Old Jul 05, 2012, 10:34 AM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Many thanks, Carlos!
I'll use on my WR737 #2 build..I also will use on my C130 Globemaster from Tian Sheng Model for it's flap modification.
Please be sure and post some photos on your method of flap cutting.
Best Regards,
-Gary
bamaguy is offline Find More Posts by bamaguy
Old Jul 05, 2012, 11:09 AM
aerocarlos is offline
Find More Posts by aerocarlos
Aerocarlos
aerocarlos's Avatar
Argentina, Autonomous City of Buenos Aires, CF
Joined Apr 2009
Best Regards,
-Gary
Hello again Gary
If you'll post some pictures later cutting the flaps, I tell him that it was with a 45 angle so that the hinges go into the actual plane wing simulating
a greeting
Carlos
aerocarlos is offline Find More Posts by aerocarlos
Old Jul 05, 2012, 05:28 PM
Aerocarlos
aerocarlos's Avatar
Joined Apr 2009
Hi all
Here some pictures of cutting the flap, there is two carbon rods to reinforce each half wing.
The radio to be used is a 10 Airtronic CH, and perform mixture elevator servo inverter without servos, so slow as to taste the speed of the servo flaps.
We will continue working tomorrow
regards
Old Jul 05, 2012, 08:46 PM
jurgen01 is offline
Find More Posts by jurgen01
jurgen01's Avatar
Mexico City
Joined Apr 2007
First attempts in vinyling. Not perfect, but promising. I have to be more careful, the material gets dented very easily and you don't notice it, but under the vinyl it really shows.
Nice cuts Carlos. You may want to round the upper part of the cut-off part to an airfoil shape. Somebody wrote about that earlier.
jurgen01 is offline Find More Posts by jurgen01
Old Jul 05, 2012, 08:54 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
jurgen01
the big question is now when your tail sits in the sun will the foam
under bubble up causeing problems with your nice work?
white seems to do better - dark colors get hotter and bubble
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Jul 05, 2012, 11:09 PM
Doug W is offline
Find More Posts by Doug W
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
Originally Posted by aerocarlos View Post
DOUG Thanks for your comments, share the other's good work and ideas.
Develop my building here, accept advice or opinions of all to carry a good quality of finish and the 737 flight.
I was thinking of putting these hinges for the flaps, which have reviews?
a greeting
Carlos
These flap hinges will work, but will not create the proper flap movement, because the hinge point needs to far below the flap itself. Those hinges will create a hinge point immediately below the undersurface of the wing, as opposed to about 1.5cm below where it needs to be.
I personally believe Dubro Razor Control horns are perfect, lightweight and are largely covered by the canoe fairings.
Doug W is offline Find More Posts by Doug W
Old Jul 05, 2012, 11:11 PM
Doug W is offline
Doug W's Avatar
Joined Jul 2010
Very nice job- just add the leading edge silver and you're there.
Old Jul 05, 2012, 11:30 PM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
Flap Hinge
+1..on the DuBro. However this other hinge from HK will likely do the job nearly as well. http://www.hobbyking.com/hobbyking/s...idproduct=9213
Old Jul 06, 2012, 09:25 AM
jurgen01 is offline
jurgen01's Avatar
Mexico City
Joined Apr 2007
Originally Posted by pulsery2k1 View Post
jurgen01
On the Lufthansa jets only the tail is dark blue, the rest of the plane is white. Since the tail is vertical it's not directly exposed to the sun. I only can hope it will not bubble. This is my original: http://www.flugzeug-bild.de/name/ein...Lufthansa.html
Doug: the silver leading edge is there. I might have cut it slightly too narrow (1cm wide) so it doesn't show well on the side view. If you look very closely you can notice the silver line at the leading edge.
Old Jul 06, 2012, 06:10 PM
Aerocarlos
aerocarlos's Avatar
Joined Apr 2009
Jurgen 01
good job
Spyro Consultation
you posting
I used Oracal 651 C, gray number 024. Oracal 651 series is 2.5 mil.
For the rest of it (fuselage and tail), I used Oracal Series 751 C
I used the lightest color # 056, blue ice. In the beginning of the video shows the "ORACAL 641".
Spyro you can confirm that ORACAL KLM colors for use in precisely please
thank you very much
Greetings to all
Old Jul 07, 2012, 01:02 AM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Jurgen 01
good job
Spyro Consultation
you posting
thank you very much
Greetings to all
VINYL USED ON MY 737 KLM:
GENERIC BRAND:
KLM BLUE = COLOR CODE #514 ARCTIC BLUE from:
- http://www.ebay.com/sch/precision62/...&_trksid=p3686
WHITE VERTICAL = COLOR CODE #501 WHITE from:
- http://www.ebay.com/itm/12-Adhesive-...ht_1292wt_1163
ORACAL BRAND:
GRAY WING VINYL = COLOR CODE #072 LIGHT GRAY from:
- http://www.oracal.com/products/all-c...p?seriesID=218
- http://www.oracal.com/products/product.asp?seriesID=218
You wanna see something cute? I took my American Airlines, BUT did not realize I loaded the Qantas wings in the trunk, LOL.
Can't cancel the flight, pilot took off anyway .
Here is the PICTURE
(window decals were not applied yet during this flight)
VIDEO
Spyro37 is offline Find More Posts by Spyro37
Old Jul 07, 2012, 01:31 AM
pauljohnston is offline
Find More Posts by pauljohnston
Winston Hills, Sydney
Joined Apr 2009
LOL nice color scheme.
Saw in the newspaper today that Qantas are starting an advertising campaign
where people can have their names painted on a A380 or Domestic 737.
they are looking for 700 names.I'm guessing 350 names each plane.
Wonder how Callie would go with that request for decals...
pauljohnston is offline Find More Posts by pauljohnston
Old Jul 07, 2012, 01:35 AM
Doug W is offline
Doug W's Avatar
Joined Jul 2010
Wedegtail FLIES!!!
I am pleased to report a successful maiden of my heavily modified Windrider 737- the RAAF AEWCS "Wedgetail" this evening at dusk. Two flawless flights, and only minor trim required typical of any maiden. Photos and videos to follow in the next 24 hours upon download.
I have to admit, the difference between this and my Alaska 737 was minimal- other than it flies very true when straight and level- likley a result of the large antennas and ventral fins.
Old Jul 07, 2012, 01:37 AM
Pannoch RC is offline
Find More Posts by Pannoch RC
Paul B
Australia, TAS, Launceston
Joined Dec 2009
Congrats Doug!!
Pannoch RC is offline Find More Posts by Pannoch RC
Old Jul 07, 2012, 07:58 AM
Joined Apr 2009
Great news Doug well done.
Look forward to seeing some video.
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
