Answer to 3) - start reading post #1 of this thread. And I mean that seriously. I have my kit now, and I started re-reading today. |
Lighting system
I really did start re-reading today in search of what lighting system to order. I liked Sergey and Spyro37 - really great, but I found they cheated! Sergey is an electronics genius and made his own controller - rats. Then helped Spyro, who also is an electronics genius - double rats. Several of their lights had strobe and they were synchronized to alternate, just like the real one (I presume like the real one - Sergey was very meticulous). I think simple ordinary static LED would be a bit boring compared to the correct strobe - especially the correct alternating sequence. The video of Spyro at dusk was awesome - the strobes showed up really well, just like they are supposed to.
Watch Spyro3's video at 5:30 and the maiden flight around 6:40 to end. I NEED lights like that .Any ideas for commercial products that provide the same true strobe looks for the correct lights, strobe, locations and colors? And alternating sequence? Or do we have to bribe Sergey to start production? Derek
I have bought these for a couple of my planes now:
http://www.giantcod.co.uk/night-flyi...-p-405040.html I know Hobbyking have a set similar |
However, I noticed Spyro37's red and green wingtip lights were strobing. And that strobe was alternating with the strobe on the fuselage. Does anybody know the exact timing and sequence of all the lights? I think this Dimension Engineering DeLight starter kit can be programmed for any sequence. I don't mind spending the money to get it right. Sergey posted many photos of the light locations on 737 here, but obviously you can't tell which ones strobe, and the timing sequence. |
I don't know the exact sequence, bit I do know that the greens and red lights on the wingtips (position lights) should be steady. Behind the position lights are white strobe lights. In the tail you should have a steady white position light. Red anti-collision lights on the top and bottom of the fuselage should flash.
For those interested in when to turn on which lights: position lights (red/green on wingtips, white on tail, all steady): always on anti-collision lights (red on fuse, flashing): on at engine start, off at engine shutdown strobe lights (white on wing tips): on when entering the runway, off when leaving the runway taxi light: on at start of taxi taxi, off before takeoff, on after landing, off when approaching the gate landing lights: on when cleared for takeoff, off after landing (and off above 10.000 ft )
Fotor,
Thanks, that's great help. The white wingtip strobes, "off when leaving the runway", do you mean leaving the runway as in lift-off? Or leaving the runway as in after the flight is over, thus the white strobes are on for the full flight including while on the runway? I watched Spyro37's video again, starting at 5:30, and his green and red position lights at the leading edge of wingtip, flash twice. So, even though it looks cool, it's not technically correct. They should be steady. Then the red on fuselage flashes twice. Maybe it should only be once? I will just presume Spyro was going for cool effect and I'll try to figure out what is the correct sequence and timing. That DeLight system is supposedly fully programmable 6 channels for any sequence and duration using their software and USB link. |
DerekB
you turn the strobes as you enter the runway for takeoff and turn them off as you exit the runway after landing . the mars rotating beacons one on top one under the fuse are on when the engines are on - as statment states rotating beacons which seem to flash at a steady rate as fotor mentioned the position lights red /green /white are on steady it helps tell you which way the other aircraft is traveling I have found except for a good set of strobes its hard to see the other lights during the bright part of the day |
Joined May 2011
hey derekb i was having same lighting issue what to buy check out www.vcshobbies.com they sell a custom made lighting system for 50 bucks.they make it for an a330-300 plane that looks to be the same scale as ours.comes with the light covers to.didnt get mine yet has them on backorder gonna try it out.
That's pretty cool how they create the effect that appears to be rotating.
- My lights were not based on the full scale 737, which I purposely chose. It wasn't a kit either. Parts were purchased from different vendors. Brightness is visible even at 200feet during the day. I can still switch terminal plugs and add more lights, but I like it the way it is.
