Old Oct 06, 2012, 03:21 PM
lil hoss is offline
Find More Posts by lil hoss
wisconsin
Joined Feb 2004
Cocg
I just ran out of the dark brown for the tail.
I should get it next week.
Once I cover the rest of the tail I will post some pictures.
Hoss
lil hoss is offline Find More Posts by lil hoss
Old Oct 06, 2012, 04:39 PM
Pannoch RC is offline
Find More Posts by Pannoch RC
Paul B
Australia, TAS, Launceston
Joined Dec 2009
Does anyone still have the outer cardboard box?
If you do, could someone tell me the box dimensions? From memory they are printed somewhere on it.
Thanks in advance,
Paul
Pannoch RC is offline Find More Posts by Pannoch RC
Old Oct 06, 2012, 04:53 PM
Seahawk One is offline
Find More Posts by Seahawk One
What tree??.......Doh!!
Seahawk One's Avatar
USA, WA, Seattle
Joined Aug 2007
Thanks in advance,
Paul
mine says: 119 x 46.5 x 33cm
~Cheers to the land down under!
Neil
Seahawk One is offline Find More Posts by Seahawk One
Old Oct 06, 2012, 06:52 PM
Paul B
Joined Dec 2009
Neil
G'Day Neil!!
Cheers mate! Exactly what I was hoping for.
Paul
Old Oct 07, 2012, 09:04 AM
Future Wingz is offline
Find More Posts by Future Wingz
Future Wingz's Avatar
United States, WA, Seattle
Joined Aug 2012
Vic- Looks awesome bro!!!
~Cheers,
Neil
Thanks Neil, I've been on business travel, left right after my last post and just got back in yesterday. The maiden prep continues! not sure where I shall accomplish flight testing yet as I'm now a bit hesitant to fly off the grass. Cheers!
Vic
Future Wingz is offline Find More Posts by Future Wingz
Old Oct 07, 2012, 09:12 AM
Joined Aug 2012
Looks great Future Wings!!
Hi Paul, thanks! I need to get a few things sorted prior to getting ready for my B-1 flight! Have you flown the VA yet? Cheers!
Old Oct 07, 2012, 09:17 AM
Joined Aug 2012
Originally Posted by lil hoss View Post
I sure learned a lesson tonight on useing vinyl.
I covered the fuse, wings, horizonal stab in white. I used a rather inexpenseve vinyl called Oracal # 641..
As I mention in a earlier post I am going with the UPS design.
I got some dark brown vinyl from a sign maker here locally.
The brown he gave me was a Scotchcal #220 for the rudder.
Geeez I can't believe what a difference it is using a better quality vinyl.
SO manageable and plyable.
Any wrinkles were easily rubbed out and the adhesive was much better.
The vinyl just stuck better to the curves than the cheaper vinyl did..
I would defenditley use a better quality material on the next one.
Hoss
This is quite interesting Hoss! Based on your experience with both, the scotchcal seems to be the better quality vinyl. Very good to know this for my next build.
Cheers!
Old Oct 07, 2012, 09:22 AM
Joined Aug 2012
Originally Posted by Major12 View Post
Proudly presenting a Ryanair replica almost complete, fine detailing to be revealed over next few weeks:
Nice work Major12 Do you plan on charging your pax fees for lav use?
Are those the Changesun 10 blade impellers? Cheers!
Vic
Old Oct 07, 2012, 03:54 PM
Major12 is offline
Find More Posts by Major12
Joined May 2012
Ryanair 737 update
Hi all,
Thanks for the kind comments, took 3 months to get to this stage with many mishaps on the way. One of the worst was the masking tape getting saturated with paint and seaping through.... Also. to start with, I covered the plane in the wrong polyfilla which ended up covering the plane in a heavy rock like material. Took me a month to chisel off leaving a rough skin. Back to square one I got the correct filler and spent months sanding and coating. Then WBPU and tissue, sanding (I hate sanding now) followed by acrylic paints and graphics from the famous callie graphics. More fine paint detailing to be done with a small paint brush as you can see from some of the pictures. Just finished LED install.
