Selecting power system
After couple of days of research here is the list of power options I found. By all means this is not everything but rather an attempt to find a suitable scale sounding power plant. I got my eye on 8 blade fan. People are saying it sounds closest to the turbine, or I'd say less reminding a Hoover vacuum cleaner
![]() There are two 8-blade fans on the market. One is DF70 from BP Hobbies and another is Skyworld fan. DF70 fan Skyworld aluminum fan There are very little test data available for 8 blade fans. One test was done by St. Martin here. HET 2W, 40c 2200 3s, 52A @ 510W. St. Martin recommends using 2200 4S setup with HET 3W motor. The amp draw will be 35A @ 450W average. It will be much more efficient set up than 3S. ExtremeRc suggests using 2W20 motor on 4S. This setup will be more powerful than 3W but reasoning behind is one can always cut on throttle for scale flying and only use more power when needed. EffluxRc recommends set of ARC motors to use. There are three different recommendations but they all have one thing in common - use 4S setup because it will be more efficient, draw less amps, less heat, and can be actually lighter than 3S. I personally having hard time to decide between 3W and 2W20. * 3W will most likely be most efficient, work at its max RPMs (better for ESC), lighter by 15g and $15 but will spare almost no reserve power when things happen. * 2W20 has wider power envelope but heavier, more expensive and less scale in terms of thrust/weight ratio. So here is the list of motors with prices, Kv and power limits. What do you think? |
I will be building my next AIRBUS once the 70mm is released on MOTO-TURBINE. The 64 mm is now released for $55 complete, assembled. The heck iS MOTOTURBINE? A result of 3 years in research and development these Taiwanese manufactured 64mm EDF units are on the cutting edge of EDF design. The duct unit is made from aircraft grade high tensile Aluminum alloy to improve performance and help reduce deformity of the duct during installation. The fan blade is the first in the world to use high tensile aluminum alloy, A result of 18 months of wind-tunnel tests and Computer Aided Evaluation. The fan unit reduces high speed deformation by 90%, compared to a conventional ABS or plastic fan. All Moto-turbine parts are manufactured using precision CNC machine tools in Taiwan. CNC machining enables a high level of acuaracy in the manufacturing proccess and ensures strict tolernances can be maintained. In conventional ducted fan design, the motor is secured to the stator hub while the fan secured to the motor shaft. During operation, any imperfection in either the motor or fan will cause both the fan and motor to vibrate at a certain resonance frequency. The oscillation can cause the blade tip to rub against the shroud of the duct. Moto-turbine’s 3-bearing system reduces resonance vibration by 90%. http://www.hobbyking.com/hobbyking/s...dProduct=15171 NOW GO TO THIS SITE , THEN CLICK THE TABS BELOW THE WEBPAGE TO LEARN ABOUT THIS STATE OF THE ART EDF TECHNOLOGY http://www.epf.com.tw/turbine/Turbine_index.html spyro |
Spyro, Sir if you want a turbine sound go with Stumax fans 11 bladed fans enclosed a video
I guess it's time to make an experiment
![]() I have A380 which is close to B737 and flies extremely scale! So I hooked up a watt meter and at full throttle I've got 500W. The Airbus' AUW is 4.4lb which makes a scale airliner watt per pound ratio = 114. So... for 737's 6.6lb AUW the most scale power is 375W per motor. Voila!
| Thread Tools | |
| Discussion Windrider Boeing 737 | Ming | Scale Electric Planes | 628 | Mar 30, 2013 07:20 PM |
| New Product Boeing 737 | philipcmf | Foamy EDFs | 83 | Jan 16, 2011 09:03 AM |
| Discussion Windrider Boeing 737-700 could be a good glider | Ming | Slope | 44 | Jan 06, 2011 07:47 PM |
| Boeing 737 | jermaine | Foamies (Kits) | 6 | Apr 08, 2002 11:21 PM |
