a better wiring system to handle the current flow, and looking for bigger batteries. I used a 14.8V 5000mah Nanotec for the flight which proved to be powerfull enough, just not enough capacity.
Easily takes off from grass with flap and spoiler mod. Inboard cam shows very little wing flex which was put through its paces due to the flap induced roll
Here's the vid
Windrider Boeing 737 Virgin Blue Maiden Flight (5 min 38 sec)
Cheers
Paul
Pannoch RC is offline Find More Posts by Pannoch RC
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