It is the c-sun 10 blade fans. Any body with any experience in these? I haven't sealed up the engines and added a yellow stripe there which I need to do yet as Im not sure if these are going to need balanced? This is next on the test list. I also have some detailed and scale intake warning stickers for the engine pods to be added once sealed :-)
I am having trouble setting up new ESCs i got, no instructions nor can I find any on line for them
As for video flying, yikes this is the scary bit. Think I will get a large scale pro to maiden for me, after all this work I'm afraid to fly it! but I just want a video myself now of this baby in the air. Anybody know what the heaviest one of these is that has flown?
Some more update pics:
Major12 is offline Find More Posts by Major12
Old Oct 07, 2012, 04:22 PM
lil hoss is offline
wisconsin
Joined Feb 2004
Wow Major 12
I can't believe how realistic it looks
That ship in the water under it really makes it look scale....
How did ya git that boat to pass under your plane and get a picture???
Just kiddin
Really does look GREAT
Nice job
Hoss
Old Oct 07, 2012, 04:33 PM
Major12 is offline
Joined May 2012
haha thanks Hoss.
The real nightmare of the paint job was that the under blue side slants at an angle, getting both sides to match took 2 days! Other issues I came a cross may be of help to others: Do wing wire installs like servos / leds before adding the engine pods. I covered the plane with this http://www.poly-c.com/ and it is great. Paints on and leaves a hard shiny shell. I have to try very hard now to make test inflicted hangar rash. Sealed the stickers down smoothly too. Another coat to go and then I will polish it up. You simply cannot tell its foam underneath now, zero trace of it.
Old Oct 07, 2012, 04:49 PM
pulsery2k1 is online now
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Major12
Nice Job - i have the CS 10 blade fans - but which motors
are you using ? and for esc's which one's did you get ?
if you have the correct motors and esc they work fine
with this - also what the RTF weight ?
the model it self is easy to flt , but a lot of people have others
maiden and trim there new models.
pulsery2k1 is online now Find More Posts by pulsery2k1
Old Oct 07, 2012, 04:59 PM
Major12 is offline
Joined May 2012
Hey Pulsery,
For motors, I have the standard scorpion 3600kv motor and 3200 3s x 2 batteries and "Fly Fly Hobbey" 60A ESC. Im not sure if this is what I need, I have been flying nitro and this is first battery setup so Im a bit clueless on it. Any advice would be appreciated.
Still to weigh the plane once I complete the installs of the power set up.
Did you need to balance you 10 blades or where the ok from new?
Old Oct 07, 2012, 06:32 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Major12
well your using a diffrent set up that mine - I'm running 4 S
what you have sounds like the setup for the standard cs edf's
that ming sold with the kit .
CS 10 blade draw more amps so to check your system
you would need a watt meter
example:
http://www.hobbyking.com/hobbyking/s...up_Ver_2_.html
this is used to test your set up now many amps / watts your using .
I do each fan/esc then both together - you mentioned 60 amp
esc's if you drawing more than 52-55 amps you may overheat
and burn the esc out .
balance ,i did mine but they were close , running the fan and adding
power slowly you will see/hear if they are out of balance
going from nitro to electric is a learning curve
Old Oct 07, 2012, 06:45 PM
Cocg is online now
Find More Posts by Cocg
Fly and let Fly!
Cocg's Avatar
United States, CO, Grand Junction
Joined May 2010
2nd 737
Originally Posted by pulsery2k1 View Post
Major12
example:
Pulsery... In reading through all the thread yet again, Some bit ago I noticed you obtained another one (737) and was going to do some different processes... Haven't seen or heard.. What you been up to with it? Cliff
Cocg is online now Find More Posts by Cocg
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
