Old Jun 18, 2012, 09:33 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
DerekB
Thanks , I have built several models using miniwax polycrylic
and tissue with very good results - all the finish's have lasted
without problems . when I finished my first 737 it looked very good
till it sat in the sun for 3 days at the NEAT fair
the sun caused the foam under to develop the little bumps and
the tissue lifted in a couple of area's , I was able to repair it
but you can see the bumps if you look close .this is a comon problem
with this type of foam , some model come with warning to keep model
out of sun.
I building a large BAE hawk (same kind of foam) but have come
up with a glass lite - I used 20 min finished -cure epoxy and the heavist
tissue I could get mixed it 75% epoxy 25% alcohol and applyed it the
the same way as with the WBPU
so far the results look excellent , and hopefully will not get the bumps under
the finish . I have lived in Florida so I know how hot it get's down there.
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Jun 18, 2012, 10:31 PM
DerekB is offline
Find More Posts by DerekB
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Originally Posted by pulsery2k1 View Post
DerekB
out of sun.
Thank you for the details about epoxy. Your models look fantastic. I think I will try epoxy next time to make a more rigid surface. I like the 3/4 ounce glass cloth because it wraps nicely around compound curves. But with only WBPU, the surface can dent easily. I will try to keep mine in the shade.
I did not think about thinning the epoxy with alcohol. What kind of alcohol, denatured alcohol or isopropyl? I am not a chemist, so no idea what the difference is.
DerekB is offline Find More Posts by DerekB
Old Jun 18, 2012, 11:59 PM
Doug W is offline
Find More Posts by Doug W
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
[QUOTE=DerekB;21932850]Microphone rig. The chicks dig it too.[QUOTE]
It's probably the fur...
Doug W is offline Find More Posts by Doug W
Old Jun 19, 2012, 12:01 AM
Doug W is offline
Doug W's Avatar
Joined Jul 2010
DerekB
BAe Hawk is coming along nicely Pulsery- I like that glassing technique. I might try that sometime.
Old Jun 19, 2012, 12:36 AM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
ive done a couple of glassing jobs myself. have any of yall ever used baby powder mixed with your wbpu, to help fill in cracks & voids. whenever i paint my aircraft with craftsmart or the waterbase paints, i mix in some wbpu with the paints. it keeps the paint from turning out so dull & dry looking. also makes the paint more durable.
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Jun 19, 2012, 03:37 AM
jakob k is offline
Find More Posts by jakob k
jakob k's Avatar
Danmark, Midtjylland, Horsens
Joined Sep 2011
Derek B>>>>
About power. Did you take up the landing gear during flight?
Mine is very underpowered with landing gear down, but in the up position then my plane has more than enough.
About wind, I have flown mine in no wind and in a lot of wind, The only issue I have with this aeroplane is that it flexes too much so it feels like you have no control over it when in alot of wind (About 10-15 m/s or 22,5-34mph).
These type of winds is regular wind conditions in denmark.
If I only wanted to fly in close to no wind, then I would never get to fly this bird due to the weather here in Denmark.
But great video.
-Jakob
jakob k is offline Find More Posts by jakob k
Old Jun 19, 2012, 07:55 AM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
The weight is an issue.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Jun 19, 2012, 02:54 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Originally Posted by jakob k View Post
Derek B>>>>
But great video.
-Jakob
I left the gear down. The 2 main gears were sticking during pre-flight test. I could always get them to keep moving by cycling the gear switch, so it never stuck permanently. But I did not want to risk it on maiden flight. My nerves could only handle so much.
On my next flight (hopefully this Sunday), I will use take-off flaps, and also pull the gear up right away. I will commit to 10 flights at least before I decide to change anything.
Old Jun 19, 2012, 10:50 PM
Hawaiian Flyin is offline
Find More Posts by Hawaiian Flyin
Hawaiian Flyin's Avatar
United States, HI
Joined Dec 2007
Jakob- I hear you about the wind. I have the same problem. Yesterday it was blowing at 80+ mph where I work.. Think it was about 40mph at the field.
I usually only have free time to go fly about 10 times a year on averege and it seems to be blowing on all those days!
Doug. Those retracts you got from PWC rc. How long did it take to get them once ordered? How much was the shipping? Thinking of swapping mine out since lots of people have issues with bending.
Hawaiian
Hawaiian Flyin is offline Find More Posts by Hawaiian Flyin
Old Jun 20, 2012, 06:54 PM
swarick is offline
Find More Posts by swarick
Stay Thirsty My Friends
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
Originally Posted by erh7771 View Post
I've ordered this plane from WindRider...
What is the easiest way so far to get current Southwest Airlines colors on it?
Regards
My 737 was airbrushed by a friend of mine here in Gilbert, Arizona. Unfortunately paint or vinyl covering will be the only way to do the SWA scheme.. The decal manufacturers I know of only make decals when the scheme is based on a white airplane.
Rick
swarick is offline Find More Posts by swarick
Old Jun 20, 2012, 08:36 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
DerekB
to be honest I don't know the diffrence between denatured alcohol or isopropyl
I used isopropyl and it worked well.
I will make a video of how I did it
this is of mini wax polycrylic and tissue
ployglass.wmv (3 min 2 sec)
Hawaiian Flyin
I ordered the retracts from
http://www.pw-rc.com/product_info.php/products_id/2631
took about a week and less than $10 but I order other things too
great service - they ship next day even with cheap shipping
Old Jun 20, 2012, 09:07 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Isopropyl is the kind to use....it contains 91% alcohol and 9% water. It's the medical type. "Rubbing" alcohol has a lower % of alcohol and some type of an oil...as well as water.
bamaguy is offline Find More Posts by bamaguy
Old Jun 21, 2012, 04:17 AM
Pannoch RC is offline
Find More Posts by Pannoch RC
Paul B
Australia, TAS, Launceston
Joined Dec 2009
Dry fit and operation of the spoiler system designed by Doug.
Having a break from the wings so started the next section - The Spyro nose wheel door mod. Its works very well.
Thanks to all the input This thread is so full of useful tips and information.
Paul
Windrider Boeing 737 spoiler system (0 min 20 sec)
Pannoch RC is offline Find More Posts by Pannoch RC
Old Jun 21, 2012, 09:32 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Paul
http://www.youtube.com/watch?v=muHqXnyxutY
The spoilers are looking very sharp! When they are up, it will expose the flaps and look really cool and show off how the flaps are really hanging out there.
One tip someone told me was to reinforce the nose gear mount - add a hard wood spar, about 2" to 3" long on each side, right above the plywood plate. I never got any photos of mine. Just cut a slot in the foam right above the plywood and glue in the spars, then the plywood plate will glue to those spars, as well as the foam.
Did you recess the nose gear to get the wheel all the way up into the well? If so, how did you compensate to keep the plane level on the runway?
Derek
Old Jun 22, 2012, 12:07 AM
Doug W is offline
Doug W's Avatar
Joined Jul 2010
Derek
-700s actually do not sit level- they have a very slight nose down attitude when all three are sitting on the ramp. I recess my nosegear as well simply for scale looks.
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
