United States, CO, Lakewood
Joined Mar 2007
Ming, you posted these photos a long time ago. You never did explain how you attach the tail to the rest of the fuse. Tabs & bolts/screws? Or magnets perhaps?
Whenever I get mine together I'd love to be able to take the tail off. I'm thinking of using magnets like I've done on my 80'' foamy P-40. |
that is what I call some nice engineering in making all those sections removable!
well done (ming) |
Latest blog entry: Burned Retina Shorts
wisconsin
Joined Feb 2004
Well I glued the fuse together last night.
I use Gorilla glue that was posted on page 50 Post 743 by Spyro The glue is really nice and sets up fast. I taped it together over night and It seems to hold well. The Gorilla glue tends to expand a bit. On some of the seams it oozed out. I think just useing a sharp exacto and some sand paper I should be in good shape. My roll of Vinyl was sitting on my front porch yesterday. So some filling and sanding and I think I will be ready for the task of covering. I did ask this in a earlier post...... I ordered the fans from Ming with the jet. Are they going to be "ok" to use?? Is the quality decent?? Has anyone else used them?? Thanks Guys Hoss |
Australia, TAS, Launceston
Joined Dec 2009
Last night must have been the night for gluing. I too glued the fuselage together. I tested a few glue types before going with PVA wood glue.
The stock fans are fine in quality, although I changed to a more powerful arrangement. Paul |
wisconsin
Joined Feb 2004
I must say for a styrofoam model the parts sure interlock nicely.
I did some minor sanding to the fuse this evening and used a light weight filler in some of the dents and seams. Waiting for it to dry so I can give it a final sanding before I apply the vinyl. I don't remember reading in any of the post that a primer should be applied before putting on the vinyl. I think I will vinyl mine in sections like Doug W did on page 244 post 3658. Spyro did the whole top section in 1 piece. I don't no if I'm that talented Well I keep posted on how the progress is going. Hoss Does Ming still follow this forum?? |
![]() I would not attempt the one piece method without a helper to very carefully use heat gun to stretch the vinyl as you form it around the nose and tail of the fuse. Ya got to be real careful as too much heat will give the EPO a bad case of acne pock marks. They actually use a blow torch when appling this stuff on automobiles! |
wisconsin
Joined Feb 2004
Wow... Lacquar thinner. I would think it would melt it.. BUT,, I will try it. Rather than use my monocote gun I will use a hair dryer.. I do thank you for the advice Hoss |
I'm quite grateful to all the guys here and everyone's sharing of a lot of lessons that newbies like myself shall tremendously benefit from. However, I must mention that both Doug W and Sypro's instructions have been exceedingly awesome! ![]() Cheers Guys! Keep up the great work! Vic |
wisconsin
Joined Feb 2004
Lacquer thinner??????
Wow,, I hate to disagree with you Bamaguy.
I finished sanding down my fuse this morning. I was going to take your advice and wipe it down with lacquer thinner. Just for the heck of it I tried it on the foam box the kit came in. It melted it like it was next to a heat gun.. Are you sure it was lacquer thinner? OR.... Is there different types of laquer thinners that I don't no about? I think I might just wash it down with soap and water. Hoss |
| Thread Tools | |
| Discussion Windrider Boeing 737 | Ming | Scale Electric Planes | 628 | Mar 30, 2013 07:20 PM |
| New Product Boeing 737 | philipcmf | Foamy EDFs | 83 | Jan 16, 2011 09:03 AM |
| Discussion Windrider Boeing 737-700 could be a good glider | Ming | Slope | 44 | Jan 06, 2011 07:47 PM |
| Boeing 737 | jermaine | Foamies (Kits) | 6 | Apr 08, 2002 11:21 PM |
