Old Feb 12, 2012, 11:22 PM
DerekB is offline
Find More Posts by DerekB
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Originally Posted by Doug W View Post
I'm running a Catle 10A BEC, programmed to 4.8V as all my servos are 4.8V (as opposed to 6V)
I'm using the venerable Hextronix HXT900 9 gram servos, since I have a box of them. Guys say they are fine at 6 Volts, but the data is stated at 4.8V. The 8 amp Exceed-RC UBEC says it can be set for 5 or 6 volts, so I'll set it for 5.
Any idea what the retracts need for volts and amps? Have to figure 5 other servos could be moving while the gear goes up or down (presuming flaps are done at a different time than the gear).
Here's some guys test data on the HXT900 servos
4.8v 160ma/290ma/690ma/0.14 sec per 60 degrees
6.0v 190ma/370ma/690ma/0.11 sec per 60 degrees
I don't know why there are 3 different mA numbers. But if we take worst case of 690 ma x 9 servos = 6.2 amps (assumes fighting massive turbulence on all controls while flaps coming down). I think I'm good with 8 amps. I guess with flaps extended, that puts constant load on 4 servos.
On the real bird, for landing, do you put flaps down first or gear down first? Likewise on takeoff, which comes up first, gear or flaps? As a passenger, I never paid much attention. Now I need to learn so I can look really scale
DerekB is offline Find More Posts by DerekB
Old Feb 13, 2012, 08:28 AM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
DerekB
flying the real the 737 the gear is retracted first and then the flaps
on landing the flap are lowered in stages and the gear usally
at the outer marker approx 5 miles from the runway
also the slats and flaps are coupled on the flap lever
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Feb 13, 2012, 08:41 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
^^ditto
same on FSX im at the 5 mile marker from the airport they use the housing estate three blocks down as the marker so i see the gear coming down all the time
Keenan smith is offline Find More Posts by Keenan smith
Old Feb 13, 2012, 10:42 AM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Originally Posted by pulsery2k1 View Post
DerekB
Thanks.
I think I will remember this by "the gear is first up and last down".
So on takeoff, the first switch to hit is the gear. I have a 600 foot runway at the club. With flaps, I'll only need about the first 50 feet, so the gear can be coming up as it passes the main pit area, but flaps still down. That will be cool . Everybody likes to see the gear come up.
It makes sense on takeoff, they want the gear up fast as possible to reduce drag and build airspeed, while still getting good lift from the flaps.
On landing, no sense putting them down until landing is for sure. For landing at the club, it'll be cool to do a low speed flyby with full flaps hanging down and put the gear down while passing the pits. Then loop around for landing.
I gotta get building!!
Old Feb 13, 2012, 10:55 AM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Be careful on that "loop around for landing"! You may really excite the crowd by auguring that baby in. If you're low, slow and dirty and turn too tight it WILL stop flying
bamaguy is offline Find More Posts by bamaguy
Old Feb 13, 2012, 11:58 AM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Yah, I hear ya!! I need to remember this is not 3D ship - not going to punch throttle and knife edge out of it. I will of course practice carefully to get to know the stall character before trying to show off for the crowd .
Old Feb 13, 2012, 12:10 PM
N437D is offline
Find More Posts by N437D
N437D's Avatar
Houston, TX
Joined Feb 2006
I'm looking into getting one of these kits. I just have a few questions from the members here.
1) Where did everyone get their kits from? ( I've found 2-3 others beside windrider that carry WR's 737)
2) Do the kits come with the 10-11 blade fans as stock? (photos show 4 blade fans)
3) Any thing else needed to know?
Thanks.
N437D is offline Find More Posts by N437D
Old Feb 13, 2012, 12:14 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
DerekB
the fly bye is a good thing ,I do it with all my retract models
to assure that all have extended and look to be all the way down.
on real aircraft there are lights to show that the gear is down and
locked or fully retracted with a model its visual
also my transmitter alows for the speed control of the flap servos
so that the flap's extend and retract slowly ,this makes the model
less likly to pitch up or down , the transmitter also is programed
to add some up with flap extension
I use a Hitec aurora 9 but hobby king sells a servo speed controler
Old Feb 13, 2012, 12:29 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
N437D
depending where you get this ,the fans may or may not be included
as of now I belive they only come with the 4 blade units ,which
with a good motor will fly this with no problem I used ming's
setup and the model has more than enough power.
the 10 blade 70mm fans sound good but I'm not inpressed with
them .
basicly it a easy to fly great model very scale except for the
cockpit window which can be easily fixed
Old Feb 13, 2012, 01:59 PM
carrerars is offline
Find More Posts by carrerars
carrerars's Avatar
Joined Aug 2008
what's wrong with the cockpit window ????
Markus
carrerars is offline Find More Posts by carrerars
Old Feb 13, 2012, 02:02 PM
Joined Dec 2010
probably that theres no eyebrows ?
Old Feb 13, 2012, 04:20 PM
swarick is offline
Find More Posts by swarick
Stay Thirsty My Friends
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
New 737-700 aircraft coming off the assembly line no longer have eyebrow windows. The carrier I fly for (Southwest) has also removed the windows and replaced them with a plug. Apparently it saves money on maintenance.
Rick
swarick is offline Find More Posts by swarick
Old Feb 13, 2012, 04:30 PM
Joined Dec 2010
what was the point o the eyebrows ??
Old Feb 13, 2012, 06:55 PM
Ming is online now
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
Yes, we strongly suggest to use 4 blades EDF for 737.
Ming Lou
Ming is online now Find More Posts by Ming
Site Sponsor
Old Feb 13, 2012, 07:48 PM
Doug W is offline
Find More Posts by Doug W
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
Ming Lou
Eyebrow windows= chicks. Chicks dig eyebrow windows, it's a scientific fact.
No eyebrow windows? You better at least have flaps, maybe spoilers or no chicks.
Now, that having been said, they deleted them on production series some time ago, which is a shame really, because now all the Boeing Renton employees are without chicks.
In reality, the only thing they were good for is baking the crew at the gate and blinding them enroute...
(We really do have the nerdiest hobby, I must admit...still, I love it!)
Doug W is offline Find More Posts by Doug W
Discussion Windrider Boeing 737 Ming Scale Kit/Scratch Built 638 Mar 10, 2016 12:41 PM
Discussion Windrider Boeing 737-700 could be a good glider Ming Slope 63 Jul 02, 2015 09:31 PM
New Product Boeing 737 philipcmf Foamy EDFs 83 Jan 16, 2011 09:03 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
