That's a good question about the window reflection. At first, I thought the way you show it, but this photo seems opposite, with the lighter highlights at the top. It's going to be a tough call. |
Winston Hills, Sydney
Joined Apr 2009
I would think that it did not matter which way you install the windows.
It would depend on time of day and angle of the sun. eg. If aircraft is on the ground at the airport and it;s around noon I would expect that bottom of window would get more sun than the top' Also if aircraft was flying north and it's afternoon then probably starboard side will be in shadow. Paul |
.It looks you are the right expert for window reflections, no doubt. The good news is, there is no right or wrong for the window stickers! |
Here's some photos of my final assembly of the wing.
Looks very nice Derek- really clean workmanship. Two recommendations- for the gray tape you are looking for to attach the ESC grills, use the gray Oracal I cover my wings in. I used that to attach the grill on my Alaska and it hasn't as much as flinched. Second item- don't forget the wing walk black lines on the top of the wing. Automotive pinstripe I found is easiest. Also, pay close attention to United/Continental's wing walk lines- not every carrier uses exactly the same format (even though yes, I know, it is the same plane.) There are tiny differences.
Nice job again- beautiful ship you have there. (I of course love the flaps) |
Brisbane, Australia
Joined Jan 2007
Looking Good
That workmanship looks fantastic.
Can you tell me type of hinges you are using for the flaps. I know I saw it somewhere in the thread ages ago but I don't want to go through it again. I've got Mings 787 and really need to get a start on it. The information I've gathered from this thread has been extremely helpful. Peter |
Joined Apr 2009
Great work Derek. Very neat finish.
I've just received my hinges for the flaps from Tower Hobbies this week. Peter the hings are Dubro Micro Razor Control Horns (not called hinge) You may be able to buy locally but when I was in Brisbane a couple of weeks ago Xtreme RC did not have stock and all the Sydney model shops wher out of stock too. Paul |
Regarding "wing walk" lines, I knew there was some kind of lines on top of the wing, but did not know the purpose. Also, I have not found a top view that shows this. All of the real photos are from the side or below. Not too many photographers get the bird's eye view. Any idea where I can get a decent photo? AND, I heap great praise upon you for the flaps design. It is really fantastic. The flaps push straight back and down. I will make a video of mine in the next few days. Again, great job. I did a test run up of my twin Change Sun 70mm 10 blade fans with the thrust tubes. Engine #1 has a wee bit of vibration I need to balance out. But, OMG, OMG, (did I say OMG ) you have got to hear this. It's sounds like twin turbines. Sooooo sweet. I ran out of time to make a video, as you see, it's past 3 a.m. and I'm fried.
Again, credits to DougW for that one. Recall a key point to Doug's design is the horns which fasten to the wing need to be on the outboard. The horns on the flaps are inboard. This keeps the flap in position. I'm not sure if that concept shows clearly in my photos. I'll try to post a better shot. |
| Thread Tools | |
| Discussion Windrider Boeing 737 | Ming | Scale Electric Planes | 628 | Mar 30, 2013 07:20 PM |
| New Product Boeing 737 | philipcmf | Foamy EDFs | 83 | Jan 16, 2011 09:03 AM |
| Discussion Windrider Boeing 737-700 could be a good glider | Ming | Slope | 44 | Jan 06, 2011 07:47 PM |
| Boeing 737 | jermaine | Foamies (Kits) | 6 | Apr 08, 2002 11:21 PM |
