Old May 05, 2012, 03:01 AM
Depressed, Enraged and DF CEO
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Good To hear Jakob! Did you Get any Footage??
Keenan
Keenan smith is offline Find More Posts by Keenan smith
Old May 05, 2012, 05:03 AM
jakob k's Avatar
Danmark, Midtjylland, Horsens
Joined Sep 2011
Boeing 737 Qantas på RCParken Søgaard (0 min 37 sec)
Boeing 737 Qantas på RCParken Søgaard (1 min 18 sec)
As you can hear and see from the takeoff then there is wind present:-)
-Jakob
jakob k is offline Find More Posts by jakob k
Old May 05, 2012, 09:33 AM
Phaedra's Avatar
Belgium, Flemish Region, Duffel
Joined Apr 2012
Nice going, Jakob !
Did you (have to) balance these EDFs ?
Phaedra is offline Find More Posts by Phaedra
Old May 05, 2012, 03:52 PM
jakob k's Avatar
Joined Sep 2011
Originally Posted by Phaedra View Post
Nice going, Jakob !
oh yes.... and it took quite a while. I did it as sergey has made a tutorial about. luckily i had an extra set of housings, since one housing broke in the motor mounting while measuring with the accelerometer.
I hope you also can tell from the sound on the videos that I've done a quite a bit of work on getting them balanced. The only thing I would say is anoying is that I have a point about 30% throttle where they vibrate and its easy to hear. But from 50-100% they sound awesome, but still this is not an overpowered setup (eco set with 3800kv motor).
Doug>>>> How many KV are yours?
-Jakob
Old May 05, 2012, 06:26 PM
Joined Jan 2009
Hi there,
concerning take-off from grass:
Hereīs a video of my 737sī maiden flight taking off from grass.
She is powered by 2 Wemotec minifans with Het 2W23 running on 1 5S 5000mAh battery.
Total static thrust is approx. 2,8 kg at 90 Amps. AUW 3,5 kg.
She has plenty of power and does not even need full thrust to take off from grass.
P1090659.MOV (0 min 15 sec)
Greetings
Michael
michi3 is offline Find More Posts by michi3
Old May 05, 2012, 06:52 PM
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
Originally Posted by michi3 View Post
Hi there,
http://www.youtube.com/watch?v=azGeN...hannel&list=UL
Greetings
Michael
First, excellent soft field take off technique and power reduction after rotation. I think you may have the most powerful W737 flying right now. HET2W-23 on a 5S? Whoa!
Doug W is offline Find More Posts by Doug W
Old May 05, 2012, 07:13 PM
Joined Dec 2010
5s ?? Man you are Crrrrraaaaazzzzzy!
Old May 06, 2012, 03:18 AM
Paul B
Australia, TAS, Launceston
Joined Dec 2009
Hi there,
Greetings
Michael
Thats good to see, mine will have just over 3kg of thrust and will be off grass. Gives me confidence.
Cheers
Pannoch RC is offline Find More Posts by Pannoch RC
Old May 06, 2012, 04:11 AM
jakob k's Avatar
Joined Sep 2011
Cheers
What is your power setup?
-Jakob
Old May 06, 2012, 05:28 AM
Paul B
Joined Dec 2009
-Jakob
I'm using Extreme RC's 10 blade fan combo, fully balanced in a custom alloy housing using HET motors with 80A ESC's. 1.5kg of thrust, 900W at 14.8V (each). Even more on 5s.
Always fly off grass so I need a bit of oomph to get of the ground.
Paul
Old May 06, 2012, 04:45 PM
jakob k's Avatar
Joined Sep 2011
Do you guys think I will be able to try 4c battery on Mings Eco set with 3800kv motor and 50A ESC?
If not what should I do.
Buy new batteries+ESC+Motors?
I really want to take off from our grass field!!!!
Ive read through this thread and what I can tell from ming's post then the 3cell setup with the 3800kv motors draw about 35A, so shouldn't I be safe to try 4 cells on the same setup? I will only give WOT for a maximum of about 5-10seconds.
-Jakob
Old May 06, 2012, 08:26 PM
Doug W's Avatar
Joined Jul 2010
Wedgetail Update
Progress today...raised the nose gear bay (as I did on the Alaska 737) to give the slightly nose down angle to the -700 when parked. Forgot how much of a pain that is as a mod. Ventral fins are done, nose gear is tested, battery hatch modified (I made it smaller) to accept the upper fairing (which is a half inch too tall in the photos- it will be recessed for structural intergrity into the fuse slightly)...engines are fit and test run, I just need to glue the cowlings togther.
First flight is in June...
Old May 07, 2012, 09:43 AM
Phaedra's Avatar
Joined Apr 2012
-Jakob
According to Windrider's own website, you can run this motor on 4S :
http://www.windrider.com.hk/product.asp?id=197
They talk about 30A on 3S, and 46A on 4S.
This means that you can run it on 4S, but you need another ESC to be safe. Some say you need some 25% margin on your ESC, but as you state it, you wouldn't need this current all the time.
I would suggest to run the motor + EDF combo with a power meter and get an idea of the current for each motor regime, and monitor the temperature of the ESC.
Another risk might be the higher RPM, since you have a higher voltage with 4S. Question is if the EDF unit is solid enough for this extra RPM.
Old May 07, 2012, 09:59 AM
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Short bursts with 50amp ESC should be O.K. But I would use a separate power source for receiver/servos/retracts.....that will keep some heat out of the ESC.
The fan unit will be fine on 4S (mine are still working!)
bamaguy is offline Find More Posts by bamaguy
Old May 07, 2012, 10:02 AM
Ming's Avatar
Hong Kong
Joined Jun 2002
Suggest to short trim the grass.
Ming
Ming is offline Find More Posts by Ming
Site Sponsor
Discussion Windrider Boeing 737 Ming Scale Electric Planes 628 Mar 30, 2013 07:20 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 44 Jan 06, 2011 07:47 PM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