- Other mods I did that you guys might be interested: http://www.ebay.com/itm/3-x-D4mm-L57...ht_2394wt_1068 used as landing gear wire. 737 will break on landing but not these. If you want less work (not as strong) but won't bend unless you land really hard: http://www.ebay.com/itm/SUNNYSKY-220...ht_2223wt_1037 - Highly recommend these quality METAL gear servos for flaps use. I've been using them for while now with great experience. These will not "deteriorate" from the stress that the engine THRUST directed towards the flaps. After countless flights on my 737, my 9gram nylon flap servos are not performing the same anymore when they were new. Bad thing is, if the servos' torque are not equally the same, one wing will have more lift than the other . I got addicted to the flaps, and possibly caused to degrade it's (nylon gear servos) performance. This is what I use now on my flaps, (& has been using them for my jets and balsa 3D planes). High torque, foam will break, but these won't "give". Just my 2 cents... http://www.hobby-lobby.com/9_gram_pr...ueryId=3449694 - Spyro |
Spyro,
You continue to amaze me with your ingenious resources!! So we are on our own for lights , - that's OK . For the lights, I'm leaning towards the DELight system I linked above. Their LEDs are $5 each "15 lumens, 120 degree beam angle, half-watt surface mount LED, an appropriate current-limit resistor and a 24" lightweight wire pigtail terminating in a universal servo-type connector." Is this similar brightness to yours? Also, any other LED can be used.The DELight controller can be programmed to activate the landing light with the retract switch. For the retracts, I will order both shafts, but use the 3mm motor shafts first, for less work and see how it goes. I presume the C-clip from the stock gear will work on the 3mm shafts? I don't have any spares - do you have a link for C-clips for 3mm and 4mm shafts? Any other special parts for the gear mods? I'd still like to know how you did the sequencer for the front gear doors .The metal gear servo on the flaps is a great idea. I will get those since they experience constant force. Do you still like the Detrum/Dynam 9 gram servos for the other control surfaces? Thanks, Derek |
DELight Light Kit
Before ordering the DELight Starter Kit, I downloaded their DELink programming software to give it a try. Quite easy to use. For the fuselage, I managed to program the effect of a rotating beacon, and control exactly how long it stays on, how it ramps up, how bright, etc. And I sequenced the timing of the white wingtip strobes to occur in between the beacon strobe. Very cool
and very flexible. And of course a Taxi light can be programmed to come on when the gear is down. It can do lots of other things also. 2 of the 6 the channels are 6 volts 2 amps - you could ignite some pyrotechnics!For what you get, I think the price is right. In the simulator window, you can import your own image to test and simulate moving the transmitter sticks/switches to see what comes on when. Here's a screen shot, but of course it doesn't show you the beacon flashing or the strobes flashing! |
1. Yes, Dentrum works great! & still recommends. 2. For flaps, I recommend metal gear or you're taking chances. http://www.hobby-lobby.com/9_gram_pr...ueryId=3450105 3. for steering servo, the same metal gear, or 9gram nylon could strip on landing as well. 4. 4mm - http://www3.towerhobbies.com/cgi-bin...?&I=LXYCE9&P=7 or http://www.hobby-lobby.com/9_gram_pr...ueryId=3449694 5. 3mm - http://www3.towerhobbies.com/cgi-bin...?&I=LXYCE8&P=7 *Main gear does not need C-clip, hex grub screw is all it needs to hold/lock the wires in place. 6. sequencer - http://www.pw-rc.com/product_info.php/products_id/2207 7. Door - http://www.pw-rc.com/product_info.php/products_id/2374 I used dremmel and Heat gun to size and shape it with the 737 nose. PLEASE MAKE SURE TO BE COMFORTABLE WITH THIS MOD. If not done nicely, door or doors may NOT open before landing. I have never had any issues with mine so far. Just remember that there are 2 nose wheels, make sure that none of them would "jam" when door closes/opens. I cycled mine a hundred times before maiden (upside down and upright position). My lights: 1. http://www.flytron.com/rc-light-syst...light-red.html 2. http://www.flytron.com/rc-light-syst...ght-green.html 3. http://www.flytron.com/82-60-lens-for-powerleds.html - I did NOT use the casing. 