Old Aug 25, 2012, 05:33 PM
Seahawk One is offline
Find More Posts by Seahawk One
What tree??.......Doh!!
Seahawk One's Avatar
USA, WA, Seattle
Joined Aug 2007
Any interest in selling me your winglets since you don't plan to use em?
Seahawk One is offline Find More Posts by Seahawk One
Old Aug 25, 2012, 06:51 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Originally Posted by Smokin_Joes View Post
Vic,
Am here, just waiting on stuff i ordered to arrive.
Anybody ever try 3M's polyolefin adhesion promoter? Was going to try it to see if it helps paint stick to EPO.
Neil
No, but I will try it.....It's rather pricey, but maybe worth it??
One source ........ http://www.autobodytoolmart.com/3m-a...7-p-10854.aspx
bamaguy is offline Find More Posts by bamaguy
Old Aug 25, 2012, 08:45 PM
USA, WA, Seattle
Joined Aug 2007
Can I bought was $18.99, even at that price ( which was clearance) is not cheap.
Gonna test on EPO, depron, maybe EPP and see if I can get paint and/or epoxy to stick and not lift.
Neil
Old Aug 25, 2012, 08:51 PM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
Good show, Neil, keep us informed!
Old Aug 25, 2012, 09:47 PM
aferguson is offline
Find More Posts by aferguson
Joined Apr 2006
Smokin'....i could sell you my winglets, i guess. I'm in Canada, so shipping to you in the US will be $9.50. You can pm me with an offer if you're interested still.
aferguson is offline Find More Posts by aferguson
Old Aug 26, 2012, 05:33 AM
Pannoch RC is offline
Find More Posts by Pannoch RC
Paul B
Australia, TAS, Launceston
Joined Dec 2009
Neil
Yes I've tried it. Works well. Just don't have the nozzle too close to the foam or the carrier may attack the foam. I found holding the can 30 - 40 cm away from the foam worked. don't make a mistake with the vinyl or it will pull chunks of foam out when you try to remove it.
Paul
Pannoch RC is offline Find More Posts by Pannoch RC
Old Aug 26, 2012, 09:59 AM
USA, WA, Seattle
Joined Aug 2007
Thanks Paul!
I was considering to decant some into a jar and either brush on or push through an airbrush. Perhaps brush on for where one will glue pieces onto the foam. And/or spray via airgun for areas where I plan to paint. Definitely won't use prior to vinyl application- sound like it sticks!
Old Aug 26, 2012, 09:08 PM
Paul B
Joined Dec 2009
Thanks Paul!
Decanting and an airbrush sounds like a good idea.
Old Aug 27, 2012, 10:02 AM
jurgen01 is offline
Find More Posts by jurgen01
jurgen01's Avatar
Mexico City
Joined Apr 2007
Thanks Paul: It may be a low cost airline without leather horizontal-incline seats .... but look at the legroom.
Don't think an adhesion promoter is a good idea. I covered the fuselage this weekend and was thankful that I was able to pull off the vinyl everytime it stuck where I didn't want it to stick.
I had done the wings before and thought that fuse would be easier to do. Man was I wrong.
Even though I did the fuse in 6 sections you work with rather large pieces of vinyl and when you do this side of the fuselage the part on the other side will do all kind of weird stuff sticking to itself, to the work bench or just wrinkle, fold and mess up. Most everytime that happened I was able to release and reposition the covering (well except for one piece which messed up so well that I had to replace it). I doubt that is possible when you apply the promoter. The vinyl sticks well enough directly to the foam.
One solution is what Pannoch already mentioned: Don't make mistakes. Good luck for that.
Finally I was able to put on the covering almost without wrinkles, but I managed to "bubble" the foam on a couple of places when trying to get the last small wrinkle out. I will have to re-do completely the last 3 or 4 centimeters on the nose. When finishing putting on the second side of the nose (the very last part) disaster struck, the covering stuck to first side and lifted up the part that already was good, then the part underneath wrinkeled and finally it tore when I streched it too much. Since it was late already the best thing one can do is put it aside and try again some other day.
Will see if I can repair the nose and put on the window sticker today and then I'll show pictures.
Jurgen
jurgen01 is offline Find More Posts by jurgen01
Old Aug 27, 2012, 09:10 PM
lil hoss is offline
Find More Posts by lil hoss
wisconsin
Joined Feb 2004
Started to cover the fuse tonight. Wow,, need patience and a heat gun..
It is comming along very well.
I can sure give credit to the guys that cover the whole fuse in 1 night.
I suppose with a little technique it will be easier.
I'm sure glad I listened and NOT tried to cover the whole top in 1 piece..
I am very happy with the butt seams and the 1/8" overlap. You have to be right on top of them to see the seams
Hoss
lil hoss is offline Find More Posts by lil hoss
Old Aug 28, 2012, 10:14 AM
jurgen01 is offline
jurgen01's Avatar
Mexico City
Joined Apr 2007
The 737 got its nose job and now the finish is much more acceptable. Window and door stickers to follow.
I also finished one of the winglet light covers.
Lil hoss: It took me all sunday to cover the fuse, I logged 7-1/2 hours.
Last edited by jurgen01; Aug 28, 2012 at 11:59 AM. Reason: Comment for lil hoss added.
Old Aug 28, 2012, 04:12 PM
lil hoss is offline
wisconsin
Joined Feb 2004
Nice job on the nose Jurgen...... I found out if I get to flusterd with a problem,, come back to it another day. (Even though it bugs the hell outta me) LOL
7 1/2 hours huh. Wow that is a long time but I have about 2 1/2 hours in now and only the tail section is done. I will say the more I worked with the vinyl and hairdryer it got easier.
I'm going to give it a break for a few days. Other things to do.
Take Care
Hoss
Old Aug 28, 2012, 07:53 PM
Future Wingz is offline
Find More Posts by Future Wingz
Future Wingz's Avatar
United States, WA, Seattle
Joined Aug 2012
Hoss
Nice to hear your progress Hoss! , Just got my kit in yesterday so I shall be joining you guys on this build I must say that this is one big bird Gladly, when I opened up the box there was no damage except to the packaging and not the parts.
I now have to decide how to proceed. keep up the great work guys!
cheers
Vic
@ Jurgen01, looking great! especially those nav lights
Future Wingz is offline Find More Posts by Future Wingz
Old Aug 28, 2012, 08:14 PM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
Good to know the packaging safe the kits.
Ming
Ming is offline Find More Posts by Ming
Site Sponsor
Old Aug 28, 2012, 10:07 PM
boom is offline
Find More Posts by boom
NiCd + Mabuchi 550 was da bomb
NY USA
Joined Apr 1999
cheers
Vic
That's because customs tries to pull the foam tray out of the box and breaks a chunk off the side. Same thing happened to my friends 737
boom is offline Find More Posts by boom
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
