Old Jun 22, 2012, 12:11 AM
Doug W is offline
Find More Posts by Doug W
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
Originally Posted by Pannoch RC View Post
Dry fit and operation of the spoiler system designed by Doug.
Having a break from the wings so started the next section - The Spyro nose wheel door mod. Its works very well.
Thanks to all the input This thread is so full of useful tips and information.
Paul
http://www.youtube.com/watch?v=muHqXnyxutY
I am confident you have the first RC 737 in the southern hemisphere with operational spoilers (that's really quite the pick up line...well, it works in the northern hemisphere).
Nice job Paul- Keep up the great work!
Doug W is offline Find More Posts by Doug W
Old Jun 22, 2012, 02:47 AM
wingnutzster is offline
Find More Posts by wingnutzster
Caravan driver
wingnutzster's Avatar
Lanseria airport South Africa
Joined Oct 2005
Originally Posted by Doug W View Post
-700s actually do not sit level- they have a very slight nose down attitude when all three are sitting on the ramp. I recess my nosegear as well simply for scale looks.
Indeed, the low nose at rest is a characteristic of all 737's right from the prototype through to the latest nexgen 900, makes for a real menacing look when she accelerates on her take off role but takes a little getting used to in my opinion when at rest.
For all you 737 and scale nuts, check http://www.b737.org.uk/index.htm
wingnutzster is offline Find More Posts by wingnutzster
Old Jun 22, 2012, 03:20 AM
Pannoch RC is offline
Find More Posts by Pannoch RC
Paul B
Australia, TAS, Launceston
Joined Dec 2009
Thanks Doug and Derek and congrats on your maiden btw!
Again I have to confess I have copied more great ideas from this thread. I have recessed the nosewheel slightly and raked it forward slightly to enable it to fully sit within the nose wheel well, similar to Doug and Spyro. This allows the nose gear doors to close properly.
Secondly, this also gives the model a slightly nose down attitude which replicates the full scale stance. It is only slight and shouldn't affect takeoff too much...... Hopefully anyway.
Thanks for the tip on the spar for the nosewheel too.
Paul.
I had better head off, I'm off to the clubs to try the new pick-up line
Pannoch RC is offline Find More Posts by Pannoch RC
Old Jun 22, 2012, 10:45 AM
hi2nr is online now
Find More Posts by hi2nr
United States, TX, League City
Joined Jun 2008
Fowler flaps
Still needs a little bit more work but they'll function in the air. Spoilers are already mocked up and ready to deploy...while im at it i could buy linear servos to make leading edge slats :P
RC 737 fowler flap test (0 min 15 sec)
hi2nr is online now Find More Posts by hi2nr
Old Jun 22, 2012, 11:57 AM
Doug W is offline
Doug W's Avatar
Joined Jul 2010
http://www.youtube.com/watch?v=aH1CngJ4wlc
Impressive- underside view? Are you using two servos for actuation?
Old Jun 22, 2012, 12:02 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
It does lower the AOA and contributes to a long take off roll and the likelihood of a climb that is a bit steeper than desired when you give the "up" elevator to break it loose off the tarmac! Makes it a bit easier to stall on take off. Just have to be prepared for it.
bamaguy is offline Find More Posts by bamaguy
Old Jun 22, 2012, 12:50 PM
hi2nr is online now
Joined Jun 2008
Windrider 737 fowler flaps bottom (0 min 25 sec)
Fowler flap top view windrider 737 (0 min 41 sec)
The bigger flaps have 2 servos. One on each pylon, the smaller one has 1 servo
Old Jun 22, 2012, 04:05 PM
jakob k is offline
Find More Posts by jakob k
jakob k's Avatar
Danmark, Midtjylland, Horsens
Joined Sep 2011
Well I just have to share this with you guys.
I have now earned the title Bc.Sc. Mech. Eng with a double major in Innovation and product design, and in Intelligent mechanisms/mechanics...
To think that I have done this at the ripe age of 30 years old with 2 kids and a wife and then on top of that, then this incredible hobby which also takes up a lot of time, then I keep wondering about how on earth I managed to get this degree.
On top of all this, then I ended up with 4 job offers before I even had gone to examination of my bachelors project(Thesis):-)
I am now employed in a company that will send me to Ming-land in the near future if I want to.
-Jakob K
jakob k is offline Find More Posts by jakob k
Old Jun 22, 2012, 07:11 PM
Doug W is offline
Doug W's Avatar
Joined Jul 2010
http://www.youtube.com/watch?v=gD1PrBu8o6o
http://www.youtube.com/watch?v=ll7pgD5q-G8
Ok, you've got me stumped...can you take the canoes off so I can see what is going on inside? And where the heck are your three servos that are operating the flaps??
And, it would appear you have spring loaded the canoes to move freely during actuation but return to flush when flaps retracted. I am VERY impressed.
Old Jun 22, 2012, 07:21 PM
hi2nr is online now
Joined Jun 2008
The servos recess inside the wings which is hidden by the foam, the hinge system is taking your concept and offsetting to fit another set inside also for the 2nd flap to pivot in the fowler motion.
I still need to add a carbon tube or metal tube with a metal wire to keep the center flaps from folding back up under deflection in order to make this functional.
I'll post pictures of the right wing once I get started so you can see the insides but here's a video of how the hinge pivot. ( I was impressed with how it looked)
Fowler hinge RC (0 min 21 sec)
Old Jun 22, 2012, 09:44 PM
Paul B
Joined Dec 2009
Very impressive hin2r!
I put the plane together to see how much "nose down" it will have after modding the nose wheel well. It turns out there is hardly any.
Old Jun 23, 2012, 02:08 AM
Phaedra is online now
Find More Posts by Phaedra
An unexpected error occurred
Phaedra's Avatar
Belgium, Flemish Region, Duffel
Joined Apr 2012
Won't the canoes of the inboard flaps touch ground at full flaps ?
Very impressive indeed !
Phaedra is online now Find More Posts by Phaedra
Old Jun 23, 2012, 08:41 AM
pauljohnston is offline
Find More Posts by pauljohnston
Winston Hills, Sydney
Joined Apr 2009
Nice job on those fowler flaps.
Glad I haven't started on mine yet as I'm now looking forward to seeing
how you did yours.
pauljohnston is offline Find More Posts by pauljohnston
Old Jun 23, 2012, 08:54 AM
hi2nr is online now
Joined Jun 2008
It doesn't, it only looks that way but they don't extend any further than the engine cowling
Old Jun 23, 2012, 03:57 PM
Doug W is offline
Doug W's Avatar
Joined Jul 2010
http://www.youtube.com/watch?v=a5nYyDUR0R0
I had a feeling you might have just added another Dubro razor control horn set to do that- very nice improvement to the concept.
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