4. http://www.lazertoyz.com/shop/LightKits/LZLTMTCD0.jpg FROM : http://www.lazertoyz.com/shop/RCLights.htm I DO NOT RECOMMEND MY NAV LIGHTS THE WAY I DID IT. With the same light system, I do RECOMMEND this for less money, less work, more options, simplicity & etc. I made my own because I don't know whom to ask and don't know of any one that knows better. I found LAZERTOYZ, only after I figured out my own design. Have I tried Lazertoyz module? NO. But sure won't recommend it if am not confident about it. I have recommended this to one of the RC "guru" here in RCGrps, and he can't be happier about the results after so many lights he has tried and spent before. 1. http://www.lazertoyz.com/shop/LightKits/Maxi-Lights.jpg 2. http://www.lazertoyz.com/shop/LightKits/LZLTMTCD0.jpg BOTH from: http://www.lazertoyz.com/shop/RCLights.htm 3. THEN USE THESE, BUT you may want to contact and ask Lazertoyz and find out how well the module will "power-up" 1 watt LEDs all at once, since I have NOT tried it as mentioned. a. http://www.ebay.com/itm/160726243535...#ht_593wt_1270 b. http://www.ebay.com/itm/10x-1-Watt-1...ht_3028wt_1270 c. http://www.ebay.com/itm/10x-1W-High-...ht_3086wt_1270 d. http://www.ebay.com/itm/20-LED-Clear...ht_2268wt_1037 OR JUST SEARCH EBAY FOR BETTER PRICING * Lazertoyz will have your stuff at your doorstep in 3-5 days, USPS * Flytron, about 4-6weeks at least! Turkish Mail Words from Flytron: It is allowing 2 different working modes, RC mode or Standalone. Power it with directly from battery (4-6v) it works on Standalone mode and strobes continuously. Plug it on your RC receiver’s any channel for RC mode, then you can On/Off it over servo channel. We tested it since months and followed the flashes from 2km at the dark without any problem. * my klm with 60 degree diffuser: http://static.rcgroups.net/forums/at...4-P9173134.jpg http://static.rcgroups.net/forums/at...5-P9173132.jpg NAV LIGHTS As a copy and paste to your inquiry (PM) and to share with others: I HIGHLY RECOMMEND THESE METAL GEAR servos for flaps use or even for the rest of the control surfaces. I have nylons on my flaps and has been addicted taking off, flying, and landing with flaps. But after lots & lots of flights, the nylon gears is NOT performing the way it should be anymore due to the amount of flights & thrust that my motors BLOWING towards my flaps. Servos sometimes do not center anymore, or "gives", compromised torque, and etc. And when one side (flaps) does not equally perform as the other side, they act as an aileron in the air! ![]() BOTTOM LINE, high torque servos are recommended due to engine thrust pushing the the flaps. I have been using these servos http://www.hobby-lobby.com/9_gram_pr...ueryId=3450105 and guarantees its performance and price is a smart BUY!Others may have not experienced nylon flap servos GOING BAD, but I fly a lot. I never had trouble in the beginning, and wished I used metal gears. They are now replaced, but again, repairs is much more difficult than doing it right the first time. -Spyro THOUGH I USE 1OAMP CC BEC ON MY RECEIVER, I RUN A DEDICATED CHEAP 3A BEC FOR MY LIGHT SYSTEM/DESIGN. This will give me a piece of mind that my lights' power consumption does not interfere with the receiver. Or any short from wirings, strobe module short, burn out & etc. will not affect the receiver (not good if there would be & they all share one BEC). Same thing why Automobils isolate/separate fuses. My BECs are SOLDERED with the ESC's + & - terminals. As seen on my video, I have VERY minimal (4) terminals that I have to plug-in, & the wing bolts to get up flying ,Using the FMS sequencer above, PLEASE "sequence" or cycle your door/retract switch TWICE before take off. FMS retracts is not same as ChangeSUN HAVE FUN ON YOUR BUILD GUYS. Still enjoys flying my KLM., Happy landings... -Spyro (I don't usually check the thread, sorry...) EDIT (08/23/2012): I HAD THE CHANCE TO TRY OUT THE MAXI-LIGHTS CONTROLLER MODULE. NOT IMPRESSED WITH THE LIGHT INTENSITY USING 1 WATT LEDs. |
| Thread Tools | |
| Discussion Windrider Boeing 737 | Ming | Scale Electric Planes | 628 | Mar 30, 2013 07:20 PM |
| New Product Boeing 737 | philipcmf | Foamy EDFs | 83 | Jan 16, 2011 09:03 AM |
| Discussion Windrider Boeing 737-700 could be a good glider | Ming | Slope | 44 | Jan 06, 2011 07:47 PM |
| Boeing 737 | jermaine | Foamies (Kits) | 6 | Apr 08, 2002 11:21 PM |
