Old Feb 17, 2012, 01:16 AM
DerekB is offline
Find More Posts by DerekB
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Originally Posted by markyb13 View Post
hey guys just wondering is everyone using the the 1 1/2 wheels for the front and 2" for the mains
I re-read the earlier posts where everybody was discussing wheel size, and yes, 1-1/2" front and 2" mains was the consensus. I went out on a limb and ordered Scale alloy hub rubber wheel, the 2" and 1-1/2" size.
DerekB is offline Find More Posts by DerekB
Old Feb 17, 2012, 04:05 AM
pauljohnston is offline
Find More Posts by pauljohnston
Winston Hills, Sydney
Joined Apr 2009
Thanks for the edf install tips Derek.
I have had my 737 for about 6 months now and still haven't started the build.
I have a few projects going at once for myself, my son and a couple of my club mates.
Hope to get to the 737 very soon now.
pauljohnston is offline Find More Posts by pauljohnston
Old Feb 17, 2012, 04:06 AM
Joined Apr 2009
Old Feb 17, 2012, 05:00 AM
carrerars is offline
Find More Posts by carrerars
carrerars's Avatar
Joined Aug 2008
Hi all,
regarding wheel and tire sizes.
In mine I'll have full scale tire sizes which means:
main tire is dia 65mm
aux tire is dia 40mm
Btw. yesterday I got the gear covers for aux gear running.
Markus
carrerars is offline Find More Posts by carrerars
Old Feb 17, 2012, 08:49 AM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Originally Posted by carrerars View Post
Hi all,
Markus
Markus,
If 65mm (about 2-1/2") is the right number, that's what I want. I swear I read the earlier builds where using 2". Rats, I just ordered four of the 2". Ming's wheels are about 2-1/8". How did you know 65mm is correct scale? I totally forgot that I have the scale CAD file directly from the Boeing website - I should open that and measure.
Do you have any details or photos of how you did the front gear doors?
Old Feb 17, 2012, 10:30 AM
carrerars's Avatar
Joined Aug 2008
Derek,
somewhere in this thread it is said that windriders 737 is scale 1:17.
737-700 original has main tires are 44.5 inch
and aux tires are 27.7 inch.
Multiplying these by 2.54 (to have cm) and divided by 17 is main 66.5mm
and aux 41.4mm.
http://www.bridgestone.com/products/...plications.pdf
Inspired by Spyro I took the gear cover of FMS Trojan and cut it to scale.
Markus
Old Feb 17, 2012, 10:50 AM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
carrerars
I like the thin wheels were did you get them.
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Feb 17, 2012, 12:38 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Derek,
and aux 41.4mm.
Markus
I love it! The actual tire specs!! That's what so awesome about these forums.
I read the scale was 1:18. Either way, the main wheels would be 2-1/2". I'm going to jump onto Hobby King and see if I can cancel my 2" order. I don't like airliner models with puny looking wheels.
The scale CAD drawing from Boeing was no help on the wheel diameter - they measure too small. Wheel diameter was not the main purpose of those particular CAD drawings anyway.
Old Feb 17, 2012, 12:43 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Looks like it's too late to cancel my order for the 2" wheels. Oh well, wasted $12. Now I have to find another airplane to build that needs some nice 2" wheels .
I'll put them on when I get them and see how they look then decide. Easy enough to swap later.
Old Feb 17, 2012, 03:23 PM
carrerars's Avatar
Joined Aug 2008
.... that's exactly what I always do... lot of wheels and tires
Oh no it is 1:18 ??? So I have to look for a differnet set.... nonono
The tires and wheels are from this fabulous set:
http://www.hobbyking.com/hobbyking/s...in_Trike_.html
Whenever I see it I want to build an executive jet around them.... addicted
Markus
Old Feb 17, 2012, 03:40 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
carrerars
thanks , I have those they seem a little small .
executive jet if your looking for one ,I have this one and it flys great
http://www.hobby-lobby.com/executive_jet_2295_prd1.htm
Old Feb 17, 2012, 03:45 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
ill buy e'm off ya !
Keenan smith is offline Find More Posts by Keenan smith
Old Feb 17, 2012, 04:29 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Originally Posted by pulsery2k1 View Post
carrerars
That is a nice jet! Could the Change Sun 70 mm shroud fit in there? I still want "swoosh" only. It looks like maybe the stock shrouds are integral with some kind of structure that goes to the fuselage, thus you are stuck with the stock shrouds?? If stuck with stock shrouds, what's the motor can diameter? Others have shaved down the CS 70mm 10 blade rotor to fit 64mm shrouds.
One good idea often leads to another..... I noticed the landing light kit for that jet could work for the 737. Probably just need to extend the wires.
I also found this gear door sequencer at HK as an option to the one Spyro is using.
Old Feb 17, 2012, 05:40 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
DerekB
the executive jet
uses 68 mm fans , that are bolted to a wood mount were a
70 mm would probly fit - the extra weight would effect balance
and the stock fan's and recomended motors work well more
then enough power
hobby-lobby.com Executive Jet (1 min 3 sec)
Old Feb 17, 2012, 06:44 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
At over $100....that is way too pricey! I think the system from Dimension Engineering runs a bit less????
bamaguy is offline Find More Posts by bamaguy
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
